7779|2
180
急救!关于protel 99se的仿真 [复制链接]
当我在对一个电路进行仿真时总是出现这些错误,但我又不知道什么意思,请各位高手指点一下。 非常感谢! C3 Error: Pin order data (PINS=1:[]) not in READ ONLY field 4. Pins sorted by pin-name. C3 Error: Part type must be entered in READ ONLY field 1: type=() C3 Error: Netlist data must be entered in READ ONLY field 5: netlist= CB1 Error: Pin order data (PINS=1:[]) not in READ ONLY field 4. Pins sorted by pin-name. CB1 Error: Part type must be entered in READ ONLY field 1: type=() CB1 Error: Netlist data must be entered in READ ONLY field 5: netlist= CB2 Error: Pin order data (PINS=1:[]) not in READ ONLY field 4. Pins sorted by pin-name. CB2 Error: Part type must be entered in READ ONLY field 1: type=() CB2 Error: Netlist data must be entered in READ ONLY field 5: netlist= Q1 Error: Pin order data (PINS=1:[]) not in READ ONLY field 4. Pins sorted by pin-name. Q1 Error: Part type must be entered in READ ONLY field 1: type=() Q1 Error: Netlist data must be entered in READ ONLY field 5: netlist= R1 Error: Pin order data (PINS=1:[]) not in READ ONLY field 4. Pins sorted by pin-name. R1 Error: Part type must be entered in READ ONLY field 1: type=() R1 Error: Netlist data must be entered in READ ONLY field 5: netlist= R2 Error: Pin order data (PINS=1:[]) not in READ ONLY field 4. Pins sorted by pin-name. R2 Error: Part type must be entered in READ ONLY field 1: type=() R2 Error: Netlist data must be entered in READ ONLY field 5: netlist= RL Error: Pin order data (PINS=1:[]) not in READ ONLY field 4. Pins sorted by pin-name. RL Error: Part type must be entered in READ ONLY field 1: type=() RL Error: Netlist data must be entered in READ ONLY field 5: netlist= RC Error: Pin order data (PINS=1:[]) not in READ ONLY field 4. Pins sorted by pin-name. RC Error: Part type must be entered in READ ONLY field 1: type=() RC Error: Netlist data must be entered in READ ONLY field 5: netlist= RE Error: Pin order data (PINS=1:[]) not in READ ONLY field 4. Pins sorted by pin-name. RE Error: Part type must be entered in READ ONLY field 1: type=() RE Error: Netlist data must be entered in READ ONLY field 5: netlist= V1 Error: Pin order data (PINS=1:[]) not in READ ONLY field 4. Pins sorted by pin-name. V1 Error: Part type must be entered in READ ONLY field 1: type=() V1 Error: Netlist data must be entered in READ ONLY field 5: netlist= VCC Error: Pin order data (PINS=1:[]) not in READ ONLY field 4. Pins sorted by pin-name. VCC Error: Part type must be entered in READ ONLY field 1: type=() VCC Error: Netlist data must be entered in READ ONLY field 5: netlist= Setup Error: GND Spice Reference Net (specified in Analog Options) is not in the schematic.
此帖出自PCB设计论坛
我不知道 给你顶起来  详情 回复 发表于 2009-10-23 13:15
我也遇到同样的问题!期待高手答复!
此帖出自PCB设计论坛
2113
裸片初长成(初级)
我不知道
给你顶起来
此帖出自PCB设计论坛
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
第2场直播:融合热仿真与热测试提升产品可靠性
直播时间:04月17日 14:00 - 15:00
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 11
