4906|3
77
F2812的FLASH烧写成功,奇怪警告让程序没跑起来 [复制链接]
我的F2812仿真正常,烧写FLASH时Erase/Program/Verify Operation succeeded,但是出现了这个警告,结果是程序没有跑起来 “Warning: This program contains initialized RAM data. It may run successfully under Code Composer Studio but not as a standalone system because of this. If your Flash program requires initialized data in RAM, you will need to write Flash code to initialize RAM memory.” 请问高手是什么原因(我用了全局变量)
可能有些程序段还定义在ram中,改一下cmd文件。  详情 回复 发表于 2007-6-14 01:34
是不是把初始化段定位到ram中去了?
61
我得以前也出现国这样的问题,但程序能运行啊 ,
66
