6402|21
473
C结构体指针问题 [复制链接]
#include
void out(struct person *t)
printf("%-10s%2c%4d%7.1f\n",t->name,t->sex,t->age,t->height);
void main()
struct person
char name[20];
char sex;
int age;
float height;
}s[3]={{"yiyi",'g',3,100},{"zhujina",'m',30,180},{"weijing",'g',29,164}};
struct person *p;
for(p=s;p out( p);
Compiling...
6.cpp
C:\Documents and Settings\Administrator\桌面\C\11\6.cpp(4) : error C2027: use of undefined type 'person'
  C:\Documents and Settings\Administrator\桌面\C\11\6.cpp(2) : see declaration of 'person'
C:\Documents and Settings\Administrator\桌面\C\11\6.cpp(4) : error C2227: left of '->name' must point to class/struct/union
C:\Documents and Settings\Administrator\桌面\C\11\6.cpp(4) : error C2227: left of '->sex' must point to class/struct/union
C:\Documents and Settings\Administrator\桌面\C\11\6.cpp(4) : error C2227: left of '->age' must point to class/struct/union
C:\Documents and Settings\Administrator\桌面\C\11\6.cpp(4) : error C2227: left of '->height' must point to class/struct/union
C:\Documents and Settings\Administrator\桌面\C\11\6.cpp(17) : error C2664: 'out' : cannot convert parameter 1 from 'struct main::person *' to 'struct person *'
  Types pointed to are unrelated; conversion requires reinterpret_cast, C-style cast or function-style cast
Error executing cl.exe.
6.exe - 1 error(s), 0 warning(s)
这问题错在哪,我是安照书上写的
编程很厉害啊!  详情 回复 发表于 2011-5-4 10:29
2749
裸片初长成(初级)
试试把下面结构体定义放到函数外面:
struct person
char name[20];
char sex;
int age;
float height;
main函数里写成:
struct person s[3]={{"yiyi",'g',3,100},{"zhujina",'m',30,180},{"weijing",'g',29,164}};
2498
至上芯片
for(p=s;p out( p);
也有点问题哟~~~~,貌似不和语法~
个人签名我的邮箱gaoxiaoan123@163.com!回帖是一种美德!互相帮助,共同进步!
口头禅:生活在于创造机会,把握机会!
256
回复 楼主 zjjone1023 的帖子
for(p=s;p out( p);
应该改成for(p=s;p++;p!='\0' )out( p);
还有struct person应先声明后引用,因而在void out ()之前就声明该数据结构
个人签名追求卓越,成功就会在不经意间追上你
2130
楼上说到点上了
6066
90
裸片初长成(初级)
  1. #include <stdio.h>
    #include <stdlib.h>
    struct person
    char name[20];
    char sex;
    int age;
    float height;
    int main()
    struct person *p;
    p = s;
    out(p);
    while(1);
    //for(p=s;p++;p!='\0' )out( p);
    return 0;
复制代码
你的程序不全,所以主函数中为你用while一直在循环。
我的这个在GCC下CODEBLOCK下编译通过。
就像楼上说的,out函数中用到了结构体,可是没有申明。结构体的定义放在最前面。
6066
90
裸片初长成(初级)
书上的例程写成这样。。这书就有点尴尬了。
6066
90
裸片初长成(初级)
原帖由 孤独剑 于 2011-5-2 19:31 发表 for(p=s;p out( p); 应该改成for(p=s;p++;p!='\0' )out( p); 还有struct person应先声明后引用,因而在void out ()之前就声明该数据结构
这里p怎么也不会等于‘\0’吧
2130
原帖由 maylove 于 2011-5-2 22:16 发表 for(p=s;p++;p!='\0' )这里p怎么也不会等于‘\0’吧
呵呵呵,应该是(*P) != '\0'
6066
90
裸片初长成(初级)
原帖由 leang521 于 2011-5-2 22:48 发表 呵呵呵,应该是(*P) != '\0'
(*p)也不会吧..不太明白这个判断有什么用.
(*p)最多也只是指向结构做的第一个元素的第一个字母
2130
从他的代码看应该是判断结构体结束的。当然这个代码很多问题,这样做是否可靠也要斟酌
473
谢谢各位了,2\4楼说对了,应该是把结构体放在前面另外那个循环我没有贴全,应该是for(p=s;p<s+3;p++)out (p)
我已经改过而且结果正确了,程序如下
#include<stdio.h>
struct person
char name[20];
char sex;
int age;
float height;
void main()
/*struct person
char name[20];
char sex;
int age;
float height;
//struct person s[3]={{"yiyi",'g',3,100},{"zhujina",'m',30,180},{"weijing",'g',29,164}};
struct person *p;
for(p=s;p<s+3;p++) out( p);
[ 本帖最后由 zjjone1023 于 2011-5-3 08:57 编辑 ]
473
有时候别人给个提示很快就能解决问题,我看书看了半天也没有看出哪不对,书上没有说过要放前面晕
5968
哇 maylove 真牛气
个人签名生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙
做一个简单的人,踏实而务实,不沉溺幻想,不庸人自扰
楼主用的是什么编译器啊,这么高难
2130
有些时候认真阅读编译器说明也是必要的。
473
回复 15楼 ddllxxrr 的帖子
我用的是论坛里辛昕给我的Microsoft Visual C++ 6.0,也不知道现在学习用什么好,呵呵
473
回复 16楼 leang521 的帖子
所言甚是
256
这里p怎么也不会等于‘\0’吧 [/quote]
正确的是这样的:
 我查找我们课本了,很确定!
256
回复 17楼 zjjone1023 的帖子
C++去弄几个教学视频看看吧!
【TI有奖直播报名中】
直播时间:4月24日(周四)上午10:00
直播奖励:好礼等您拿!
