5474|10
跪求G2553多路ADC转换程序或指导!谢谢各位大虾! [复制链接]
 用launch pad做去年TI电设控制类题目,遇到了点问题 希望各位慷慨帮助,在此谢过.....
ti 专用的例子在哪里可以下载?  详情 回复 发表于 2012-11-30 16:09
5014
裸片初长成(初级)
//   MSP430G2x33/G2x53 Demo - ADC10, DTC Sample A1-0 16x, AVcc, Repeat Seq, DCO
//  Description: Use DTC to sample A1/A0 repeat sequence 16x(32 total samples)
//  with reference to AVcc.  Software sets ADC10SC to trigger sample burst.
//  In Mainloop MSP430 waits in LPM0 to save power until ADC10 conversion
//  complete, ADC10_ISR will force exit from any LPMx in Mainloop on reti.
//  ADC10 internal oscillator times sample period (16x) and conversion (13x).
//  DTC transfers conversion code to RAM 200h - 240h.  ADC10(DTC) interrupt
//  will return system active. P1.0 set at start of conversion burst, reset
//  on completion.
//        /|\|              XIN|-
//         --|RST          XOUT|-
//       >---|P1.1/A1          |
//       >---|P1.0/A0          |
//  D. Dang
//  Texas Instruments Inc.
//  December 2010
//   Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
#include  "msp430g2553.h"
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  ADC10CTL1 = INCH_1 + CONSEQ_3;            // A1/A0, repeat multi channel
  ADC10CTL0 = ADC10SHT_2 + MSC + ADC10ON + ADC10IE;
  ADC10AE0 = 0x03;                          // P1.0,1 ADC option select
  ADC10DTC1 = 0x20;                         // 16 conversions
  for (;;)
    ADC10CTL0 &= ~ENC;
    while (ADC10CTL1 & BUSY);               // Wait if ADC10 core is active
    ADC10SA = 0x200;                        // Data buffer start
    ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion ready
    __bis_SR_register(CPUOFF + GIE);        // LPM0, ADC10_ISR will force exit
    _NOP();                                 // space for debugger
    _NOP();                                 // Set Breakpoint here to read ADC
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR (void)
  __bic_SR_register_on_exit(CPUOFF);        // Clear CPUOFF bit from 0(SR)
ADC设置成多通道多次转换后,ADC中断是在各个通道完成后中断吗? Data Transfer Control Register0 和1 也就是ADC10DTC0 和1 控制的是什么功能,是将转换结果写入RAM吗? 数据手册中说的block是什么意思也不懂  详情 回复 发表于 2012-7-2 21:56
437
TI  有专门的范例程序~
谢谢你,例程我看了 不太懂,例程是多通道将结果写入RAM,我不知道怎么读取 求指点 谢谢!  详情 回复 发表于 2012-7-2 21:58
回复 沙发 wstt 的帖子
Data Transfer Control Register0 和1 也就是ADC10DTC0 和1  控制的是什么功能,是将转换结果写入RAM吗?    数据手册中说的block是什么意思也不懂,这段代码我看过,没看太懂,如果版主有时间看看我下来这些问题,只看英文数据手册没例程没人指导太蛋疼了!  谢谢版主帮助!
回复 板凳 juring 的帖子
碰到同样的问题,求大神指点!
就是不晓得怎么把数据读出来:)  详情 回复 发表于 2012-7-26 20:48
回复 6楼 hxunan 的帖子
就是不晓得怎么把数据读出来
22
看看这个
https://bbs.eeworld.com.cn/thread-340360-1-1.html
楼主,看看这个帖子,那位大哥讲的很明白了,反正我是看懂他讲的了,希望可以对你有些帮助
O(∩_∩)O谢谢了。终于搞明白了。O(∩_∩)O哈哈~  详情 回复 发表于 2012-7-27 09:49
87
回复 8楼 lixuan9980 的帖子
23
我也同样不懂,
ti 专用的例子在哪里可以下载?
