3714|5
78
各位大虾 帮忙看一下这个4*4键盘扫描程序有什么问题 在此谢过 [复制链接]
int keyscan()
P0=0x0f;
if(P0&0x0f!=0x0f)
      delay();
   P04=0;
   P05=1;
   P06=1;
   P07=1;
   if(P0!=0xef)
    lie=1;
    switch(P0)
    case 0xee:
     hang=1;
     break;
    case 0xed:
     hang=2;
    case 0xeb:
     hang=3;
    case 0xe7:
     hang=4;
    default:
     break;
   P04=1;
   P05=0;
   P06=1;
   P07=1;
   if(P0!=0xdf)
    lie=2;
    switch(P0)
    case 0xde:
     hang=1;
     break;
    case 0xdd:
     hang=2;
     break;
    case 0xdb:
     hang=3;
     break;
    case 0xd7:
     hang=4;
     break;
    default:
     break;
   P04=1;
   P05=1;
   P06=0;
   P07=1;
   if(P0!=0xbf)
    lie=3;
    switch(P0)
    case 0xbe:
     hang=1;
     break;
    case 0xbd:
     hang=2;
     break;
    case 0xbb:
     hang=3;
     break;
    case 0xb7:
     hang=4;
     break;
    default:
     break;
   P04=1;
   P05=1;
   P06=1;
   P07=0;
   if(P0!=0x7f)
    lie=4;
    switch(P0)
    case 0x7e:
     hang=1;
     break;
    case 0x7d:
     hang=2;
     break;
    case 0x7b:
     hang=3;
     break;
    case 0x77:
     hang=4;
     break;
    default:
     break;
    a[0]=hang;
    a[1]=lie;
    return a;
  else
   return 0;
谢过了,呵呵。。。。  详情 回复 发表于 2009-11-8 19:17
77
写得太复杂;了
65
哥,你这程序毛病一大堆的啊
#include
#define uint unsigned int
#define uchar unsigned char
sbit dula=P2^6;
sbit wela=P2^7;
sbit key1=P3^4;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0};
uchar num,temp,num1;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
uchar keyscan();
void display(uchar aa);
void main()
        num=17;
        dula=1;
        P0=0;
        dula=0;
        wela=1;
        P0=0xc0;
        wela=0;
        while(1)
                        display(keyscan());
                        dula=1;
                        P0=table[aa-1];
                        dula=0;
uchar keyscan()
                        P3=0xfe;
                        temp=P3;
                        temp=temp&0xf0;
                        while(temp!=0xf0)
                                        delay(5);
                                        temp=P3;
                                        temp=temp&0xf0;
                                        while(temp!=0xf0)
                                                temp=P3;
                                        switch(temp)
                                                        case 0xee:num=1;
        break;
                                                        case 0xde:num=2;
        break;
                                                        case 0xbe:num=3;
        break;
                                                        case 0x7e:num=4;
        break;
                                        while(temp!=0xf0)
                                                        temp=P3;
                                                        temp=temp&0xf0;
                        P3=0xfd;
                        temp=P3;
                        temp=temp&0xf0;
                        while(temp!=0xf0)
                                        delay(5);
                                        temp=P3;
                                        temp=temp&0xf0;
                                        while(temp!=0xf0)
                                                temp=P3;
                                        switch(temp)
                                                        case 0xed:num=5;
        break;
                                                        case 0xdd:num=6;
        break;
                                                        case 0xbd:num=7;
        break;
                                                        case 0x7d:num=8;
        break;
                                        while(temp!=0xf0)
                                                        temp=P3;
                                                        temp=temp&0xf0;
                        P3=0xfb;
                        temp=P3;
                        temp=temp&0xf0;
                        while(temp!=0xf0)
                                        delay(5);
                                        temp=P3;
                                        temp=temp&0xf0;
                                        while(temp!=0xf0)
                                                temp=P3;
                                        switch(temp)
                                                        case 0xeb:num=9;
        break;
                                                        case 0xdb:num=10;
        break;
                                                        case 0xbb:num=11;
        break;
                                                        case 0x7b:num=12;
        break;
                                        while(temp!=0xf0)
                                                        temp=P3;
                                                        temp=temp&0xf0;
                        P3=0xf7;
                        temp=P3;
                        temp=temp&0xf0;
                        while(temp!=0xf0)
                                        delay(5);
                                        temp=P3;
                                        temp=temp&0xf0;
                                        while(temp!=0xf0)
                                                temp=P3;
                                        switch(temp)
                                                        case 0xe7:num=13;
        break;
                                                        case 0xd7:num=14;
        break;
                                                        case 0xb7:num=15;
        break;
                                                        case 0x77:num=16;
        break;
                                        while(temp!=0xf0)
                                                        temp=P3;
                                                        temp=temp&0xf0;
return num;
仔细参考下这个程序。你的程序真的是一大堆错误。
75
#include
unsigned char temp;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,
0x39,0x5e,0x79,0x71};
void delay_10ms()                         /*延时10MS*/
        unsigned char i,j,k;
        for(i=0;i<2;i++)
                for(j=0;j<20;j++)
                        for(k=0;k<248;k++);
void scanf(unsigned char key) /*LED扫描与显示*/
        switch(key)
                case 0xe7:P0=0x3f;break;
                case 0xeb:P0=0x06;break;
                case 0xed:P0=0x5b;break;
                case 0xee:P0=0x4f;break;
                case 0xd7:P0=0x66;break;
                case 0xdb:P0=0x6d;break;
                case 0xdd:P0=0x7d;break;
                case 0xde:P0=0x07;break;
                case 0xb7:P0=0x7f;break;
                case 0xbb:P0=0x6f;break;
                case 0xbd:P0=0x77;break;
                case 0xbe:P0=0x7c;break;
                case 0x77:P0=0x39;break;
                case 0x7b:P0=0x5e;break;
                case 0x7d:P0=0x79;break;
                case 0x7e:P0=0x71;break;
                default:  P0=0x00;break;
void control(temp)                        /*确定哪个健按下啊*/
{        temp=temp&0x0f;
                        if( temp!=0x0f)
                                delay_10ms();
                                if( temp!=0x0f)
                                        scanf(P3);
                                        while(temp!=0x0f)
                                                         temp=P3;
                                                        temp=temp&0x0f;
void main()
        unsigned char a;
                while(1)
                                 P3=0xff;
                                P3_4=0;                           //确定行
                                a=P3;
                                control(a);
                                P3=0xff;
                                P3_5=0;
                                a=P3;
                                control(a);
                                P3=0xff;
                                P3_6=0;
                                a=P3;
                                control(a);
                                P3=0xff;
                                P3_7=0;
                                a=P3;
                                control(a);
自己写的,参考下
谢过了,呵呵。。。。
