3005|0
431
RV1106手把手教你:yolov5图像识别模型从pt转换到onnx再到rknn [复制链接]
邀请:@littleshrimp   @w494143467   @kiverin   @MianQi   参与回复
安装yolov5环境
  • git clone git@github.com:airockchip/yolov5.git
  • cd yolov5
  • pip3 install -r requirements.txt -i https://pypi.tuna.tsinghua.edu.cn/simple
使用yolov5官方模型进行预测测试
 下载yolov5m-seg.pt很慢,直接使用地址下载
https://github.com/ultralytics/yolov5/releases/download/v7.0/yolov5m-seg.pt
  安装下onnx
下载rknn-toolkit2
git clone git@github.com:airockchip/rknn-toolkit2.git
安装rknn-toolkit2环境依赖
  • dar@dar:~/epan/rv1106/rknn-toolkit2/rknn-toolkit2/packages$ python3 --version
  • Python 3.8.10
  • pip3 install -r requirements_cp38-1.6.0.txt -i https://pypi.tuna.tsinghua.edu.cn/simple
  • 会出现版本的问题,换一个国内源
  • pip3 install -r requirements_cp38-1.6.0.txt -i https://mirrors.aliyun.com/pypi/simple
安装rknn_toolkit2包
  • pip3 install rknn_toolkit2-1.6.0+81f21f4d-cp38-cp38-linux_x86_64.whl -i http://pypi.douban.com/simple
测试库是否安装正常
用test.py进行推理和转RKNN
进入dar@dar:~/epan/rv1106/rknn-toolkit2/rknn-toolkit2/examples/onnx/yolov5
运行python3 test.py
修改测试程序
  • git clone git@gitee.com:darboy/rknn_model_zoo.git
  • export GCC_COMPILER=/home/dar/epan/rv1106/luckfox-pico/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/bin/arm-rockchip830-linux-uclibcgnueabihf
  • ./build-linux.sh -t rv1106 -a armv7l -d yolov5
出现如下报错
  • [100%] Built target rknn_yolov5_demo
  • Install the project...
  • -- Install configuration: "Release"
  • -- Installing: /mnt/e/epan-ubuntu/rv1106/rknn_model_zoo/install/rv1106_linux_armv7l/rknn_yolov5_demo/./rknn_yolov5_demo
  • -- Set runtime path of "/mnt/e/epan-ubuntu/rv1106/rknn_model_zoo/install/rv1106_linux_armv7l/rknn_yolov5_demo/./rknn_yolov5_demo" to "$ORIGIN/lib"
  • -- Installing: /mnt/e/epan-ubuntu/rv1106/rknn_model_zoo/install/rv1106_linux_armv7l/rknn_yolov5_demo/./model/bus.jpg
  • -- Installing: /mnt/e/epan-ubuntu/rv1106/rknn_model_zoo/install/rv1106_linux_armv7l/rknn_yolov5_demo/./model/coco_80_labels_list.txt
  • -- Installing: /mnt/e/epan-ubuntu/rv1106/rknn_model_zoo/install/rv1106_linux_armv7l/rknn_yolov5_demo/lib/librknnmrt.so
  • -- Installing: /mnt/e/epan-ubuntu/rv1106/rknn_model_zoo/install/rv1106_linux_armv7l/rknn_yolov5_demo/lib/librga.so
  • The RKNN model can not be found in "/mnt/e/epan-ubuntu/rv1106/rknn_model_zoo/install/rv1106_linux_armv7l/rknn_yolov5_demo/model", please check!
不用管如上的模型没有,我们需要使用自己的rknn
将如下目录全部发送到rv1106开发板
  • cd /mnt/e/epan-ubuntu/rv1106/rknn_model_zoo/install/rv1106_linux_armv7l
  • scp -r rknn_yolov5_demo/ root@192.168.31.136:~
 将rknn的模型也复制到开发板
  测试一张随便从网上下载的图片,侵删~
查看本帖全部内容,请登录或者注册
点赞(1) 关注(1)
ADI 有奖直播报名中~
直播时间:3月27日(周四) 上午10:00-11:30
直播主题:易于驱动SAR型ADC的原理、优点及应用介绍
好礼等你拿~
