3397|1
569
4X4键盘矩阵代码分享 [复制链接]
module key(
  input         clk,
  input         rst,
  input   [3:0] row,                 // 矩阵键盘 行
  output reg [3:0] col,                 // 矩阵键盘 列
  output reg [6:0] keyboard_val         // 键盘值
// 状态机部分 开始
// 状态编码
parameter NO_KEY_PRESSED = 6'b000_001;  // 没有按键按下
parameter SCAN_COL0      = 6'b000_010;  // 扫描第0列
parameter SCAN_COL1      = 6'b000_100;  // 扫描第1列
parameter SCAN_COL2      = 6'b001_000;  // 扫描第2列
parameter SCAN_COL3      = 6'b010_000;  // 扫描第3列
parameter KEY_PRESSED    = 6'b100_000;  // 有按键按下
//parameter delay          = 6'b111_111;  //延时5ms
reg [5:0] current_state, next_state;    // 现态、次态
reg  key_pressed_flag;          // 键盘按下标志
reg [3:0] col_reg, row_reg;             // 列值、行值
//reg delay_en;       //延时5ms后使能端为1,否则为0
reg [11:0]c0;
//reg [5:0] temp_state;
reg clk0;
always @(posedge clk or negedge rst)
   if(!rst)
     current_state<=NO_KEY_PRESSED;
   else
     current_state<=next_state;
always @(posedge clk0)
begin
     case(current_state)
      NO_KEY_PRESSED:
           if(row!=4'b1111)  next_state=SCAN_COL0;
           else begin next_state=NO_KEY_PRESSED;end
      SCAN_COL0:
         begin
            if(row!=4'b1111)
                  next_state=KEY_PRESSED;
                else next_state=SCAN_COL1;
         end
      SCAN_COL1:
          begin
            if(row!=4'b1111)
                else  next_state=SCAN_COL2;
          end
      SCAN_COL2:
          begin
            if(row!=4'b1111)
                else  next_state=SCAN_COL3;
          end
      SCAN_COL3:
          begin
            if(row!=4'b1111)
                else next_state=NO_KEY_PRESSED;
          end
      KEY_PRESSED:
           if(row!=4'b1111)
     default: next_state=NO_KEY_PRESSED;
    endcase
end
always @ (posedge clk or negedge rst)
begin
  if (!rst)
  begin
    col<= 4'b0000; key_pressed_flag<=0;
  end
  else
    case(next_state)
      NO_KEY_PRESSED:begin col=4'b0000;key_pressed_flag=0;end
      SCAN_COL0:  col=4'b1110;
      SCAN_COL1:  col=4'b1101;
      SCAN_COL2:  col=4'b1011;
      SCAN_COL3:  col=4'b0111;
      KEY_PRESSED: begin
                   col_reg=col;row_reg=row;
                   key_pressed_flag=1;
                   end
    endcase
end
always@(posedge clk0 or negedge rst) begin
    if(!rst) keyboard_val<=7'b0000000;
    else if(key_pressed_flag)
    begin
      case({col_reg,row_reg})
        8'b1110_1110: keyboard_val=7'b1111110; //显示"0"
        8'b1110_1101: keyboard_val=7'b0110011; //显示"4"
        8'b1110_1011: keyboard_val=7'b1111111; //显示"8"
        8'b1110_0111: keyboard_val=7'b1001110; //显示"C"
        8'b1101_1110: keyboard_val=7'b0110000; //显示"1"
        8'b1101_1101: keyboard_val=7'b1011011; //显示"5"
        8'b1101_1011: keyboard_val=7'b1110011; //显示"9"
        8'b1101_0110: keyboard_val=7'b0111101; //显示"d"
        8'b1011_1110: keyboard_val=7'b1101101; //显示"2"
        8'b1011_1101: keyboard_val=7'b1011111; //显示"6"
        8'b1011_1011: keyboard_val=7'b1110111; //显示"A"
        8'b1011_0111: keyboard_val=7'b1001111; //显示"E"
        8'b0111_1110: keyboard_val=7'b1111001; //显示"3"
        8'b0111_1101: keyboard_val=7'b1110000; //显示"7"
        8'b0111_1011: keyboard_val=7'b0011111; //显示"b"
        8'b0111_0111: keyboard_val=7'b1000111; //显示"F"
        default: keyboard_val=7'b0000000;
     endcase
   end
end
always@(posedge clk)
   if(c0<4000)
      c0=c0+1;
   else begin c0=0; clk0=~clk0;end
endmodule
此帖出自FPGA/CPLD论坛
这个不错,copy下来保存先,以后会用到的,谢谢楼主啊。 楼主,这是什么语言的,VHDL?好吧,虽说不怎么常用FPGA,还是先留着吧。 [ 本帖最后由 xiaoding18 于 2010-11-23 14:18 编辑 ]  详情 回复 发表于 2010-11-23 14:17
99
此帖出自FPGA/CPLD论坛
