视频链接:
代码仓库:GitHub - LitchiCheng/ros2_package
前期讲到了笛卡尔速度,也就是末端的速度控制,今天介绍下关节速度如何玩!
新建package,命名moveit_joint_velocity
- ros2 pkg create --build-type ament_cmake moveit_joint_velocity --dependencies rclcpp control_msgs geometry_msgs moveit_servo moveit_core moveit_msgs planning_scene_monitor tf2_ros
CMakeLists.txt文件
- cmake_minimum_required(VERSION 3.8)
- project(moveit_joint_velocity)
- if(CMAKE_COMPILER_IS_GNUCXX OR CMAKE_CXX_COMPILER_ID MATCHES "Clang")
- add_compile_options(-Wall -Wextra -Wpedantic)
- endif()
- # find dependencies
- find_package(ament_cmake REQUIRED)
- find_package(rclcpp REQUIRED)
- find_package(control_msgs REQUIRED)
- find_package(geometry_msgs REQUIRED)
- find_package(moveit_servo REQUIRED)
- find_package(moveit_core REQUIRED)
- find_package(moveit_msgs REQUIRED)
- find_package(tf2_ros REQUIRED)
- if(BUILD_TESTING)
- find_package(ament_lint_auto REQUIRED)
- # the following line skips the linter which checks for copyrights
- # comment the line when a copyright and license is added to all source files
- set(ament_cmake_copyright_FOUND TRUE)
- # the following line skips cpplint (only works in a git repo)
- # comment the line when this package is in a git repo and when
- # a copyright and license is added to all source files
- set(ament_cmake_cpplint_FOUND TRUE)
- ament_lint_auto_find_test_dependencies()
- endif()
- add_executable(joint_velocity_node src/joint_velocity.cpp)
- ament_target_dependencies(joint_velocity_node
- rclcpp
- control_msgs
- geometry_msgs
- moveit_servo
- moveit_core
- moveit_msgs
- tf2_ros
- install(TARGETS
- joint_velocity_node
- DESTINATION lib/${PROJECT_NAME}
- ament_package()
src中新建joint_velocity_node.cpp
- using namespace std::chrono_literals;
- static const rclcpp::Logger LOGGER = rclcpp::get_logger("moveit_joint_velocity.joint_velocity_node");
- rclcpp::Node::SharedPtr node_;
- rclcpp::Publisher<control_msgs::msg::JointJog>::SharedPtr joint_cmd_pub_;
- std::string joint_name = panda_joint1;
- double velocity = 0.0;
- void publishCommands()
- auto msg = std::make_unique<control_msgs::msg::JointJog>();
- msg->header.stamp = node_->now();
- msg->joint_names.push_back(joint_name);
- msg->velocities.push_back(velocity);
- joint_cmd_pub_->publish(std::move(msg));
- int main(int argc, char** argv)
- rclcpp::init(argc, argv);
- rclcpp::NodeOptions node_options;
- node_options.use_intra_process_comms(false);
- node_ = std::make_shared<rclcpp::Node>("joint_velocity_node", node_options);
- node_->declare_parameter("velocity", velocity);
- node_->declare_parameter("joint_name", joint_name);
- node_->get_parameter("velocity", velocity);
- node_->get_parameter("joint_name", joint_name);
- auto tf_buffer = std::make_shared<tf2_ros::Buffer>(node_->get_clock());
- auto planning_scene_monitor = std::make_shared<planning_scene_monitor::PlanningSceneMonitor>(
- node_, "robot_description", tf_buffer, "planning_scene_monitor");
- if (planning_scene_monitor->getPlanningScene())
- planning_scene_monitor->startStateMonitor("/joint_states");
- planning_scene_monitor->setPlanningScenePublishingFrequency(25);
- planning_scene_monitor->startPublishingPlanningScene(planning_scene_monitor::PlanningSceneMonitor::UPDATE_SCENE,
- "/moveit_servo/publish_planning_scene");
- planning_scene_monitor->startSceneMonitor();
- planning_scene_monitor->providePlanningSceneService();
- else
- RCLCPP_ERROR(LOGGER, "Planning scene not configured");
- return EXIT_FAILURE;
- joint_cmd_pub_ = node_->create_publisher<control_msgs::msg::JointJog>("joint_velocity_node/delta_joint_cmds", 10);
- auto servo_parameters = moveit_servo::ServoParameters::makeServoParameters(node_);
- if (!servo_parameters)
- RCLCPP_FATAL(LOGGER, "Failed to load the servo parameters");
- auto servo = std::make_unique<moveit_servo::Servo>(node_, servo_parameters, planning_scene_monitor);
- servo->start();
- rclcpp::TimerBase::SharedPtr timer = node_->create_wall_timer(50ms, publishCommands);
- auto executor = std::make_unique<rclcpp::executors::MultiThreadedExecutor>();
- executor->add_node(node_);
- executor->spin();
- rclcpp::shutdown();
- return 0;
编译运行,先运行rviz场景,再运行moveit_joint_node,指定joint_name和velocity
- colcon build --packages-select moveit_joint_velocity
- source install/setup.bash
- ros2 launch moveit2_tutorials demo.launch.py rviz_config:=panda_moveit_config_demo_empty.rviz
- ros2 run moveit_joint_velocity joint_velocity_node --ros-args -p joint_name:="panda_joint1" -p velocity:=0.3
不动的原因可能是到达关节限位
