4818|0
846
A novel 22. 5度 and 11. 25度 multi一octave MMIC [复制链接]
Abstract: Design, fabrication and(haracterization of a novel 22. 50 and 11.250 mufti
octave MMIC phase shifter with a sharing Lan;e(oupler is described ever 5 to band.  The topology was specifically selected to mmmize process variatrons on 20GHz band manfle Low peals phaseerror (<=2),low input/output VSWR( <=1.5), sertion loss variations( <=(2. 6士0. 4dB)range. The(hip size of the MMIC phase are   exhibited ever 5 to 4fimm 20CHz low  in一 frequency shifter is 4. 2mm *0.1mm
2462.rar
113.81 KB, 下载次数: 2
个人签名生活就是一场真人秀!
直播时间:4月22日(周二)10:00
直播奖励:京东卡、蓝牙温湿度计、定制水杯
