2812|3
2721
【Renesas Starter Kit for R8C2D】开箱上电 [复制链接]
前段时间论坛买了个瑞萨开发板,快递整整走了半个多月
开发板型号:Renesas Starter Kit for R8C2D,官网似乎已经停产
瑞萨开发板Starter Kit for R8C/2D套件应该包含如下,缺少红色部分,有的同学还请分享一下,一、特别是光盘资料,不胜感激
Starter Kit for R8C/2D KIT INCLUDES
- CPU Board
- Detachable LCD Display Module
- Detachable AD Adjustment Shaft
- E8a Emulator
- Connection Cable (USB Cable, User Interface Cable)
- Quick Start Guide
- CD-ROM
上电,电源指示灯亮
一会儿其他LED点亮,呈跑马灯形式,最后越闪越快,近乎长亮
开发板元件布局
开发板资源如下
MicrocontrollerR5F212D8SNFP
Input ClockMain: 20 MHz
Sub: 32.768 kHz
PotentiometerSingle-turn, 10 kΩ
LEDPower indicator: green x 1
Boot indicator: orange x 1
User: green x 1, orange x 1, red x 2
SwitchReset x 1
User/Boot x 1
User x 2
DC Power Jack5 V Input
E8a Header14-pin box header
RS232 Serial Connector9-pin DSUB
LCD Display Connector14-pin Socket
LIN Connector2.54 mm pitch, 3-pin (VBAT x 1, LIN Bus Line x 1, Ground x 1)
Microcontroller Pin Header2.54 mm pitch, 20-pin x 4
Application Board Interface2.54 mm pitch, 26-pin x 2 (JA1, JA2), 24-pin x 2 (JA5, JA6)
通过E8a emulator烧写程序,之前知道E4a,不知道瑞萨什么用意?两个有什么区别?
  • CD-ROM内容
    - Documents: User Manual, Tutorial, and more
    - IDE: High-performance Embedded Workshop
    - C Compiler: M3T-NC30WA Evaluation Version
    - Debugger: E8a Emulator Debugger
    - Flash Memory Programmer: Flash Development Toolkit Evaluation Version
此内容由EEWORLD论坛网友suoma原创,如需转载或用于商业用途需征得作者同意并注明出处
点亮了,CD里面的东西直接去网官下载不就行了!  详情 回复 发表于 2017-4-2 22:36
2721
按键会让LED进入快速闪烁状态,但是再无法退出,LED闪烁频率加快,估计和定时器有关
2774
嗯,有光盘最好了  详情 回复 发表于 2017-4-3 14:34
2721
嗯,有光盘最好了
