2722|1
75
求助:NiosII的模拟I2C控制没有应答 [复制链接]
使用NiosII控制高频头CU1216,在NiosII IDE中运行下列程序后,由于没有应答,程序死在Write_I2C_Byte函数的while(I2C_Ackn() );,reset,sda,scl均加了上拉电阻,进行了一些检查均没有结果 ,哪位高手能帮我指点迷津?谢谢。
#include "i2c.h"
#include "system.h"
#include
#include
//***DELAY FUNCTION//
void delay(unsigned int dt)
while(dt>0)
   asm("nop");
   dt--;
   asm("nop");
//***  This routine will reset the I2C bus ***//
void Reset_I2C(void)
    IOWR_ALTERA_AVALON_PIO_DIRECTION(I2C_RESET_BASE, 1);  // Set RESET to output
    IOWR_ALTERA_AVALON_PIO_DATA(I2C_RESET_BASE, 1);   // Set RESET high
    delay(I2C_TIMER);
    IOWR_ALTERA_AVALON_PIO_DATA(I2C_RESET_BASE, 0);   // Set RESET low
    delay(I2C_TIMER);
    delay(I2C_TIMER);
    delay(I2C_TIMER);
    delay(I2C_TIMER);
    delay(I2C_TIMER);
    delay(I2C_TIMER);
    delay(I2C_TIMER);
    delay(I2C_TIMER1);
// *** This routine will setup the I2C Port *** //
void Init_I2C(void)
{          //1 ??
IOWR_ALTERA_AVALON_PIO_DIRECTION(I2C_SCL_BASE, 1);  // Set SCL to output
IOWR_ALTERA_AVALON_PIO_DIRECTION(I2C_SDA_BASE, 1);   // Set SDA to output
IOWR_ALTERA_AVALON_PIO_DATA(I2C_SCL_BASE, 1);    // Set SCL high
delay(I2C_TIMER);
IOWR_ALTERA_AVALON_PIO_DATA(I2C_SDA_BASE, 1);  // Set SDA high
delay(I2C_TIMER);
// *** This routine will send the I2C Start Bit *** //
void I2C_Start (void)
  delay(I2C_TIMER/2);
  IOWR_ALTERA_AVALON_PIO_DATA(I2C_SCL_BASE, 1);     // Set SCL High
  delay(I2C_TIMER);
  IOWR_ALTERA_AVALON_PIO_DATA(I2C_SDA_BASE, 1);      // Set SDA High
  delay(I2C_TIMER);
  IOWR_ALTERA_AVALON_PIO_DATA(I2C_SDA_BASE, 0);       // Clear SDA
  delay(I2C_TIMER);
  delay(I2C_TIMER);
// *** This routine will send the I2C Stop Bit *** //
void I2C_Stop (void)
delay(I2C_TIMER*2);
IOWR_ALTERA_AVALON_PIO_DATA(I2C_SCL_BASE, 0);      // Clear SCL
delay(I2C_TIMER*2);
delay(I2C_TIMER*4);
delay(I2C_TIMER*2);
// *** This routine will write a byte to the I2C device *** //
void Write_I2C_Byte(unsigned char byte)
unsigned int i;
delay(I2C_TIMER);
for (i = 0; i < 8; i++){      // Loop for our 8 bits
   if((byte & 0x80) == 0x80) IOWR_ALTERA_AVALON_PIO_DATA(I2C_SDA_BASE, 1); // Set I2C SDA PIN
   else IOWR_ALTERA_AVALON_PIO_DATA(I2C_SDA_BASE, 0);              // Clear I2C SDA PIN
   delay(I2C_TIMER);
   IOWR_ALTERA_AVALON_PIO_DATA(I2C_SCL_BASE, 1);        // Set SCL High, Clock data
   delay(I2C_TIMER);
   byte = byte << 1;           // Shift data in buffer right one
    delay(I2C_TIMER);
while(I2C_Ackn() );           // Check for acknowledge from I2C device
unsigned char I2C_Ackn(void)
unsigned char Ackn = 0;       // Temp RAM for Ackn flag
   delay(I2C_TIMER/2);
IOWR_ALTERA_AVALON_PIO_DATA(I2C_SCL_BASE, 0);     //  CLEARBIT(I2C_PORT,SCL);
   delay(I2C_TIMER);
IOWR_ALTERA_AVALON_PIO_DIRECTION(I2C_SDA_BASE, 0);    // Set SDA to input
   delay(I2C_TIMER);
IOWR_ALTERA_AVALON_PIO_DATA(I2C_SCL_BASE, 1);    //SETBIT(I2C_PORT,SCL);         // Clock the ACK bit
   delay(I2C_TIMER/2);
if ((IORD_ALTERA_AVALON_PIO_DATA(I2C_SDA_BASE)&0x01)==0x01) Ackn = 1;   // Check the ACK bit on SDA
delay(I2C_TIMER);
//IOWR_ALTERA_AVALON_PIO_DATA(I2C_SCL_BASE, 0);      //CLEARBIT(I2C_PORT ,SCL);         // Clear the clock
return Ackn;            // Return our ACK bit
//***This routine is main fuction***//
void  main()
Reset_I2C();
Init_I2C();            //初始化I2C总线
I2C_Start();           //I2C总线的起始条件
Write_I2C_Byte(0xC0);  //写入控制字ADB,b11000000
Write_I2C_Byte(0x1B);  //写入控制字DB1,b00011011
Write_I2C_Byte(0xF2);  //写入控制字DB2,b11110010
Write_I2C_Byte(0xCE);  //写入控制字CB,b11001110
Write_I2C_Byte(0x04);  //写入控制字BB,b00000100
I2C_Stop ();           //I2C总线的结束条件
程序看似没有问题。 建议你再看看从设备的文档看硬件配置是否正确,然后拿示波器看看波形和预期的是否一致。 供参考.   详情 回复 发表于 2008-8-5 16:55
有奖直播:ADMT4000 掀起多圈编码器设计革命 报名中!
直播时间:5月8日(周四)上午10:00
直播主题:ADMT4000 掀起多圈编码器设计革命
预报从速,好礼等您拿~
