2102|0
3836
MSP430 - G2553之串口操作 [复制链接]
#include
void delay1s(void)
  int t = 1000;
  while (t--)
    __delay_cycles(1000);
#define UART_TXD 0x02                                  // TXD on P1.1 (Timer0_A.OUT0)
#define UART_TBIT (1000000 / 9600)                     // 9600 Baud, SMCLK = 1MHz
                                                       // Globals for transmit UART communication
unsigned int txData;                                   // UART internal variable for TX
void TimerA_UART_tx(unsigned char byte);               // Function prototypes
void TimerA_UART_print(char *string);
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                            // Stop watchdog timer
  DCOCTL = 0x00;                                       // Set DCOCLK to 1MHz
  BCSCTL1 = CALBC1_1MHZ;
  DCOCTL = CALDCO_1MHZ;
  P1OUT = UART_TXD;                                    // Initialize P1.1
  P1SEL = UART_TXD;                                    // Timer function for TXD pin
  P1DIR = UART_TXD;                                    // Set TXD pin to output
                                                       // Timer_A for transmit UART operation
  TA0CCTL0 = OUT;                                      // Set TXD Idle as Mark = '1'
  TA0CCTL1 = SCS + CM1 + CAP;                          // Sync, Neg Edge, Capture
  TA0CTL = TASSEL_2 + MC_2;                            // SMCLK, start in continuous mode
  P2DIR |= (BIT3 | BIT4);                       //Set P1.0 and P1.6 to outputs
  _BIS_SR(GIE);                                        // Enable CPU interrupts
  while (1) {
    TimerA_UART_print("G2553 TimerA UART\r\n");          // Send test message
    TimerA_UART_print("READY.\r\n");
    P2OUT ^= 0x18;
    delay1s();
void TimerA_UART_tx(unsigned char byte)              // Outputs one byte using the Timer_A UART
  while (TACCTL0 & CCIE);                              // Ensure last char got TX'd
  TA0CCR0 = TAR;                                       // Current state of TA counter
  TA0CCR0 += UART_TBIT;                                // One bit time till first bit
  txData = byte;                                       // Load transmit data, e.g. 'A'=01000001
  txData |= 0x100;                                     // Add mark stop bit, e.g. 101000001
  txData <<= 1;                                        // Add space start bit, e.g. 1010000010
  TA0CCTL0 = OUTMOD0 + CCIE;                           // Set TXD on, enable counter interrupt
void TimerA_UART_print(char *string) {                 // Prints a string using the Timer_A UART
  while (*string)
    TimerA_UART_tx(*string++);
#pragma vector = TIMER0_A0_VECTOR                      // Timer_A UART - Transmit ISR
__interrupt void Timer_A0_ISR(void) {
  static unsigned char txBitCnt = 10;
  TA0CCR0 += UART_TBIT;                                // Add Offset to CCRx
  if (txBitCnt == 0) {                                 // All bits TXed?
    TA0CCTL0 &= ~CCIE;                                 // All bits TXed, disable interrupt
    txBitCnt = 10;                                     // Re-load bit counter
  else {
    if (txData & 0x01)
      TA0CCTL0 &= ~OUTMOD2;                            // TX Mark '1'
    else
      TA0CCTL0 |= OUTMOD2;                             // TX Space '0'
  txData >>= 1;                                        // Shift right 1 bit (low bits TX'ed first)
  txBitCnt--;
点赞 关注(1)
福禄克有奖直播:高精度测温赋能电子制造 报名中!
直播时间:2025年2月28日(周五)上午10:00
直播主题:高精度测温赋能电子制造
小伙伴们儿快来报名直播吧~好礼等你拿!
