6414|6
52单片机的程序问题,程序刚开始可以执行,可是执行一段时间后就不灵敏了!求高人指点 [复制链接]
#include         // 89C52单片机头文件
#include
#include
sbit key1=P1^0;
sbit key2=P1^1;
sfr ISP_CONTR=0xe7;
idata unsigned char dis5_temp_buf[50];
unsigned int num4=0,temp=0,num5=0;
unsigned char temp_buf_f=0;
unsigned int  flag=0,flag1=0,flag2=0,flag3=0,flag4=0;
double num2=0,num3=0;
unsigned int num=0,num1=0;
unsigned  char dis0_temp_buf[7]={"
unsigned  char dis4_temp_buf[6]={"JI"};
unsigned  char dis6_temp_buf[2]={'#'};
unsigned  char dis7_temp_buf[11]={"KF报警#"};
unsigned  char dis10_temp_buf[10]={"
idata unsigned  char dis11_temp_buf[9]={"KG常#"};
idata unsigned  char dis12_temp_buf[11]={"LF故障#"};
idata unsigned  char dis13_temp_buf[10]={"
idata unsigned  char dis14_temp_buf[9]={"LG常#"};
idata unsigned  char dis15_temp_buf[8]={"KK1#"};
idata unsigned  char dis16_temp_buf[8]={"KK0#"};
idata unsigned  char dis17_temp_buf[5]={"
idata unsigned  char dis18_temp_buf[5]={"
void delayms(unsigned int xms)         //延时程序
        unsigned int m,n;
        for(m=xms;m>0;m--)
                for(n=110;n>0;n--);
void T_init (void)           //T0用于计数,T2用于定时
        TMOD=0x25;             //设置T1定时器和T0计数器的工作方式
        TH0=0;                           //设置T0计数器初值
        TL0=0;
        TR0=1;                           // 启动定时器T0
        TH1=0xfd;                   //串口初始化设置
    TL1=0xfd;
    TR1=1;
    SM0=0;
    SM1=1;
        REN=0;
    ES=1;
        RCAP2H=(65536-45872)/256;        //T2定时器的初始化设置
        RCAP2L=(65536-45872)%256;
        TH2=RCAP2H;
        TL2=RCAP2L;
        T2CON=0x04;
        ET2=1;
/*void uart0_rx_isr() interrupt 4           //串口中断
RI=0;
temp_buf[temp_buf_f++]=SBUF;
if (temp_buf_f>=17)
   temp_buf_f=0;
void USART_Transmit( unsigned char date )        // 发送数据
ES=0;
SBUF=date;
while(!TI);
TI=0;
ES=1;
void send_data(unsigned char *buffer, unsigned char len)
unsigned char i=0;
for(i=0;i
  USART_Transmit(*buffer++);
void shipin_init (void)                                                          //视频初始化设置
  send_data(dis0_temp_buf,sizeof(dis0_temp_buf));
  delayms(10);
void main(void)        //主函数
shipin_init();
EA=1;
T_init();
// WDT_CONTR=0x34;
P1=0xff;
//key2=1;
while(1)
        if(flag==1)
            flag=0;
                delayms(2);
                if(key1!=0)
                    flag1=1;
                        delayms(20);
                        send_data(dis10_temp_buf,sizeof(dis10_temp_buf));
                        delayms(10);
                        send_data(dis11_temp_buf,sizeof(dis11_temp_buf));
                        delayms(10);
           if(key1==0)
                        delayms(10);
                        if (key1==0)
                         { flag1=0;
                           flag2=1;
                           flag3=0;
                           num4=0;
                           delayms(10);
                           send_data(dis7_temp_buf,sizeof(dis7_temp_buf));
                           delayms(10);
                           send_data(dis15_temp_buf,sizeof(dis15_temp_buf));
                           delayms(10);
                           send_data(dis18_temp_buf,sizeof(dis18_temp_buf));
                           delayms(10);
                temp=flag2+flag1;
                flag1=0;
            if (temp==2)
                {        temp=0;
                        flag3=1;
                        if(num4>=200)
                            //delayms(1);
                                send_data(dis16_temp_buf,sizeof(dis16_temp_buf));
                                delayms(10);
                                send_data(dis17_temp_buf,sizeof(dis17_temp_buf));
                                delayms(10);
                                num4=0;
                                flag3=0;
                                flag2=0;
                if(key2!=0)
                          delayms(10);
                    //send_data(dis13_temp_buf,sizeof(dis13_temp_buf));
                        delayms(10);
                        send_data(dis14_temp_buf,sizeof(dis14_temp_buf));
                        delayms(10);
            if (key2==0)
                        delayms(2);
                   if (key2==0)
                           send_data(dis12_temp_buf,sizeof(dis12_temp_buf));
                sprintf(dis5_temp_buf,"%.1f",num3) ;           //速度值保留一位小数
                delayms(10);
                send_data(dis4_temp_buf,sizeof(dis4_temp_buf));
            send_data(dis5_temp_buf,sizeof(dis5_temp_buf));
             send_data(dis6_temp_buf,sizeof(dis6_temp_buf));
                delayms(10);
                if(flag4==1)
                        flag4=0;
                        ISP_CONTR=0x20;
                delayms(100);
void T2_() interrupt 5                          //定时器T2中断
        TF2=0;
        num1++;
        num5++;
        if(num1==10)                                  //定时1秒
           num1=0;
           flag=1;
           num=256*TH0+TL0;
           TH0=0;
           TL0=0;
           num2=(double)num/27.69;
           num3=num2;
        if(flag3==1)
                num4++;
        if(num5>=6000)
           num5=0;
           flag4=1;
程序就是采集一个脉冲变量,还有两个开关量,为什么那key1开关量,在程序运行一段时间后,给1或者给0都没有变化,但是key2开关量一直都是正常的,跪求高人指点啊 。如果可以,有酬谢。
此帖出自51单片机论坛
那你检查一下你ttl电平低电平持续的时间吧,你程序有一堆软件延时,如果低电平持续时间不足,检查不到是很正常的  详情 回复 发表于 2014-3-11 09:24
推荐
闁哄被鍎冲﹢鍛村嫉椤掆偓缁楁﹢宕楅妸鈺佸姤閻犱降鍔忛鎴︽晬瀹€鍐惧殲闁谎嗩嚙缂嶏拷闁瑰瓨鐗為埀顒婃嫹婵炲鍔岄崬锟�
此帖出自51单片机论坛
81
没看明白的说!什么叫不灵敏?
此帖出自51单片机论坛
程序开始还行,执行一段时间没问题,这个时间可能是十几分钟,也可能是1个多小时,可是后面他就不灵敏了,我在KEY1为低电平时,他有时候能够执行if(key1==0)后面的语句,有时候不能执行if(key1==0)后面的语句。  详情 回复 发表于 2014-3-11 09:07
个人签名51嵌入式,嵌入式开发的家园!51嵌入式官方QQ群52497844,欢迎爱好者加入。
最好在读key前,将端口置1(上拉),防止之前端口被意外修改.
测量下key1电平是否在按键按下和释放有0到1的变化.
此帖出自51单片机论坛
我的程序是500ms执行一次,每次都要制1吗?我的key1是外接的一个TTL的信号,平时为高电平,等有报警时为低电平,我就是要采集到低电平,然后发从“报警”两个字。还望您给看看,谢谢  详情 回复 发表于 2014-3-11 09:11
Hugo801122 发表于 2014-3-11 01:10
没看明白的说!什么叫不灵敏?
程序开始还行,执行一段时间没问题,这个时间可能是十几分钟,也可能是1个多小时,可是后面他就不灵敏了,我在KEY1为低电平时,他有时候能够执行if(key1==0)后面的语句,有时候不能执行if(key1==0)后面的语句。还望帮忙看看,谢谢啊
此帖出自51单片机论坛
测量下key1电平是否在按键按下和释放有0到1的变 ...
此帖出自51单片机论坛
此帖出自51单片机论坛
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 13
