5978|12
wince中hook的问题 [复制链接]
看了很多资料wince下只支持三种hook.
按照资料加载coredll.dll,在模拟器上调试.使用WH_KEYBOARD_LL安装后返回的hook是0x01.而且不进处理程序,使用WH_JOURNALRECORD,安装后返回的是0.
请问是模拟器的问题吗?
代码几乎是和网上的一样
得到的值是多少我不清楚,不过我的可以提示("set hook 成功"),  详情 回复 发表于 2008-7-29 15:25
82
键盘的HOOK,LZ是如何实现与加载的?
和模拟器的关系不大。
98
试试这个,我使用使用WH_KEYBOARD_LL已经可以正常使用了
  1. BOOL ActivateKBHook(HINSTANCE hInstance)//, HOOKPROC LLKeyboardHookCallbackFunction)
  2. {
  3.         //we need to manually load these standard Win32 API calls
  4.         //MSDN states that these aren't supported in WinCE
  5.         SetWindowsHookEx                = NULL;
  6.         CallNextHookEx                        = NULL;
  7.         UnhookWindowsHookEx                = NULL;
  8.         //now load the coredll.dll
  9.         g_hHookApiDLL = LoadLibrary(_T("coredll.dll"));
  10.         if(g_hHookApiDLL == NULL)
  11.         {
  12.                 //something is awfully wrong
  13.                 //the dll has to be present
  14.                 return false;
  15.         }
  16.         else
  17.         {
  18.                 //load the SetWindowsHookEx API call
  19.                 //the SetWindowsHookEx function installs an application-defined hook procedure into a hook chain.
  20.                 //You would install a hook procedure to monitor the system for certain types of events.
  21.                 //here we use use the hook to monitor kyeboard events
  22.                 SetWindowsHookEx = (_SetWindowsHookExW)GetProcAddress(g_hHookApiDLL, _T("SetWindowsHookExW"));
  23.                 if(SetWindowsHookEx == NULL)
  24.                 {
  25.                         //this means that MS has really stopped supporting this API in WinCE
  26.                         return false;
  27.                 }
  28.                 else
  29.                 {
  30.                         //install the KB hook
  31.                         //the hande needs to be saved for default processing of the events and to uninstall the hook, once we are done with it
  32.                         g_hInstalledLLKBDhook = SetWindowsHookEx(WH_KEYBOARD_LL, LLKeyboardHookCallbackFunction, hInstance, 0);
  33.                         if(g_hInstalledLLKBDhook == NULL)
  34.                         {
  35.                                 MessageBox(NULL,TEXT("set hook error"),TEXT("error"),MB_OK);//我的
  36.                                 return false;
  37.                         }
  38.                         else MessageBox(NULL,TEXT("set hook 成功"),TEXT("error"),MB_OK);//我的程序
  39.                 }
  40.                 //load CallNextHookEx() API call
  41.                 //the CallNextHookEx function passes the hook information to the next hook procedure in the current hook chain.
  42.                 //we use this call for default processing of events.
  43.                 CallNextHookEx = (_CallNextHookEx)GetProcAddress(g_hHookApiDLL, _T("CallNextHookEx"));
  44.                 if(CallNextHookEx == NULL)
  45.                 {
  46.                         return false;
  47.                 }
  48.                 //load UnhookWindowsHookEx() API
  49.                 //the UnhookWindowsHookEx function removes a hook procedure installed in a hook chain by the SetWindowsHookEx function.
  50.                 //we use this call to unistall the hook.
  51.                 UnhookWindowsHookEx = (_UnhookWindowsHookEx)GetProcAddress(g_hHookApiDLL, _T("UnhookWindowsHookEx"));
  52.                 if(UnhookWindowsHookEx == NULL)
  53.                 {
  54.                         return false;
  55.                 }
  56.         }
  57.         //all the APIs are loaded and the application is hooked
  58.         return true;
  59. }
复制代码
我使用的是全局hook,写了个dll
59
HINSTANCE hInstance怎么赋值呢?
我也是写的dll,全局Hook.我把hInstance赋值为theApp.m_hInstance.因为wince的winmain第一个参数是handle
65
LLKeyboardHookCallbackFunction这个函数需要定义为dllexport吗?
75
WH_JOURNALRECORD在wince下能实现吗?
82
引用 4 楼 helen_alone 的回复:
[/quote]
我是这样调用钩子的,其中,AdKeyboardHook是dll文件的名字。
ActivateKBHook(GetModuleHandle(_T("AdKeyboardHook")));///////调用dll,挂钩
引用 5 楼 helen_alone 的回复:
不用的。
我只 __declspec(dllexport) BOOL ActivateKBHook(HINSTANCE hInstance);
还有一个
__declspec(dllexport) BOOL DeactivateKBHook();
[quote]引用 6 楼 helen_alone 的回复:
这个没试过
按照你的一样写了,还是得到hook是0x01
63
函数的值都能得到。
glhHook = SetWindowsHookEx(WH_KEYBOARD_LL, (int)MouseProc, gInstance, 0);
75
没有人遇到过吗?
安装hook得到0x01
78
66
引用 10 楼 helen_alone 的回复:
没有人遇到过吗?
安装hook得到0x01
猜你喜欢
直播时间:4月22日(周二)10:00
直播奖励:京东卡、蓝牙温湿度计、定制水杯
