2649|0
62
U_boot1.1.6 编译出错,很郁闷 [复制链接]
我用的是arm-linux-gcc-3.3.2   系统fedora 错误如下
t not recognized: failed to merge target specific data of file /usr/local/arm/3.3.2/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_udivdi3.oS)
/usr/local/arm/3.3.2/bin/arm-linux-ld: ERROR: /usr/local/arm/3.3.2/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_clz.oS) uses hardware FP, whereas u-boot uses software FP
File format not recognized: failed to merge target specific data of file /usr/local/arm/3.3.2/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_clz.oS)
make: *** [u-boot] Error 1
不知道有没有和我碰到一样的,指点一下啊,忙了两天,softfloat这个我也去了,还是不行
