2336|2
65
驱动加载出错 [复制链接]
我写了个驱动程序,编译没错,但是insmod的时候就出现
moduletest: please compile with -fno-common
insmod: cannot insert `moduletest.ko': Invalid module format (-1): Exec format error的错误,不知道为什么,求高手指教.
源码如下:
#include
#ifndef __KERNEL__
# define __KERNEL__
#endif
#ifndef MODULE
# define MODULE
#endif
MODULE_LICENSE("GPL");
#include
#include
#include
#include
#include
#include //for udelay
#include
#include
#define GPFCON (*(volatile unsigned long *) 0x56000050)
#define GPFDAT (*(volatile unsigned long *) 0x56000054)
#define GPF4_in  ~(1<<(4*2))
unsigned long dwdat;
unsigned int fs_major = 0;
static char *data;
static dev_OPEN=0;
static ssize_t GPIO_read(struct file *file,char *buf,size_t count,loff_t *f_pos);
static ssize_t GPIO_write(struct file *file,const char *buffer,size_t count,loff_t *f_pos);
static int  GPIO_open(struct inode *inode,struct file *file);
static int  GPIO_release(struct inode *inode,struct file *file);
static ssize_t  GPIO_ioctl(struct inode *inode,struct file *file,unsigned int ret,unsigned long data);
int init_module(void);
void cleanup_module(void);
static struct file_operations GPIO_fops = {
        read: GPIO_read,
        write: GPIO_write,
        ioctl: GPIO_ioctl,
        open: GPIO_open,
        release: GPIO_release,
        int len;
        if(count<0)
                return -EINVAL;
        len = strlen(data);
        if(len                 count = len;
        copy_to_user(buf,data,count+1);
        return count;
        if(count < 0)
                return -EINVAL;
        kfree(data);
        data = (char *)kmalloc(sizeof(char)*(count+1),GFP_KERNEL);
        if(!data)
        return -ENOMEM;
        copy_from_user(data,buffer,count+1);
        return count;
        //MOD_INC_USE_COUNT;
        dev_OPEN++;
        printk("This is open\n");
        return 0;
{        GPFCON=GPF4_in;
        dwdat=GPFDAT;
        ret=dwdat&(1<<4);
        if(ret)   //如果是高电平返回1
                return ret;
        //MOD_DEC_USE_COUNT;
        dev_OPEN--;
        //module_put(fs_major);
        printk("this is released\n");
        return 0;
        int res;
        res=register_chrdev(0,"my2440dev",&GPIO_fops);
        printk("can get major name %d!\n ",res);
        if(res<0)
                printk("can't get major name!\n");
                return res;
        if(fs_major ==0)
                fs_major = res;
        return 0;
        unregister_chrdev(fs_major,"my2440dev");
这就是对应的makefile,如果不要那个ioctl函数就没问题,不知道为什么,第一次编译驱动遇到的问题实在有点棘手, CFLAGS=-D__KERNEL__ -DMOUDULE -DDEBUG_PRINTK -I/opt/FriendlyARM/QQ2440V3/kernel-2.6.13/include/ ifneq ($(KERNELRELEASE),)         obj-m     := moduletest.o else KDIR :=/opt/FriendlyARM/QQ2440V3/kernel-2.6.13/ PWD := $(shell pwd) default:         $(MAKE) -C $(KDIR) SUBDIRS=$(PWD) modules endif   详情 回复 发表于 2009-3-1 19:00
75
你的.ko文件怎么编译出来的?把你写的Makefile文件也贴出来看看
77
else
PWD := $(shell pwd)
default:
endif
