3154|3
54
关于RESERVED_BOOT_BLOCKS的问题,eboot大小256K ,为何只占10块? [复制链接]
问题是这样的,eboot运行起来之后我使用 F) Low-level format the Smart Media card
这时候可以看到DNW打印如下信息
Enter your selection: f
Reserving Blocks [0x0 - 0x11] ...
...reserve complete.
Low-level format Blocks [0x12 - 0xfff] ...
...erase complete.
Reserving Blocks [0x0 - 0x11] 我不理解为什么只保留了前12块。
在代码中追踪,从功能F看起   ,
  1. ...\r\n"), 0, IMAGE_START_BLOCK-1));
  2.                 for (i = 0; i < IMAGE_START_SECTOR; i++) {
  3.                     FMD_WriteSector(i, NULL, &si, 1);
  4.                 }
  5.                 OALMSG(TRUE, (TEXT("...reserve complete.\r\n")));
复制代码
可以看到是IMAGE_START_BLOCK-1 ,继续往下看
loader.h中
  1. #define RESERVED_BOOT_BLOCKS        (NBOOT_BLOCK_SIZE + TOC_BLOCK_SIZE + EBOOT_BLOCK_SIZE)
  2. // Images start after OEM Reserved Blocks
  3. #define IMAGE_START_BLOCK           RESERVED_BOOT_BLOCKS
复制代码
RESERVED_BOOT_BLOCKS就是nboot占块+TOC块+eboot占的块
前面两个好说 , 都是1
  1. #define NBOOT_BLOCK                 0
  2. #define NBOOT_BLOCK_SIZE            1
  3. #define NBOOT_SECTOR                BLOCK_TO_SECTOR(NBOOT_BLOCK)
  4. // TOC @ Block 1
  5. #define TOC_BLOCK                   1
  6. #define TOC_BLOCK_SIZE              1
  7. #define TOC_SECTOR                  BLOCK_TO_SECTOR(TOC_BLOCK)
  8. // Eboot @ Block 2
  9. #define EBOOT_BLOCK                 2
  10. #define EBOOT_SECTOR_SIZE           FILE_TO_SECTOR_SIZE(EBOOT_RAM_IMAGE_SIZE)
  11. #define EBOOT_BLOCK_SIZE            SECTOR_TO_BLOCK(EBOOT_SECTOR_SIZE)
  12. #define EBOOT_SECTOR                BLOCK_TO_SECTOR(EBOOT_BLOCK)
复制代码
eboot占的块是根据eboot大小得来的  EBOOT_RAM_IMAGE_SIZE
这个在上面有定义的   ,一起贴出来
  1. #define EBOOT_RAM_IMAGE_BASE        0x80038000
  2. #define EBOOT_RAM_IMAGE_SIZE        0x00040000
  3. #define EBOOT_STORE_OFFSET          0
  4. #define EBOOT_STORE_ADDRESS         (EBOOT_RAM_IMAGE_BASE + EBOOT_STORE_OFFSET)
  5. #define EBOOT_STORE_MAX_LENGTH      EBOOT_RAM_IMAGE_SIZE
  6. // BinFS work area defined in boot.bib
  7. #define BINFS_RAM_START             (0x80021000 | CACHED_TO_UNCACHED_OFFSET)   // uncached
  8. #define BINFS_RAM_LENGTH            0x5000
  9. //
  10. // Nk Memory reigions defined in config.bib...
  11. //
  12. #define ROM_RAMIMAGE_START          0x80000000
  13. #define ROM_RAMIMAGE_SIZE           0x02000000
  14. #define FILE_CACHE_START            (0x80200000 | CACHED_TO_UNCACHED_OFFSET)        // Start of file cache (temporary store
  15.        // for flash images).
  16. // Driver globals pointer (parameter sharing memory used by bootloader and OS).
  17. //
  18. #define pBSPArgs                    ((BSP_ARGS *) IMAGE_SHARE_ARGS_UA_START)
  19. // Platform "BOOTME" root name.
  20. //
  21. #define PLATFORM_STRING         "SMDK2440"
  22. #ifndef SECTOR_SIZE
  23. #define SECTOR_SIZE                        512
  24. #endif
  25. #ifndef PAGES_PER_BLOCK
  26. #define PAGES_PER_BLOCK             32
  27. #endif
  28. #ifndef BADBLOCKMARK
  29. #define BADBLOCKMARK                0x00
  30. #endif
  31. #ifndef SECTOR_TO_BLOCK
  32. #define SECTOR_TO_BLOCK(sector)     ((sector) >> 5 )
  33. #endif
  34. #ifndef BLOCK_TO_SECTOR
  35. #define BLOCK_TO_SECTOR(block)      ((block)  << 5 )
  36. #endif
复制代码
eboot大小  256K   按他的算   EBOOT_BLOCK_SIZE=256*1024/(32*512)=16 block
那就应该是一共保留18块  ,不知道我哪里算错了  ,   望指教。
汗死.....竟然是这么低级的错误,结贴给分,赶紧沉了。我的个破脑袋哦,昏头了。  详情 回复 发表于 2009-5-9 15:32
82
引用楼主 sphink 的帖子:
0x11 = 17
所以从 0x0 - 0x11 总共 18 块 ...
65
你...........忽略了0x.....
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
第2场直播:融合热仿真与热测试提升产品可靠性
直播时间:04月17日 14:00 - 15:00
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 12
