Sate210-F 开发板/核心板正常启动uboot,kernel,android4.0打印信息输出参考
OK
********************Sate210 VIP Uboot V1.0.0 RC1****************
** Websit:www.nqarm.net
** Email:gooogleman@foxmail.com
** taobao:http://gooogleman.taobao.com/
** Author:gooogleman
** Date:Mar 5 2014 - 10:58:02 for Sate210
CPU: S5PV210@1000MHz(OK)
APLL = 1000MHz, HclkMsys = 200MHz, PclkMsys = 100MHz
MPLL = 667MHz, EPLL = 80MHz
HclkDsys = 166MHz, PclkDsys = 83MHz
HclkPsys = 133MHz, PclkPsys = 66MHz
SCLKA2M = 200MHz
Board: Sate210
DRAM: 512 MB
SD/MMC: Warning: cannot find the raw area table(23e4e0ec) 00000000
bl1: 1
env: 17
bl2: 49
knl: 1073
wince: 9265
logo: 152625
rfs: 169009
3776MB
*** Warning - using default environment
In: serial
Out: serial
Err: serial
checking mode for fastboot ...
display is at700
3776MB
os is android
Please hit any key to stop autoboot : 3
### 2 do_movi( ) @sate210VIP-uboot @sate210VIP-uboot!
reading kernel.. 1073, 8192
MMC read: dev # 0, block # 1073, count 8192 ...8192 blocks read: OK
completed
reading RFS.. 169009, 3072
MMC read: dev # 0, block # 169009, count 3072 ...3072 blocks read: OK
completed
Boot with zImage
get_format
-------- 1 --------
## Loading init Ramdisk from Legacy Image at 21a00000 ...
Image Name: ramdisk
Created: 2014-02-27 3:03:27 UTC
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 163847 Bytes = 160 kB
Load Address: 30a00000
Entry Point: 30a00000
Verifying Checksum ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.0.8-svn1 (cyt@ubuntu) (gcc version 4.4.1 (Sourcery G++ Lite 2009q3-67) ) #6 PREEMPT Sat Mar 1 23:13:11 PST 2014
[ 0.000000] CPU: ARMv7 Processor [412fc082] revision 2 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: SMDKV210
[ 0.000000] Ignoring unrecognised tag 0x41001099
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] CPU S5PV210/S5PC110 (id 0x43110220)
[ 0.000000] S3C24XX Clocks, Copyright 2004 Simtec Electronics
[ 0.000000] S5PV210: PLL settings, A=1000000000, M=667000000, E=80000000 V=54000000
[ 0.000000] S5PV210: ARMCLK=1000000000, HCLKM=200000000, HCLKD=166750000
[ 0.000000] HCLKP=133400000, PCLKM=100000000, PCLKD=83375000, PCLKP=66700000
[ 0.000000] sclk_dmc: source is sclk_a2m (0), rate is 200000000
[ 0.000000] sclk_onenand: source is hclk_dsys (1), rate is 166750000
[ 0.000000] uclk1: source is mout_mpll (6), rate is 66700000
[ 0.000000] sclk_mixer: source is sclk_dac (0), rate is 54000000
[ 0.000000] sclk_fimc: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_cam0: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_cam1: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_fimd: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_mmc: source is mout_mpll (6), rate is 47642857
[ 0.000000] sclk_mmc: source is mout_epll (7), rate is 80000000
[ 0.000000] sclk_mfc: source is sclk_a2m (0), rate is 200000000
[ 0.000000] sclk_g2d: source is sclk_a2m (0), rate is 200000000
[ 0.000000] sclk_g3d: source is sclk_a2m (0), rate is 200000000
[ 0.000000] sclk_csis: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_spi: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_pwi: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_pwm: source is ext_xtal (0), rate is 24000000
[ 0.000000] s5p: 37748736 bytes system memory reserved for mfc at 0x2dc00000, 0-bank base(0x2dc00000)
[ 0.000000] s5p: 37748736 bytes system memory reserved for mfc at 0x4dbf5000, 1-bank base(0x4dbf5000)
[ 0.000000] s5p: 6291456 bytes system memory reserved for fimc0 at 0x4d5f5000, 1-bank base(0x4d5f5000)
[ 0.000000] s5p: 10137600 bytes system memory reserved for fimc1 at 0x4cc4a000, 1-bank base(0x4cc4a000)
[ 0.000000] s5p: 6291456 bytes system memory reserved for fimc2 at 0x4c64a000, 1-bank base(0x4c64a000)
[ 0.000000] s5p: 8388608 bytes system memory reserved for jpeg at 0x2d400000, 0-bank base(0x2d400000)
[ 0.000000] s5p: 7680000 bytes system memory reserved for fimd at 0x4bef7000, 1-bank base(0x4bef7000)
[ 0.000000] s5p: 1843200 bytes system memory reserved for pmem_gpu1 at 0x2d23e000, 0-bank base(0x2d23e000)
[ 0.000000] s5p: 8388608 bytes system memory reserved for g2d at 0x2ca3e000, 0-bank base(0x2ca3e000)
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 99136
[ 0.000000] Kernel command line: console=ttySAC2,115200 init=/init
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 202MB 190MB 0MB = 393MB total
[ 0.000000] Memory: 390932k/512532k available, 11756k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xff000000 - 0xffe00000 ( 14 MB)
[ 0.000000] vmalloc : 0xf0800000 - 0xfd000000 ( 200 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0032000 ( 168 kB)
[ 0.000000] .text : 0xc0032000 - 0xc0559664 (5278 kB)
[ 0.000000] .data : 0xc055a000 - 0xc0597000 ( 244 kB)
[ 0.000000] .bss : 0xc0597024 - 0xc06d4df0 (1272 kB)
[ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:208
[ 0.000000] VIC @fd000000: id 0x00041192, vendor 0x41
[ 0.000000] VIC @fd010000: id 0x00041192, vendor 0x41
[ 0.000000] VIC @fd020000: id 0x00041192, vendor 0x41
[ 0.000000] VIC @fd030000: id 0x00041192, vendor 0x41
[ 0.000000] mult[140737]
[ 0.000000] max_delta_ns[2937815369]
[ 0.000000] min_delta_ns[30517]
[ 0.000000] rate[32768]
[ 0.000000] HZ[200]
[ 0.000000] Console: colour dummy device 80x30
[ 0.000090] Calibrating delay loop... 992.87 BogoMIPS (lpj=2482176)
[ 0.024824] pid_max: default: 32768 minimum: 301
[ 0.024935] Mount-cache hash table entries: 512
[ 0.025224] Initializing cgroup subsys debug
[ 0.025235] Initializing cgroup subsys cpuacct
[ 0.025247] Initializing cgroup subsys freezer
[ 0.025277] CPU: Testing write buffer coherency: ok
[ 0.027657] NET: Registered protocol family 16
[ 0.028872] S3C Power Management, Copyright 2004 Simtec Electronics
[ 0.033360] invalid media device
[ 0.033370] invalid media device
[ 0.033375] invalid media device
[ 0.033380] invalid media device
[ 0.033396] ---pmem_start is 0x4bef7000
[ 0.033445] smdkc110_setup_clocks: sclk_mmc: source is mout_mpll, rate is 47642857
[ 0.034007] S5PV210: Initializing architecture
[ 0.034679] s3c-adc s5pv210-adc: attached adc driver
[ 0.035187] s3c24xx-pwm s3c24xx-pwm.0: tin at 66700000, tdiv at 66700000, tin=divclk, base 0
[ 0.049351] bio: create slab at 0
[ 0.050283] SCSI subsystem initialized
[ 0.051385] usbcore: registered new interface driver usbfs
[ 0.051621] usbcore: registered new interface driver hub
[ 0.051771] usbcore: registered new device driver usb
[ 0.052267] s3c-i2c s3c2440-i2c.0: slave address 0x10
[ 0.052279] s3c-i2c s3c2440-i2c.0: bus frequency set to 378 KHz
[ 0.052580] s3c-i2c s3c2440-i2c.0: i2c-0: S3C I2C adapter
[ 0.052620] s3c-i2c s3c2440-i2c.1: slave address 0x10
[ 0.052630] s3c-i2c s3c2440-i2c.1: bus frequency set to 65 KHz
[ 0.053035] s3c-i2c s3c2440-i2c.1: i2c-1: S3C I2C adapter
[ 0.053072] s3c-i2c s3c2440-i2c.2: slave address 0x10
[ 0.053082] s3c-i2c s3c2440-i2c.2: bus frequency set to 65 KHz
[ 0.053233] s3c-i2c s3c2440-i2c.2: i2c-2: S3C I2C adapter
[ 0.053907] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.054395] Switching to clocksource clock_source_systimer
[ 0.054662] Switched to NOHz mode on CPU #0
[ 0.066188] NET: Registered protocol family 2
[ 0.066338] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.066854] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.067098] TCP bind hash table entries: 16384 (order: 6, 327680 bytes)
[ 0.067455] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.067463] TCP reno registered
[ 0.067472] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.067495] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.067677] NET: Registered protocol family 1
[ 0.067826] Trying to unpack rootfs image as initramfs...
[ 0.076757] Freeing initrd memory: 160K
[ 0.076824] PMU: registered new PMU device of type 0
[ 0.077085] Loaded driver for PL330 DMAC-0 s3c-pl330
[ 0.077095] DBUFF-64x8bytes Num_Chans-8 Num_Peri-2 Num_Events-32
[ 0.077163] Loaded driver for PL330 DMAC-1 s3c-pl330
[ 0.077171] DBUFF-8x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[ 0.077240] Loaded driver for PL330 DMAC-2 s3c-pl330
[ 0.077248] DBUFF-8x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[ 0.085357] ashmem: initialized
[ 0.098142] ROMFS MTD (C) 2007 Red Hat, Inc.
[ 0.098356] msgmni has been set to 763
[ 0.098443] io scheduler noop registered
[ 0.098450] io scheduler deadline registered
[ 0.098497] io scheduler cfq registered (default)
[ 0.098504] start plist test
[ 0.102946] end plist test
[ 0.103585] win->id=2, pmem_start=0x4c35c000
[ 0.103598] s3cfb s3cfb: [fb2] dma: 0x4c35c000, cpu: 0xf0c00000, size: 0x002ee000
[ 0.116176] FIMD src sclk = 166750000
[ 0.116215] s3cfb s3cfb: registered successfully
[ 0.116223] Start display and show logo
[ 0.233339] s5pv210-uart.0: ttySAC0 at MMIO 0xe2900000 (irq = 16) is a S3C6400/10
[ 0.234685] s5pv210-uart.1: ttySAC1 at MMIO 0xe2900400 (irq = 20) is a S3C6400/10
[ 0.244548] s5pv210-uart.2: ttySAC2 at MMIO 0xe2900800 (irq = 24) is a S3C6400/10
[ 1.056247] console [ttySAC2] enabled
[ 1.069539] s5pv210-uart.3: ttySAC3 at MMIO 0xe2900c00 (irq = 28) is a S3C6400/10
[ 1.085507] PA FB = 0x4C35C000, bits per pixel = 32
[ 1.088907] screen width=800 height=480 va=0xec35c000 pa=0x4c35c000
[ 1.095186] xres_virtual = 800, yres_virtual = 960, xoffset = 0, yoffset = 0
[ 1.102194] fb_size=3072000
[ 1.104953] Back frameBuffer[0].VAddr=ec4d3000 PAddr=4c4d3000 size=1536000
[ 1.118082] brd: module loaded
[ 1.122805] loop: module loaded
[ 1.124702] pmem_gpu1: 1 init
[ 1.129108] PPP generic driver version 2.4.2
[ 1.132266] PPP Deflate Compression module registered
[ 1.137008] PPP BSD Compression module registered
[ 1.141619] NET: Registered protocol family 24
[ 1.146060] dm9000 Ethernet Driver, V1.31
[ 1.151126] eth0: dm9000a at f0830300,f0832304 IRQ 32 MAC: 00:09:c0:ff:ec:48 (platform data)
[ 1.158560] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
[ 1.166018] usbcore: registered new interface driver pegasus
[ 1.171638] usbcore: registered new interface driver asix
[ 1.177008] usbcore: registered new interface driver cdc_ether
[ 1.182811] usbcore: registered new interface driver dm9601
[ 1.188357] usbcore: registered new interface driver net1080
[ 1.193986] usbcore: registered new interface driver cdc_subset
[ 1.199884] usbcore: registered new interface driver zaurus
[ 1.205340] cdc_ncm: 04-Aug-2011
[ 1.208600] usbcore: registered new interface driver cdc_ncm
[ 1.214166] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.220854] s5p-ehci s5p-ehci: S5P EHCI Host Controller
[ 1.225865] s5p-ehci s5p-ehci: new USB bus registered, assigned bus number 1
[ 1.232949] s5p-ehci s5p-ehci: irq 87, io mem 0xec200000
[ 1.244491] s5p-ehci s5p-ehci: USB 0.0 started, EHCI 1.00
[ 1.249062] hub 1-0:1.0: USB hub found
[ 1.252180] hub 1-0:1.0: 1 port detected
[ 1.256414] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.262319] s5p-ohci s5p-ohci: EXYNOS OHCI Host Controller
[ 1.267680] s5p-ohci s5p-ohci: new USB bus registered, assigned bus number 2
[ 1.274694] s5p-ohci s5p-ohci: irq 87, io mem 0xec300000
[ 1.339114] hub 2-0:1.0: USB hub found
[ 1.341408] hub 2-0:1.0: 1 port detected
[ 1.345670] Initializing USB Mass Storage driver...
[ 1.350333] usbcore: registered new interface driver usb-storage
[ 1.356243] USB Mass Storage support registered.
[ 1.360875] s3c-udc : S3C HS USB Device Controller Driver, (c) 2008-2009 Samsung Electronics
[ 1.360881] s3c-udc : version 15 March 2009 (DMA Mode)
[ 1.377322] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.382766] android_usb gadget: Number of LUNs=1
[ 1.387372] lun0: LUN: removable file: (no medium)
[ 1.392546] android_usb gadget: android_usb ready
[ 1.415596] Registered gadget driver 'android_usb'
[ 1.419288] mousedev: PS/2 mouse device common for all mice
[ 1.424840] input: gpio-keys as /devices/platform/gpio-keys.0/input/input0
[ 1.431958] tp_power_ft5x06 1
[ 2.394485] [FTS] ft5x0x_ts_probe, driver version is 2.0.
[ 2.398568] msg ft5x0x_read_reg i2c read error: -6
[ 2.403221] ==singlethread error =
[ 2.406673] ==ft5x0x_ts_init 0==
[ 2.410165] S3C24XX RTC, (c) 2004,2006 Simtec Electronics
[ 2.415217] s3c-rtc s3c64xx-rtc: rtc disabled, re-enabling
[ 2.421114] using rtc device, s3c, for alarms
[ 2.424809] s3c-rtc s3c64xx-rtc: rtc core: registered s3c as rtc0
[ 2.431117] i2c /dev entries driver
[ 2.435437] lirc_dev: IR Remote Control driver registered, major 251
[ 2.440905] IR NEC protocol handler initialized
[ 2.445401] IR RC5(x) protocol handler initialized
[ 2.450147] IR RC6 protocol handler initialized
[ 2.454649] IR JVC protocol handler initialized
[ 2.459144] IR Sony protocol handler initialized
[ 2.463746] IR RC5 (streamzap) protocol handler initialized
[ 2.469295] IR LIRC bridge handler initialized
[ 2.473710] Linux video capture interface: v2.00
[ 2.478393] mfc_init: <6>S5PC110 MFC Driver, (c) 2009 Samsung Electronics
[ 2.478398]
[ 2.487125] S3C JPEG Driver, (c) 2007 Samsung Electronics
[ 2.491986] JPEG driver for S5PV210
[ 2.495827] i2c i2c-1: attached s5p_ddc into i2c adapter successfully
[ 2.501918] S5PC11X HPD Driver, (c) 2010 Samsung Electronics
[ 2.507683] s5p_hpd_irq_handler: HDMI OFF ++++++++++
[ 2.513161] S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
[ 2.518539] s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
[ 2.526150] sdhci: Secure Digital Host Controller Interface driver
[ 2.532063] sdhci: Copyright(c) Pierre Ossman
[ 2.536429] s3c-sdhci s3c-sdhci.0: clock source 0: hsmmc (133400000 Hz)
[ 2.542967] s3c-sdhci s3c-sdhci.0: clock source 2: sclk_mmc (47642857 Hz)
[ 2.549880] mmc0: SDHCI controller on samsung-hsmmc [s3c-sdhci.0] using ADMA
[ 2.556795] s3c-sdhci s3c-sdhci.1: clock source 0: hsmmc (133400000 Hz)
[ 2.563328] s3c-sdhci s3c-sdhci.1: clock source 2: sclk_mmc (80000000 Hz)
[ 2.571284] mmc1: SDHCI controller on samsung-hsmmc [s3c-sdhci.1] using ADMA
[ 2.577148] s3c-sdhci s3c-sdhci.2: clock source 0: hsmmc (133400000 Hz)
[ 2.583692] s3c-sdhci s3c-sdhci.2: clock source 2: sclk_mmc (47642857 Hz)
[ 2.590616] mmc2: SDHCI controller on samsung-hsmmc [s3c-sdhci.2] using ADMA
[ 2.597528] s3c-sdhci s3c-sdhci.3: clock source 0: hsmmc (133400000 Hz)
[ 2.605096] s3c-sdhci s3c-sdhci.3: clock source 2: sclk_mmc (80000000 Hz)
[ 2.612954] mmc3: SDHCI controller on samsung-hsmmc [s3c-sdhci.3] using ADMA
[ 2.619330] usbcore: registered new interface driver usbhid
[ 2.624115] usbhid: USB HID core driver
[ 2.628441] logger: created 256K log 'log_main'
[ 2.632624] logger: created 256K log 'log_events'
[ 2.640326] logger: created 256K log 'log_radio'
[ 2.643650] logger: created 256K log 'log_system'
[ 2.649606] Error: Driver 'samsung-audio' is already registered, aborting...
[ 2.655494] wm8960-codec 1-001a: No platform data supplied
[ 2.681174] mmc0: new high speed MMC card at address 0001
[ 2.685371] mmcblk0: mmc0:0001 SEM04G 3.68 GiB
[ 2.689679] mmcblk0boot0: mmc0:0001 SEM04G partition 1 1.00 MiB
[ 2.695567] mmcblk0boot1: mmc0:0001 SEM04G partition 2 1.00 MiB
[ 2.703946] mmcblk0: p1 p2 p3 p4
[ 2.708576] mmcblk0boot1: unknown partition table
[ 2.713092] mmcblk0boot0: unknown partition table
[ 2.800682] asoc: wm8960-hifi <-> samsung-i2s.0 mapping ok
[ 2.808511] asoc: wm8960-hifi <-> samsung-i2s.0 mapping ok
[ 2.815090] ALSA device list:
[ 2.818581] #0: SMDK-I2S
[ 2.819942] Netfilter messages via NETLINK v0.30.
[ 2.824601] nf_conntrack version 0.5.0 (6110 buckets, 24440 max)
[ 2.830978] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 2.837448] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 2.844690] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.848699] arp_tables: (C) 2002 David S. Miller
[ 2.853197] TCP cubic registered
[ 2.857318] NET: Registered protocol family 10
[ 2.862988] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.867146] IPv6 over IPv4 tunneling driver
[ 2.872739] NET: Registered protocol family 17
[ 2.875795] mmc2: new SDHC card at address 1234
[ 2.880380] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 2
[ 2.888003] mmcblk1: mmc2:1234 SA08G 7.28 GiB
[ 2.893584] s3c-rtc s3c64xx-rtc: setting system clock to 2000-01-01 00:05:04 UTC (946685104)
[ 2.900762] mmcblk1: p1
[ 2.905318] FIMC0 registered successfully
[ 2.909212] FIMC1 registered successfully
[ 2.913168] FIMC2 registered successfully
[ 2.916980] S5PC1XX TVOUT Driver, (c) 2009 Samsung Electronics
[ 2.921971] s5p-tvout s5p-tvout: hpd status is cable removed
[ 2.937028] Freeing init memory: 168K
[ 2.952361] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 3.204130] init: cannot open '/initlogo.rle'
[ 3.237589] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
[ 3.246991] EXT4-fs (mmcblk0p2): recovery complete
[ 3.250329] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.293987] EXT4-fs (mmcblk0p3): warning: checktime reached, running e2fsck is recommended
[ 3.304518] EXT4-fs (mmcblk0p3): recovery complete
[ 3.310048] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 3.365807] EXT4-fs (mmcblk0p4): warning: checktime reached, running e2fsck is recommended
[ 3.374104] EXT4-fs (mmcblk0p4): recovery complete
[ 3.378826] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[ 3.411210] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 3.423951] init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead
[ 3.433888] init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead
[ 3.442708] init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead
[ 3.452465] android_usb: already disabled
[ 3.456264] init: using deprecated syntax for specifying property 'sys.usb.config', use ${name} instead
[ 3.467110] adb_open
[ 3.468534] adb_bind_config
[ 3.471207] init: using deprecated syntax for specifying property 'sys.usb.config', use ${name} instead
[ 3.480049] android_work: did not send uevent (0 0 (null))
/system/bin/sh: No controlling tty (open /dev/tty: No such device or address)
/system/bin/sh: warning: won't have full job control
[ 3.633208] android_work: sent uevent USB_STATE=CONNECTED
[ 3.722877] android_usb gadget: high speed config #1: android
[ 3.729546] android_work: sent uevent USB_STATE=CONFIGURED
root@android:/ # [ 3.793242] PVR_K:(Warning): SysFinalise: Version string: SGX540 S5PC110 [543, drivers/gpu/pvr/s5pc110/sysconfig.c]
[ 5.051663] win->id=0, pmem_start=0x4bef7000
[ 5.051681] s3cfb s3cfb: [fb0] dma: 0x4bef7000, cpu: 0xf3000000, size: 0x00465000
[ 5.073122] s3cfb s3cfb: [fb1] dma: 0x49400000, cpu: 0xffa00000, size: 0x002ee000
[ 5.082101] pmem: request for physical address of pmem region from process 2018.
[ 13.986626] warning: `zygote' uses 32-bit capabilities (legacy support in use)
[ 17.295824] request_suspend_state: wakeup (3->0) at 17291430259 (2000-01-01 00:05:18.898522444 UTC)
[ 17.489534] dm9000 dm9000.0: eth0: link down
[ 17.493726] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.657728] acc_open
[ 17.658452] acc_release
[ 34.835886] EXT4-fs error (device mmcblk0p2): ext4_readdir:214: inode #895: block 31669: comm MediaScannerSer: path /system/media/audio/ui: bad entry in directory: directory entry across blocks - offset=0(0), inode=9127168, rec_len=17664, name_len=139
[ 34.858948] Aborting journal on device mmcblk0p2-8.
[ 34.863729] EXT4-fs (mmcblk0p2): Remounting filesystem read-only
[ 71.789793] init: untracked pid 2930 exited
[ 83.072318] request_suspend_state: sleep (0->3) at 83067997969 (2000-01-01 00:06:24.675089987 UTC)
