本次主要讨论裸机移植lwip,由于最近比较忙,暂且用库函数实现
第一步是看f769discovery的原理图
由图可知,网络所占用的IO,从datasheet可查出:
RMII_REF_CLK ----------------------> PA1
RMII_MDIO -------------------------> PA2
RMII_MDC --------------------------> PC1
RMII_MII_CRS_DV -------------------> PA7
RMII_MII_RXD0 ---------------------> PC4
RMII_MII_RXD1 ---------------------> PC5
RMII_MII_RXER ---------------------> PG2
RMII_MII_TX_EN --------------------> PG11
RMII_MII_TXD0 ---------------------> PG13
RMII_MII_TXD1 ---------------------> PG14
增加IO口的初始化操作
GPIO_InitTypeDef GPIO_InitStructure;
/* Enable GPIOs clocks */
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOG_CLK_ENABLE();
/* Ethernet pins configuration ************************************************/
void lan8742_init(void)
/* Configure PA1, PA2 and PA7 */
GPIO_InitStructure.Speed = GPIO_SPEED_HIGH;
GPIO_InitStructure.Mode = GPIO_MODE_AF_PP;
GPIO_InitStructure.Pull = GPIO_NOPULL;
GPIO_InitStructure.Alternate = GPIO_AF11_ETH;
GPIO_InitStructure.Pin = GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_7;
HAL_GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Configure PC1, PC4 and PC5 */
GPIO_InitStructure.Pin = GPIO_PIN_1 | GPIO_PIN_4 | GPIO_PIN_5;
HAL_GPIO_Init(GPIOC, &GPIO_InitStructure);
/* Configure PG2, PG11, PG13 and PG14 */
GPIO_InitStructure.Pin = GPIO_PIN_2 | GPIO_PIN_11 | GPIO_PIN_13 | GPIO_PIN_14;
HAL_GPIO_Init(GPIOG, &GPIO_InitStructure);
第二步,开始配置所需寄存器
void ETH_Init(void)
/* Enable SYSCFG Clock */
__HAL_RCC_SYSCFG_CLK_ENABLE();
/* Select MII or RMII Mode*/
SYSCFG->PMC &= ~(SYSCFG_PMC_MII_RMII_SEL);
SYSCFG->PMC |= (uint32_t)heth->Init.MediaInterface;
HAL_ETH_ReadPHYRegister(heth, PHY_BSR, &phyreg);
HAL_ETH_WritePHYRegister(heth, PHY_BCR, PHY_AUTONEGOTIATION);
HAL_ETH_ReadPHYRegister(heth, PHY_SR, &phyreg);
/* Config MAC and DMA */
ETH_MACDMAConfig(heth, err);
第三步设置默认IP
//lwip 默认IP设置
//lwipx:lwip控制结构体指针
void lwip_comm_default_ip_set(__lwip_dev *lwipx)
u32 sn0;
sn0=*(vu32*)(0x1FF0F420);//获取STM32的唯一ID的前24位作为MAC地址后三字节
//默认远端IP为:192.168.1.100
lwipx->remoteip[0]=192;
lwipx->remoteip[1]=168;
lwipx->remoteip[2]=1;
lwipx->remoteip[3]=104;
//MAC地址设置(高三字节固定为:2.0.0,低三字节用STM32唯一ID)
lwipx->mac[0]=2;//高三字节(IEEE称之为组织唯一ID,OUI)地址固定为:2.0.0
lwipx->mac[1]=0;
lwipx->mac[2]=0;
lwipx->mac[3]=(sn0>>16)&0XFF;//低三字节用STM32的唯一ID
lwipx->mac[4]=(sn0>>8)&0XFFF;
lwipx->mac[5]=sn0&0XFF;
//默认本地IP为:192.168.1.30
lwipx->ip[0]=192;
lwipx->ip[1]=168;
lwipx->ip[2]=1;
lwipx->ip[3]=30;
//默认子网掩码:255.255.255.0
lwipx->netmask[0]=255;
lwipx->netmask[1]=255;
lwipx->netmask[2]=255;
lwipx->netmask[3]=0;
//默认网关:192.168.1.1
lwipx->gateway[0]=192;
lwipx->gateway[1]=168;
lwipx->gateway[2]=1;
lwipx->gateway[3]=1;
lwipx->dhcpstatus=0;//没有DHCP
第五步,初始化LWIP内核
tcp_init();
第六步,初始化lwip stack
void Netif_Config(void)
ip_addr_t ipaddr;
ip_addr_t netmask;
ip_addr_t gw;
/* IP address setting */
IP4_ADDR(&ipaddr, IP_ADDR0, IP_ADDR1, IP_ADDR2, IP_ADDR3);
IP4_ADDR(&netmask, NETMASK_ADDR0, NETMASK_ADDR1 , NETMASK_ADDR2, NETMASK_ADDR3);
IP4_ADDR(&gw, GW_ADDR0, GW_ADDR1, GW_ADDR2, GW_ADDR3);
/* - netif_add(struct netif *netif, ip_addr_t *ipaddr,
ip_addr_t *netmask, ip_addr_t *gw,
void *state, err_t (* init)(struct netif *netif),
err_t (* input)(struct pbuf *p, struct netif *netif))
Adds your network interface to the netif_list. Allocate a struct
netif and pass a pointer to this structure as the first argument.
Give pointers to cleared ip_addr structures when using DHCP,
or fill them with sane numbers otherwise. The state pointer may be NULL.
The init function pointer must point to a initialization function for
your ethernet netif interface. The following code illustrates it's use.*/
netif_add(&gnetif, &ipaddr, &netmask, &gw, NULL, eernetif_init, &tcpip_input);
/* Registers the default network interface. */
netif_set_default(&gnetif);
if (netif_is_link_up(&gnetif))
/* When the netif is fully configured this function must be called.*/
netif_set_up(&gnetif);
else
/* When the netif link is down this function must be called */
netif_set_down(&gnetif);
第七步 开始轮询收发数据,
lwip_periodic_handle();
另外,使用轮询,需要添加一个timer进行辅助操作
void timer3_init(void)
进行编译,运行即可,设置本地链接的IP
在命令行中输入
ping命令
说明运行成功链接到了。
有时间可以增加数据的收发。
点击此处,查看STM32F769I开发板官方资源。
