3143|0
294
Keithley's 2651A Get Breakthrough Capabilities and Unmatched Performance [复制链接]
Keithley’s Model 2651A High Power System SourceMeter® Instrument lets you
characterize and test today’s challenging high power electronics with unprecedented power,
precision, speed, flexibility, and ease of use. This newest member of Keithley’s popular Series
2600A family of System SourceMeter instruments improves productivity in applications
across R&D, reliability, and production environments testing power semiconductors, LEDs,
materials, and other high power devices.
Source or sink:
2,000W of pulsed power (±40V, ±50A)
200W of DC power (±10V@ ±20A,±20V@ ±10A, ±40V@ ±5A)
Easily connect two units, in series or
parallel, to create solutions up to±100A or ±80V
1pA current resolution ensures precise
measurements of very low leakage currents
1μV voltage resolution (and current
sourcing up to 50A) enables low-level
Rds measurements to support next generation devices
Combines the functionality of all these instruments in one compact box (2U high):
Semiconductor characterization instrument
V or I waveform generator
V or I pulse generator
Precision power supply
True current source
Digital multimeter (DCV, DCI, ohms,and power with 5½-digit resolution)
Electronic load
Trigger controller
Keithley's Chinese Website: http://www.keithley.com.cn/products
