2153|0
 /*******´®ÐÐÊý¾ÝÔËÓõÄʵÑé*****        */
#include
#include   //_nop_()ÒýÓÃ
#define uint unsigned int
#define uchar unsigned char
unsigned  int dsp_send,cont_send,temp,lo,km;
uchar  cont_tr;
uint  cont_fe;
uchar cont_urat, dsp_contr,dsp_modn,aa,bai,shi,ge,ge,com_js,conk,key;//??5?????
bit number_sys=0;
sbit dulb=P2^6;
sbit duls=P2^7;
sbit dulg=P3^7 ;
#define  bdata flag;
sbit cufa=P2^2;
sbit zhen=P2^1;
sbit fan= P2^0;
sbit key_cont=P2^5;
sbit dxbh_jb  = P2^3;
sbit ua_indata =P1^7;  //74HC595-14        sdA        ´®ÐÐÊäÈë
sbit st_cp_data =P1^6;  //74hc595-12 SLCK Ëø´æÆ÷ʱÖÓ ¸ßµçƽÓÐЧ
sbit sh_cp_data =P1^5;  //74HC595-11 SCLK ¼Ä´æÆ÷Ëø´æʱÖÓ        ¸ßµçƽÓÐЧ
sbit mr_re_data =P1^4;  //74HC595-10          CLR ¼Ä´æÆ÷¸´Î»  µÍµçƽÓÐЧ
sbit oe_ontcontre_data =P1^3; //74HC595-13 ¸ßµçƽΪÎÞÊä³ö¸ß×è̬£¬µÍµçƽʱQ1-Q7ÓÐÊä³öÖµ
sfr ISP_DATA  = 0xe2;
sfr ISP_ADDRH = 0xe3;
sfr ISP_ADDRL = 0xe4;
sfr ISP_CMD   = 0xe5;
sfr ISP_TRIG  = 0xe6;
sfr ISP_CONTR = 0xe7;
sfr AUXR=0X8E;
sfr WDT_CONTR=0Xe1;   //¿´ÃŹ·           85D           D5 N         61 E
sfr P1M0=0x91;
sfr P1M1=0x92;
sfr P3M0=0XB1;
sfr P3M1=0XB2;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
0x07,0x7f,0x6f,0x5f,0x7c,0x58,0x5e,0x7b,0x71,0x00,0x40};
void display_data (uchar bai,uchar shi,uchar ge) ;
void key_contme (void);
void init();
void delay(uint);
void delay(uint boms)
    uint froma,lites; //Âýµã¿ÉÒÔ¿´Ç幤×÷¹ý³Ì
    for(froma=130;froma>0;froma--)
          for(lites=boms;lites>0;lites--);
//·¢ËÍÏÔʾ//
void display(uint datal)
    uchar b;
    for(b=0;b<8;b++)
       st_cp_data=0;        //ÔÚÊý¾Ýµ½À´Ö®Ç°ÏÈÀ´Ò»¸öµÍµçƽ
       sh_cp_data=0;  //ÔÚÊý¾Ýµ½À´Ö®Ç°ÏÈÀ´Ò»¸öµÍµçƽ
       if(datal&0x80)          //Èç¹ûÊÕµ½µÄÊý¾ÝÓë-0x8000ÏàÓë µÄ½á¹ûΪ1/        1000 0000
                    ua_indata=1;
       else
                    ua_indata=0;
                datal<<=1; //½«ÊÕµ½µÄÊý¾ÝÏò×óÒƶ¯Ò»Î»ºó¼Ä´æµ½datalÖР ´ËʱµÄdatalµÄÖµÊǵÈÓÚ½øÐÐÒÆλºóµÄÖµÁË,ÿ×óÒÆÒ»´ÎºóÓұߵÄ0¿ªÊ¼Ôö¶à
                 //ai_esp_datal();//°ÑÊÕµ½µÄOºÍ1½øÐÐÖØл¹Ô­ÎªÔ­ÓÐÊý¾Ý
                sh_cp_data=1;  //Ëø´æµ½¼Ä´æ÷
        st_cp_data=1;   //Ëø´æס
          return         ;
void main(void)
  uint x,y;
     init();
         for(x=0;x<18;x++)
           y++;
           display_data(table[y],table[y],table[y]);
        while(1)
         if(!cufa)
           cont_send=30000;
            while((!cufa)&&(--cont_send));
                   ge++;
                    display_data(17,17,17);
           key_contme();
          else
                     display_data(ge,shi,bai);
void timer0() interrupt 1//???0????
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        aa++;
        if(aa==20) //1s
                    aa=0;
                        temp++;
                      if(temp==dsp_send)
                         zhen=0;
                    if(temp==cont_urat)
                             zhen=1;
                          if(temp==dsp_contr)
                                 fan=0;
                         if(temp==dsp_modn)
                             fan=1;
                          if(temp>=dsp_modn==134)display_data(17,17,17);
                        if(temp==134) {TR0=0;TR1=0;EA=0;        }
                           bai=temp/100;
                   shi=temp%100/10;
                   ge=temp%10;
void init()//?????,
    cont_send=300;
    dsp_send=0;
           temp=0;
          TMOD=0x11;
    cont_urat=ua_indata=0;
        km=0;
        lo=0;
        EA=0;
        ET0=1;
        TR0=0;
        IT0=1;
        dulg=1;
        duls=1;
        dulb=1;
void display_data (uchar ge,uchar shi,uchar bai )
    display(table[shi]);
        dulg=0;
        delay(50); //ÉÁ˸¸ÐºÍÁÁ¶È£¬
        dulg=1;
        delay(20);//µÈ´ýÊý¾ÝÈ«²¿·¢ËÍÍê
   display(table[ge]);
        duls=0;
        delay(50);
    duls=1;
        delay(20);        //ÏûÒþ
   display(table[bai]);
        dulb=0;
    delay(50);
        dulb=1;
        delay(20);
  if((cufa==0)&&(number_sys==0))
            delay(10);
           if(!cufa);delay(10);
           if(!cufa)//°´Ïºó¾Í¿ªÊ¼¼ÆÊý£¬È·¶¨°´Ï¼üµÄʱ¼ä³¤Óë¶Ì
                    TR0=0;
                        TR1=0;
                        EA=0;
                   cont_send=300;
                   while((!cufa)&&(--cont_send));//  Á½±ßµÄÌõ¼þÏàͬʱ£¬ÈçËÉ¿ªÊÖÁË£¬Í¬Ê±DSP_SEND»¹Ã»ÓÐΪ0.»òÕß°´¼ü°´ÏÂÖУ¬DSP£ßSEND¼õÍêΪ£°ÁË
                           delay(100); //300X100=30000MS
                           delay(200);
                        if(cont_send)//°´¼üÄ©³¬¹ýÈýÃ룮ֻÊDzÙ×÷ÕßÌáÇ°ËÉÊÖÁË
                           temp++;
                   dsp_send++;
                           cont_urat=dsp_send+10;
                           dsp_contr=20+cont_urat;
                           dsp_modn=dsp_contr+10;
                                else
                                    TR0=1;
                                    TR1=1;
                                    EA=1;
                                    delay(200);
                                    aa=0;
                                    temp=0;
                   number_sys=0;
上面的代码,原想在按下键以后,显示___线,再进入正常显示状态,可是得到的却是另外一个结果.望高人修正一下.
   三片74HC595串行显示计数值,当按照 个位,十位,百位的顺序进行发送数据发现;个位的显示却跑到十位的位置上来显示,调整无效果,线路连接也没问题,单独测试个位,十位,百位的连线没问题,可以单独控制显示个位,十位,百位,三个位都正常.最后所以找不到原因,
【TI有奖直播报名中】
直播时间:4月24日(周四)上午10:00
直播奖励:好礼等您拿!
