2422|0
德国伍尔特1210功率电感7447709680 68μH 3.2A 12×12×10mm [复制链接]
凝睿电子作为德国伍尔特电子国内唯一样品代理,提供其全系列元件。
WE-HCC SMD High Current Cube Inductor
Characteristics:
Magnetically shielded version which results in a low leakage field
High storage capacity
Low self-losses
Highest possible current loading for SMD Inductors
Operating temperature: –40 °C to +125 °C
Recommended solder profile: Reflow
Würth Elektronik included now in their product range as well the WE-PD with white coating for a higher light efficiency used in LED applications. Hence a pleasant optical design, where beside the circuit board as well the mounted components could now be manufactured in white color, is possible. The SMD Power Inductor is available with white coating in the sizes 7332, 7345, 1260 and 1280 (all with plastic base).
Applications:
Switching regulators with low operating voltages (computer, laptop, mobile phones, pagers)
Integrated DC/DC-converter
Perfectly suitable for switching regulators with extremely high efficiency (> 86%)
Graphic cards
Plastic base: Because of the one piece construction these are more suitable for high vibration or shock applications
元件生产商:Wurth Electronic 德国伍尔特
元件系列: 1210
料号
PN
尺寸
Dimension
电感值
Inductance
精度
Tolerance
额定电流
Rated Current
直流阻抗
DC Resistance
自谐频率
Self Resonant Frequency
7447709152 12×12×10mm 1500μH ±20% 0.9A 2300mΩ
7443310100 12.1×11.4×9.5mm  1μH ±20% 21A 1.15mΩ 100MHz
7447709003 12×12×10mm 3.5μH ±20% 16.5A 8.5mΩ  45MHz
7447709006 12×12×10mm 6.8μH ±20% 12.8A 14mΩ 23MHz
7447709100 12×12×10mm 10μH ±20% 10.5A 21mΩ 21MHz
7447709101 12×12×10mm 100μH ±20% 3.1A 110mΩ 0.1MHz
7447709102 12×12×10mm  1000μH ±20% 1A 1200mΩ 0.1MHz
7447709680 12×12×10mm 68μH ±20% 3.2A 88.5mΩ 6MHz
7447709330 12×12×10mm 33μH ±20% 4.2A 45mΩ 8.5MHz
7447709270 12×12×10mm 27μH ±20% 4.6A 40mΩ 8MHz
7447709220 12×12×10mm 22μH ±20%  5.3A 28mΩ 10MHz
74476410 2.9×3.2×2.2mm 10μH ±10% 0.15A 2100mΩ 36MHz
7447709470 12×12×10mm 47μH ±20% 3.8A 60mΩ 6.5MHz
有需要Wurth 的料的朋友们,请与旺旺:凝睿电子科技联系
有奖直播:ADMT4000 掀起多圈编码器设计革命 报名中!
直播时间:5月8日(周四)上午10:00
直播主题:ADMT4000 掀起多圈编码器设计革命
预报从速,好礼等您拿~
