在我使用sate210-F 的wince系统的时候,出现了以下几个问题:
1,使用光盘资料提供的uboot,nk.nb0时候,将wince,android烧写成功以后,先进入android,然后重启进入wince,再重启的时候不会进入uboot,串口输出以下信息:
SD checksum Error
SD Init Error
Uart negotiation Error
Enumeration TimeOut Error
SD checksum Error
2.使用光盘资料提供的wince bsp编译出来的nk,下载进去以后,运行时候会出现以下错误:
SD checksum Error
OK
********************Sate210 VIP Uboot V1.0.0 RC1****************
** Websit:www.***.net
** Email:gooogleman@foxmail.com
** taobao:http://***.***.com/
** Author:gooogleman
** Date:Jan 9 2014 - 22:56:14 for Sate210
CPU: S5PV210@1000MHz(OK)
APLL = 1000MHz, HclkMsys = 200MHz, PclkMsys = 100MHz
MPLL = 667MHz, EPLL = 80MHz
HclkDsys = 166MHz, PclkDsys = 83MHz
HclkPsys = 133MHz, PclkPsys = 66MHz
SCLKA2M = 200MHz
Board: Sate210
DRAM: 512 MB
SD/MMC: Warning: cannot find the raw area table(23e4dfec) 00000000
bl1: 1
env: 17
bl2: 49
knl: 1073
wince: 9265
logo: 152625
rfs: 169009
3776MB
*** Warning - using default environment
In: serial
Out: serial
Err: serial
checking mode for fastboot ...
display is at700
3776MB
os is wince
Please hit any key to stop autoboot : 3
### 2 do_movi( ) @sate210VIP-uboot @sate210VIP-uboot!
reading wince.. 9265, 143360
MMC read: dev # 0, block # 9265, count 143360 ...143360 blocks read: OK
completed
***********Sate210VIP-uboot to Start to run OS***********
Windows CE Kernel for ARM (Thumb Enabled) Built on May 7 2012 at 12:47:43
DCache: 128 sets, 4 ways, 64 line size, 32768 size
ICache: 128 sets, 4 ways, 64 line size, 32768 size
Exception 'Raised Exception' (-1): Thread-Id=00ae0002(pth=9ff783b8), Proc-Id=017f0006(pprc=9ffc6eac) 'udevice.exe', VM-active=017f0006(pprc=9ffc6eac) 'udevice.exe'
PC=400252d8(coredll.dll+0x000152d8) RA=800322c8(kernel.dll+0x000062c8) SP=0008f8bc, BVA=00000000
PC=4002373c(coredll.dll+0x0001373c) RA=800322c8(kernel.dll+0x000062c8) SP=0008fb28, BVA=00000000
Exception 'Raised Exception' (-1): Thread-Id=00ae0002(pth=9ff783b8), Proc-Id=01900006(pprc=9ffc6eac) 'udevice.exe', VM-active=01900006(pprc=9ffc6eac) 'udevice.exe'
Exception 'Raised Exception' (-1): Thread-Id=00ae0002(pth=9ff783b8), Proc-Id=019a0006(pprc=9ffc6eac) 'udevice.exe', VM-active=019a0006(pprc=9ffc6eac) 'udevice.exe'
这时候重启,无法启动,串口输出以下打印
SD checksum Error
SD Init Error
SD checksum Error
同志们有人出现这种情况吗,应该怎么解决呢。。。。。。
