2196|0
能不能帮忙看一下这个程序有什么错误 [复制链接]
键盘不能控制pwm波,数码管显示也不明显,我4个端口都用完了,能用p3口连接矩阵键盘吗 头文件内容 #include #include #define uchar unsigned char uchar code Matrix_Keyboard[]={0xf7,0xfb,0xfd,0xfe}; void delay_1ms(void) //1ms延时函数 { unsigned int i; for (i=0;i<1140;i++); } void delay_nms(unsigned int n) //N ms延时函数 { unsigned int i=0; for (i=0;i> 4) { case 0x07: return loop_key*4+0; case 0x0b: return loop_key*4+1; case 0x0d: return loop_key*4+2; case 0x0e: return loop_key*4+3; } } } //5ms去抖 return 16; //表示无输入 } .c文件内容 //PWM控制LED的亮度,渐灭到渐亮 #include #include"readkey.h" #define uchar unsigned char uchar keynum=16; uchar code SEG7[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; uchar code ACT[8]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe}; void mdelay(unsigned int m); ///m*1ms的延时子程序 void disp( unsigned char i ,uchar num); ///显示子函数,在第i个数码管显示内容是num void xianshi(void);////显示主函数。 int high; unsigned int i=0; unsigned int number; unsigned char number1,number2,number3,number4; void t0(void)interrupt 1 /////////////定时器0中断程序 { TH0=0xff; TL0=0xbd; i++; if(i0;m--) { for(r=0;r<124;r++) {;} } } void disp( unsigned char i ,uchar num) ////在第i个数码管显示内容是num { switch(i) { case 1:P1=ACT[7]; P0=SEG7[num]; mdelay(1); break; case 2:P1=ACT[6]; P0=SEG7[num]; mdelay(1); break; case 3:P1=ACT[5]; P0=SEG7[num]; mdelay(1); break; case 4:P1=ACT[4]; P0=SEG7[num]; mdelay(1); break; } } void xianshi(void) { disp(1,number1); disp(2,number2); disp(3,number3); disp(4,number4); }
此帖出自电子竞赛论坛
