3216|0
Linux-2.6.21 S3c6400中断剖析<二>(原创)-上海嵌入式索漫科技培训教材 [复制链接]
作者:下家山(请尊重原创,转载请注明)  http://www.xiajiashan.com
2.2 调用的第二个函数setup_irq
setup_irq的函数原形为
int setup_irq(unsigned int irq, struct irqaction *new)
{}(见kernel/irq/manage.c)
这个函数做的事情就多了:
下面逐句解释:
 * Internal function to register an irqaction - typically used to
 * allocate special interrupts that are part of the architecture.
       struct irq_desc *desc = irq_desc + irq;/* irq_desc是一个结构体数组,是一个全局变量,定义在include/linux/irq.h中,其初始化在后面会讲到*/
       struct irqaction *old, **p;
       const char *old_name = NULL;
       unsigned long flags;
       int shared = 0;
       if (irq >= NR_IRQS) /* 定义在/include/asm/irq.h 初始值为128*/
              return -EINVAL;
       if (desc->chip == &no_irq_chip)
              return -ENOSYS;
        * Some drivers like serial.c use request_irq() heavily,
        * so we have to be careful not to interfere with a
        * running system.
       if (new->flags & IRQF_SAMPLE_RANDOM) {
               * This function might sleep, we want to call it first,
               * outside of the atomic block.
               * Yes, this might clear the entropy pool if the wrong
               * driver is attempted to be loaded, without actually
               * installing a new handler, but is this really a problem,
               * only the sysadmin is able to do this.
              rand_initialize_irq(irq); /*当你在注册驱动时加入了IRQF_SAMPLE_RANDOM标志,则调用此函数,这个函数是内核引入的一个通过中断产生随机数的机制,毛德操写的《Linux内核源代码情景分析上册》P209解释的很清楚*/
        * The following block of code has to be executed atomically
       spin_lock_irqsave(&desc->lock, flags);/*对于中断请求队列的操作是一个原子性操作,不允许其他操作打扰,故加锁,使CPU进入临界区*/
       p = &desc->action;
       old = *p;
       if (old) {/*一般*p应为空(初始化时为空,后面会讲到),因为是第一次注册这个中断(我们大部分情况中断是不去共享的,也就是一个中断不会注册两次),故这里就不熬述了*/
               * Can't share interrupts unless both agree to and are
               * the same type (level, edge, polarity). So both flag
               * fields must have IRQF_SHARED set and the bits which
               * set the trigger type must match.
              if (!((old->flags & new->flags) & IRQF_SHARED) ||
                  ((old->flags ^ new->flags) & IRQF_TRIGGER_MASK)) {
                     old_name = old->name;
                     goto mismatch;
#if defined(CONFIG_IRQ_PER_CPU)
              /* All handlers must agree on per-cpuness */
              if ((old->flags & IRQF_PERCPU) !=
                  (new->flags & IRQF_PERCPU))
                     goto mismatch;
#endif
              /* add new interrupt at end of irq queue */
              do {
                     p = &old->next;
                     old = *p;
              } while (old);
              shared = 1;
       *p = new;                            /*把新的irq放到队列里*/
       if (new->flags & IRQF_PERCPU)
              desc->status |= IRQ_PER_CPU;
#endif
       /* Exclude IRQ from balancing */
       if (new->flags & IRQF_NOBALANCING)
              desc->status |= IRQ_NO_BALANCING;
       if (!shared) {
              irq_chip_set_defaults(desc->chip);/*函数原型见/kernel/irq/chip.c,主要设置几个重要的函数指针,后面专门做解释*/
              /* Setup the type (level, edge polarity) if configured: */
              if (new->flags & IRQF_TRIGGER_MASK) {/*注册新irq时如果标志位带触发条件,则执行,我们平常注册一个中断时只会带SA_INTERRUPT和SA_SHIRQ标志,触发条件有专门的函数实现*/
                     if (desc->chip && desc->chip->set_type)
                            desc->chip->set_type(irq,
                                          new->flags & IRQF_TRIGGER_MASK);
                     else
                             * IRQF_TRIGGER_* but the PIC does not support
                             * multiple flow-types?
                            printk(KERN_WARNING "No IRQF_TRIGGER set_type "
                                   "function for IRQ %d (%s)\n", irq,
                                   desc->chip ? desc->chip->name :
                                   "unknown");
              } else
                     compat_irq_chip_set_default_handler(desc);/*检查 新irq对应desc结构体的handle_irq*/
              desc->status &= ~(IRQ_AUTODETECT | IRQ_WAITING |
                              IRQ_INPROGRESS);/*确信这三个位不会置位,其定义见/include/linux/irq.h */
              /*在kernel启动初始化irq_desc 结构体时对desc->status 的设置值为IRQ_NOPROBE | IRQ_NOAUTOEN,故下面的if语句为真 */
              if (!(desc->status & IRQ_NOAUTOEN)) {
                     desc->depth = 0;
                     desc->status &= ~IRQ_DISABLED;/*当然要清这位*/
                     if (desc->chip->startup)/* 在上面已调用irq_chip_set_defaults(desc->chip);,其中就注册了desc->chip->startup 函数指针,见/kernel/irq/chip.c*/
                            desc->chip->startup(irq);/*会调用desc->chip->unmask ,而desc->chip->unmask最终会调用到s3c_irq_unmask,见/arch/arm/plat-s3c24xx/irq-pl192.c ,后面会专门讲*/
                     else
                            desc->chip->enable(irq);
              } else
                     /* Undo nested disables: */
                     desc->depth = 1;
       /* Reset broken irq detection when installing new handler */
       desc->irq_count = 0;
       desc->irqs_unhandled = 0;
       spin_unlock_irqrestore(&desc->lock, flags);
       new->irq = irq;
       register_irq_proc(irq);
       new->dir = NULL;
       register_handler_proc(irq, new);
/* register_irq_proc(irq);  register_handler_proc(irq, new);这两句主要是做在文件系统中建立一个与此irq对应的文件相关的事情*/
       return 0;
mismatch:
#ifdef CONFIG_DEBUG_SHIRQ
       if (!(new->flags & IRQF_PROBE_SHARED)) {
              printk(KERN_ERR "IRQ handler type mismatch for IRQ %d\n", irq);
              if (old_name)
                     printk(KERN_ERR "current handler: %s\n", old_name);
              dump_stack();
#endif
       return -EBUSY;
2009-2-13   下家山     写于上海.漕河泾
                                   有什么问题可以给我邮件ximenpiaoxue4016@sina.com或加我群198204885
