#include <msp430.h>
void delay1s(void)
int t = 1000;
while (t--)
__delay_cycles(1000);
#define UART_TXD 0x02 // TXD on P1.1 (Timer0_A.OUT0)
#define UART_TBIT (1000000 / 9600) // 9600 Baud, SMCLK = 1MHz
// Globals for transmit UART communication
unsigned int txData; // UART internal variable for TX
void TimerA_UART_tx(unsigned char byte); // Function prototypes
void TimerA_UART_print(char *string);
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
DCOCTL = 0x00; // Set DCOCLK to 1MHz
BCSCTL1 = CALBC1_1MHZ;
DCOCTL = CALDCO_1MHZ;
P1OUT = UART_TXD; // Initialize P1.1
P1SEL = UART_TXD; // Timer function for TXD pin
P1DIR = UART_TXD; // Set TXD pin to output
// Timer_A for transmit UART operation
TA0CCTL0 = OUT; // Set TXD Idle as Mark = '1'
TA0CCTL1 = SCS + CM1 + CAP; // Sync, Neg Edge, Capture
TA0CTL = TASSEL_2 + MC_2; // SMCLK, start in continuous mode
P2DIR |= (BIT3 | BIT4); //Set P1.0 and P1.6 to outputs
_BIS_SR(GIE); // Enable CPU interrupts
while (1) {
TimerA_UART_print("G2553 TimerA UART\r\n"); // Send test message
TimerA_UART_print("READY.\r\n");
P2OUT ^= 0x18;
delay1s();
void TimerA_UART_tx(unsigned char byte) // Outputs one byte using the Timer_A UART
while (TACCTL0 & CCIE); // Ensure last char got TX'd
TA0CCR0 = TAR; // Current state of TA counter
TA0CCR0 += UART_TBIT; // One bit time till first bit
txData = byte; // Load transmit data, e.g. 'A'=01000001
txData |= 0x100; // Add mark stop bit, e.g. 101000001
txData <<= 1; // Add space start bit, e.g. 1010000010
TA0CCTL0 = OUTMOD0 + CCIE; // Set TXD on, enable counter interrupt
void TimerA_UART_print(char *string) { // Prints a string using the Timer_A UART
while (*string)
TimerA_UART_tx(*string++);
#pragma vector = TIMER0_A0_VECTOR // Timer_A UART - Transmit ISR
__interrupt void Timer_A0_ISR(void) {
static unsigned char txBitCnt = 10;
TA0CCR0 += UART_TBIT; // Add Offset to CCRx
if (txBitCnt == 0) { // All bits TXed?
TA0CCTL0 &= ~CCIE; // All bits TXed, disable interrupt
txBitCnt = 10; // Re-load bit counter
else {
if (txData & 0x01)
TA0CCTL0 &= ~OUTMOD2; // TX Mark '1'
else
TA0CCTL0 |= OUTMOD2; // TX Space '0'
txData >>= 1; // Shift right 1 bit (low bits TX'ed first)
txBitCnt--;
