2167|1
MSP430f5310 ADC多通道采集问题 [复制链接]
        你好,我在使用ADC多通道采集时遇到的问题,首先,我使用的ADC 4通道10位采集(A3,A2,A1,A0),采用内部基准电压2.5v,利用DMA取出ADC转换数据。我的问题是,在A3电压为0时,为什么采集的AD转换值 为110.理论上应该是0,才对,不知道问题出在什么地方,请给出帮助。谢谢
#include
unsigned int ADC_Result[4];
int main(void)
  WDTCTL = WDTPW | WDTHOLD;                 // Stop WDT
  // Configure ADC10
  ADC10CTL0 = ADC10SHT_2 | ADC10MSC | ADC10ON;// 16ADCclks, MSC, ADC ON
  ADC10CTL1 = ADC10SHP | ADC10CONSEQ_1;     // sampling timer, s/w trig.,single sequence
  ADC10CTL2 |= ADC10RES;                   // 10-bit resolution
  ADC10MCTL0 = ADC10SREF_1 |ADC10INCH_3;                 // A0,A1,A2,A3(EoS), AVCC reference
  while(REFCTL0 & REFGENBUSY);              // If ref generator busy, WAIT
  REFCTL0 |= REFVSEL_2|REFON;               // Select internal ref = 2.5V
  // Configure DMA0 (ADC10IFG trigger)
  DMACTL0 = DMA0TSEL_24;                    // ADC10IFG trigger
  __data16_write_addr((unsigned short) &DMA0SA,(unsigned long) &ADC10MEM0);
                                            // Source single address
  __data16_write_addr((unsigned short) &DMA0DA,(unsigned long) &ADC_Result[0]);
                                            // Destination array address
  DMA0SZ = 0x04;                            // 4 conversions
  DMA0CTL = DMADT_4 | DMADSTINCR_3  | DMAEN | DMAIE;
                                            // Rpt, inc dest, byte access,
                                            // enable int after seq of convs
  while(1)
    while (ADC10CTL1 & ADC10BUSY);          // Wait if ADC10 core is active
    ADC10CTL0 |= ADC10ENC | ADC10SC;        // Sampling and conversion start
    __bis_SR_register(CPUOFF | GIE);        // LPM0, ADC10_ISR will force exit
    __delay_cycles(5000);                   // Delay between sequence convs
    __no_operation();                       // BREAKPOINT; check ADC_Result
#pragma vector=DMA_VECTOR
__interrupt void DMA0_ISR (void)
  switch(__even_in_range(DMAIV,16))
    case  0: break;                         // No interrupt
    case  2:
      // sequence of conversions complete
      __bic_SR_register_on_exit(CPUOFF);    // exit LPM
      break;                                // DMA0IFG
    case  4: break;                         // DMA1IFG
    case  6: break;                         // DMA2IFG
    case  8: break;                         // Reserved
    case 10: break;                         // Reserved
    case 12: break;                         // Reserved
    case 14: break;                         // Reserved
    case 16: break;                         // Reserved
    default: break;
在A3电压为0时,实际测量值是多少。0V?A3的电压,不同,得到的数据是否会变化。接近2.5V时,数据是否基本正确。  详情 回复 发表于 2016-4-26 20:53
3471
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
第2场直播:融合热仿真与热测试提升产品可靠性
直播时间:04月17日 14:00 - 15:00
