568|3
107
笙泉MG82F6D17 可以通过MDK配置向导进行MCU的初始化 [复制链接]
初始化简单了,我要在重新修改怎么办
(SC)MG82F6D17_SampleCode_v1.00.zip (15.09 MB, 下载次数: 0)
107
 * [url=home.php?mod=space&uid=1307177]@File[/url] MG82F6D17_UART0_MID.h
 * [url=home.php?mod=space&uid=159083]@brief[/url] This is the C code format driver file.
 * @par         Project
 *              MG82F6D17
 * [url=home.php?mod=space&uid=252314]@version[/url] V1.00
 * [url=home.php?mod=space&uid=311857]@date[/url] 2020/07/10
 * [url=home.php?mod=space&uid=1315547]@author[/url] Megawin Software Center
 * @copyright   Copyright (c) 2020 MegaWin Technology Co., Ltd.
 *              All rights reserved.
 * @par 		Disclaimer
 *		The Demo software is provided "AS IS"  without any warranty, either
 *		expressed or implied, including, but not limited to, the implied warranties
 *		of merchantability and fitness for a particular purpose.  The author will
 *		not be liable for any special, incidental, consequential or indirect
 *		damages due to loss of data or any other reason.
 *		These statements agree with the world wide and local dictated laws about
 *		authorship and violence against these laws.
#ifndef MG82F6D17_UART0_MID_H
#define MG82F6D17_UART0_MID_H
///@cond __DRV_URT0_Easy_Wizard_Init
#define OPTION_ADDRESS_BASE 0x000000
#define OPTION_MATCH 0
#define UART0_8BIT_CONFIG0 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_TX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_9600|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG1 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_RX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_9600|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG2 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_TX_RX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_9600|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG3 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_TX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_9600|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG4 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_RX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_9600|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG5 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_TX_RX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_9600|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG6 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_TX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_19200|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG7 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_RX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_19200|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG8 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_TX_RX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_19200|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG9 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_TX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_19200|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG10 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_RX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_19200|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG11 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_TX_RX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_19200|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG12 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_TX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_57600|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG13 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_RX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_57600|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG14 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_TX_RX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_57600|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG15 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_TX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_57600|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG16 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_RX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_57600|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG17 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_TX_RX|UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_57600|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG18 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_TX|UART0_8BIT_S0BRG_IHRCO_110592MHZ_BAUD_RATE_115200|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG19 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_RX|UART0_8BIT_S0BRG_IHRCO_110592MHZ_BAUD_RATE_115200|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG20 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_TX_RX|UART0_8BIT_S0BRG_IHRCO_110592MHZ_BAUD_RATE_115200|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG21 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_TX|UART0_8BIT_S0BRG_IHRCO_110592MHZ_BAUD_RATE_115200|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG22 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_RX|UART0_8BIT_S0BRG_IHRCO_110592MHZ_BAUD_RATE_115200|UART0_PIN_CONFIG_RX_P30_TX_P31)
#define UART0_8BIT_CONFIG23 (UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_TX_RX|UART0_8BIT_S0BRG_IHRCO_110592MHZ_BAUD_RATE_115200|UART0_PIN_CONFIG_RX_P30_TX_P31)
//constant URT0 mode (0~255) option
#define UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_TX    (0x000000+OPTION_ADDRESS_BASE)
#define UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_RX    (0x010000+OPTION_ADDRESS_BASE)
#define UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_LSB_TX_RX (0x020000+OPTION_ADDRESS_BASE)
#define UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_TX    (0x030000+OPTION_ADDRESS_BASE)
#define UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_RX    (0x040000+OPTION_ADDRESS_BASE)
#define UART0_8BIT_S0BRG_SYSCLK_DIV_1_BAUD_RATE_2X_MSB_TX_RX (0x050000+OPTION_ADDRESS_BASE)
//constant URT0 baud rate(0~255) option
#define UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_9600   (0x000000+OPTION_ADDRESS_BASE)
#define UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_19200  (0x000100+OPTION_ADDRESS_BASE)
#define UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_57600  (0x000200+OPTION_ADDRESS_BASE)
#define UART0_8BIT_S0BRG_IHRCO_12MHZ_BAUD_RATE_115200 (0x000300+OPTION_ADDRESS_BASE)
#define UART0_8BIT_S0BRG_IHRCO_110592MHZ_BAUD_RATE_115200 (0x000400+OPTION_ADDRESS_BASE)
//constant URT0 pin config (0~15) option
#define UART0_PIN_CONFIG_RX_P30_TX_P31 (0x000000+OPTION_ADDRESS_BASE)
#define UART0_PIN_CONFIG_RX_P44_TX_P45 (0x000001+OPTION_ADDRESS_BASE)
#define UART0_PIN_CONFIG_RX_P31_TX_P30 (0x000002+OPTION_ADDRESS_BASE)
#define UART0_PIN_CONFIG_RX_P17_TX_P22 (0x000003+OPTION_ADDRESS_BASE)
///@endcond
* @brief        UART0 Easy Wizard
* @details      Set SM30 SM00 SM10 S0DOR SMOD2 SMOD1 SMOD3 S0TX12 S0RCK S0TCK
* @param[in]    \_\_SELECT\_\_ :
*  @arg\b       UART0_8BIT_CONFIG0 : 9600 12MHz 8bit LSB Rx p30 Tx p31 Tx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG1 : 9600 12MHz 8bit LSB Rx p30 Tx p31 Rx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG2 : 9600 12MHz 8bit LSB Rx p30 Tx p31 Tx/Rx both SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG3 : 9600 12MHz 8bit MSB Rx p30 Tx p31 Tx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG4 : 9600 12MHz 8bit MSB Rx p30 Tx p31 Rx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG5 : 9600 12MHz 8bit MSB Rx p30 Tx p31 Tx/Rx both SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG6 : 19200 12MHz 8bit LSB Rx p30 Tx p31 Tx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG7 : 19200 12MHz 8bit LSB Rx p30 Tx p31 Rx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG8 : 19200 12MHz 8bit LSB Rx p30 Tx p31 Tx/Rx both SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG9 : 19200 12MHz 8bit MSB Rx p30 Tx p31 Tx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG10 : 19200 12MHz 8bit MSB Rx p30 Tx p31 Rx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG11 : 19200 12MHz 8bit MSB Rx p30 Tx p31 Tx/Rx both SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG12 : 57600 12MHz 8bit LSB Rx p30 Tx p31 Tx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG13 : 57600 12MHz 8bit LSB Rx p30 Tx p31 Rx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG14 : 57600 12MHz 8bit LSB Rx p30 Tx p31 Tx/Rx both SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG15 : 57600 12MHz 8bit MSB Rx p30 Tx p31 Tx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG16 : 57600 12MHz 8bit MSB Rx p30 Tx p31 Rx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG17 : 57600 12MHz 8bit MSB Rx p30 Tx p31 Tx/Rx both SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG18 : 115200 11.0592MHz 8bit LSB Rx p30 Tx p31 Tx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG19 : 115200 11.0592MHz 8bit LSB Rx p30 Tx p31 Rx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG20 : 115200 11.0592MHz 8bit LSB Rx p30 Tx p31 Tx/Rx both SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG21 : 115200 11.0592MHz 8bit MSB Rx p30 Tx p31 Tx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG22 : 115200 11.0592MHz 8bit MSB Rx p30 Tx p31 Rx only SYSCLK/1 double baud rate S0BRG
*  @arg\b       UART0_8BIT_CONFIG23 : 115200 11.0592MHz 8bit MSB Rx p30 Tx p31 Tx/Rx both SYSCLK/1 double baud rate S0BRG
* @return       None
* @note         None
* @par          Example
* @code
                __DRV_URT0_Mode_Easy_Select(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_Mode_Easy_Select(__SELECT__)\
    MWT(\
        __DRV_SFR_PageIndex(0);\
        __DRV_URT0_EasySetSM30(__SELECT__);\
        __DRV_URT0_EasySetSM00(__SELECT__);\
        __DRV_URT0_EasySetSM10(__SELECT__);\
        __DRV_URT0_EasySetS0DOR(__SELECT__);\
        __DRV_URT0_EasySetSMOD2(__SELECT__);\
        __DRV_URT0_EasySetSMOD1(__SELECT__);\
        __DRV_URT0_EasySetSMOD3(__SELECT__);\
        __DRV_URT0_EasySetS0TX12(__SELECT__);\
        __DRV_URT0_EasySetS0RCK(__SELECT__);\
        __DRV_URT0_EasySetS0TCK(__SELECT__);\
* @details      Set S0TR S0BRT S0BRC
* @return       None
* @note         None
* @par          Example
* @code
                __DRV_URT0_BaudRate_Easy_Select(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_BaudRate_Easy_Select(__SELECT__)\
    MWT(\
        __DRV_URT0_EasySetS0TR_Stop(__SELECT__);\
        __DRV_URT0_EasySetS0BRT(__SELECT__);\
        __DRV_URT0_EasySetS0BRC(__SELECT__);\
        __DRV_URT0_EasySetS0TR_Start(__SELECT__);\
* @brief        UART0 PinMux Easy Wizard
* @details      Set S0PS0 S0PS1
* @return       None
* @note         None
* @par          Example
* @code
                __DRV_URT0_PinMux_Easy_Select(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_PinMux_Easy_Select(__SELECT__)\
    MWT(\
        __DRV_URT0_EasySetS0PS0(__SELECT__);\
        __DRV_URT0_EasySetS0PS1(__SELECT__);\
* @brief       UART0 Serial Reception
* @details     Set REN0
* @return      None
* @note        None
* @par         Example
* @code
__DRV_URT0_EasyEnableSerialReception(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasyEnableSerialReception(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(REN0=1):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(REN0=1):_nop_());\
* @details     Clear REN0
* @return      None
* @note        None
* @par         Example
* @code
__DRV_URT0_EasyDisableSerialReception(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasyDisableSerialReception(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(REN0=0):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(REN0=0):_nop_());\
* @brief       UART0 Mode Select
* @details     Set SM30
* @return       None
* @note         None
* @par         Example
* @code
__DRV_URT0_EasySetSM30(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetSM30(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(S0CFG=S0CFG&(~SM30)):_nop_());\
* @details     Set SM00
* @return      None
* @note        None
* @par         Example
* @code
__DRV_URT0_EasySetSM00(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetSM00(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(SM00_FE=0):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(SM00_FE=0):_nop_());\
* @details     Set SM10
* @return      None
* @note        None
* @par         Example
* @code
__DRV_URT0_EasySetSM10(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetSM10(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(SM10=1):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(SM10=1):_nop_());\
* @brief       UART0 S0CR1 Access Enable.
* @details     Set SMOD3
* @return      None
* @note        None
* @par         Example
* @code
__DRV_URT0_EasySetSMOD3(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetSMOD3(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD3)):_nop_());\
* @brief       UART0 S0BRG Clock Source
* @details     Set S0TX12
* @return      None
* @note        Before set S0TX12 , set SMOD3=1 first
* @par         Example
* @code
__DRV_URT0_EasySetS0TX12(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetS0TX12(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(S0CR1=S0CR1|(S0TX12)):_nop_());\
* @brief       UART0 Receive Clock
* @details     Set S0RCK
* @return      None
* @note        None
* @par         Example
* @code
__DRV_URT0_EasySetS0RCK(URT0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetS0RCK(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(S0CR1=S0CR1&(~S0RCK)):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(S0CR1=S0CR1&(~S0RCK)):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(S0CR1=S0CR1&(~S0RCK)):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(S0CR1=S0CR1&(~S0RCK)):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(S0CR1=S0CR1&(~S0RCK)):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(S0CR1=S0CR1&(~S0RCK)):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(S0CR1=S0CR1&(~S0RCK)):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(S0CR1=S0CR1&(~S0RCK)):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(S0CR1=S0CR1|(S0RCK)):_nop_());\
* @brief       UART0 Transmit Clock
* @details     Set S0TCK
* @return      None
* @note        None
* @par         Example
* @code
___DRV_URT0_EasySetS0TCK(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetS0TCK(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TCK)):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TCK)):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TCK)):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TCK)):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TCK)):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TCK)):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TCK)):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TCK)):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(S0CR1=S0CR1|(S0TCK)):_nop_());\
* @brief       UART0 Data Order
* @details     Set S0DOR
* @return      None
* @note        None
* @par         Example
* @code
__DRV_URT0_EasySetS0DOR(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetS0DOR(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(S0CFG=S0CFG|(S0DOR)):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(S0CFG=S0CFG|(S0DOR)):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(S0CFG=S0CFG|(S0DOR)):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(S0CFG=S0CFG&(~S0DOR)):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(S0CFG=S0CFG&(~S0DOR)):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(S0CFG=S0CFG&(~S0DOR)):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(S0CFG=S0CFG|(S0DOR)):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(S0CFG=S0CFG|(S0DOR)):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(S0CFG=S0CFG|(S0DOR)):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(S0CFG=S0CFG&(~S0DOR)):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(S0CFG=S0CFG&(~S0DOR)):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(S0CFG=S0CFG&(~S0DOR)):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(S0CFG=S0CFG|(S0DOR)):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(S0CFG=S0CFG|(S0DOR)):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(S0CFG=S0CFG|(S0DOR)):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(S0CFG=S0CFG&(~S0DOR)):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(S0CFG=S0CFG&(~S0DOR)):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(S0CFG=S0CFG&(~S0DOR)):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(S0CFG=S0CFG|(S0DOR)):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(S0CFG=S0CFG|(S0DOR)):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(S0CFG=S0CFG|(S0DOR)):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(S0CFG=S0CFG&(~S0DOR)):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(S0CFG=S0CFG&(~S0DOR)):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(S0CFG=S0CFG&(~S0DOR)):_nop_());\
* @brief       UART0 Enhance Baud Rate
* @details     Set SMOD1
* @return      None
* @note        None
* @par         Example
* @code
__DRV_URT0_EasySetSMOD1(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetSMOD1(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(PCON0=PCON0&(~SMOD1)):_nop_());\
* @brief       UART0 Enhance Baud Rate.
* @details     Set SMOD2
* @return      None
* @note        None
* @par         Example
* @code
__DRV_URT0_EasySetSMOD2(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetSMOD2(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(S0CFG=S0CFG|(SMOD2)):_nop_());\
* @brief      UART0  Baud Rate Generator Reload Register
* @details    Write S0BRT
* @return      None
* @note        Before write S0BRT and S0BRC,S0BRG operation stop first
* @par         Example
* @code
__DRV_URT0_EasySetS0BRT(UART0_8BIT_CONFIG0)
* @endcode
///@cond __DRV_URT0_EasySetS0BRT
//                                                              //error
#define S0BRG_BRGRL_2400_1X_12000000_12T            0xF3        // 0.16%
#define S0BRG_BRGRL_4800_1X_11059200_12T            0xFA        // 0%
#define S0BRG_BRGRL_9600_1X_11059200_12T            0xFD        // 0%
#define S0BRG_BRGRL_2400_1X_12000000_1T             0x64        // 0.16%
#define S0BRG_BRGRL_4800_1X_12000000_1T             0xB2        // 0.16%
#define S0BRG_BRGRL_9600_1X_12000000_1T             0xD9        // 0.16%
#define S0BRG_BRGRL_19200_1X_12000000_1T            0xEC        // -2.34%
#define S0BRG_BRGRL_38400_1X_12000000_1T            0xF6        // -2.34%
#define S0BRG_BRGRL_57600_1X_11059200_1T            0xFA        // 0%
#define S0BRG_BRGRL_115200_1X_11059200_1T           0xFD        // 0%
#define S0BRG_BRGRL_2400_2X_12000000_12T            0xE6        // 0.16%
#define S0BRG_BRGRL_4800_2X_12000000_12T            0xF3        // 0.16%
#define S0BRG_BRGRL_9600_2X_11059200_12T            0xFA        // 0%
#define S0BRG_BRGRL_19200_2X_11059200_12T           0xFD        // 0%
#define S0BRG_BRGRL_57600_2X_11059200_12T           0xFF        // 0%
#define S0BRG_BRGRL_4800_2X_12000000_1T             0x64        // 0.16%
#define S0BRG_BRGRL_9600_2X_12000000_1T             0xB2        // 0.16%
#define S0BRG_BRGRL_19200_2X_12000000_1T            0xD9        // 0.16%
#define S0BRG_BRGRL_38400_2X_12000000_1T            0xEC        // -2.34%
#define S0BRG_BRGRL_57600_2X_12000000_1T            0xF3        // 0.16%
#define S0BRG_BRGRL_115200_2X_11059200_1T           0xFA        // 0%
#define S0BRG_BRGRL_230400_2X_11059200_1T           0xFD        // 0%
#define S0BRG_BRGRL_250000_2X_12000000_1T           0xFD        // 0%
#define S0BRG_BRGRL_750000_2X_12000000_1T           0xFF        // 0%
///@endcond
#define __DRV_URT0_EasySetS0BRT(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_9600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_9600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_9600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_9600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_9600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_9600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_19200_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_19200_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_19200_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_19200_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_19200_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_19200_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_57600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_57600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_57600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_57600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_57600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_57600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_115200_2X_11059200_1T):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_115200_2X_11059200_1T):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_115200_2X_11059200_1T):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_115200_2X_11059200_1T):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_115200_2X_11059200_1T):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(S0BRT=S0BRG_BRGRL_115200_2X_11059200_1T):_nop_());\
* @details    Write S0BRC
* @return      None
* @par         Example
* @code
__DRV_URT0_EasySetS0BRC(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetS0BRC(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_9600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_9600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_9600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_9600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_9600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_9600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_19200_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_19200_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_19200_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_19200_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_19200_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_19200_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_57600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_57600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_57600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_57600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_57600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_57600_2X_12000000_1T):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_115200_2X_11059200_1T):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_115200_2X_11059200_1T):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_115200_2X_11059200_1T):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_115200_2X_11059200_1T):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_115200_2X_11059200_1T):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(S0BRC=S0BRG_BRGRL_115200_2X_11059200_1T):_nop_());\
* @brief       UART0 S0BRG Operation Enable
* @details     Set S0TR
* @return      None
* @par         Example
* @code
__DRV_URT0_EasySetS0TR_Start(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetS0TR_Start(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(S0CR1=S0CR1|(S0TR)):_nop_());\
* @brief       UART0 S0BRG Operation Disable
* @details     Set S0TR
* @return      None
* @par         Example
* @code
__DRV_URT0_EasySetS0TR_Stop(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetS0TR_Stop(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(S0CR1=S0CR1&(~S0TR)):_nop_());\
* @brief       UART0 Pin Config
* @return      None
* @note        None
* @par         Example
* @code
__DRV_URT0_EasySetS0PS0(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetS0PS0(__SELECT__)\
    MWT(\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(AUXR3=AUXR3&(~S0PS0)):_nop_());\
* @details     Set S0PS1
* @return      None
* @note        None
* @par         Example
* @code
__DRV_URT0_EasySetS0PS1(UART0_8BIT_CONFIG0)
* @endcode
#define __DRV_URT0_EasySetS0PS1(__SELECT__)\
    MWT(\
        __DRV_SFR_PageIndex(7);\
        ((__SELECT__^UART0_SELECT0)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT1)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT2)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT3)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT4)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT5)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT6)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT7)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT8)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT9)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT10)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT11)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT12)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT13)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT14)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT15)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT16)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT17)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT18)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT19)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT20)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT21)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT22)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):\
        (__SELECT__^UART0_SELECT23)==OPTION_MATCH?(AUXR10=AUXR10&(~S0PS1)):_nop_());\
#endif  //MG82F6D17_UART0_MID_H
重新更改的,可以通过一些宏
107
有谁还用过这样开发的单片机
107
void TIMER2_TF2_EXF2_ISR(void)   interrupt TIMER2_ISR_VECTOR
    _push_(SFRPI);
    _pop_(SFRPI);
里面这两行是干嘛的啊
推荐帖子
各种集成电路简介(经典ZZ)
第一节 三端稳压IC 电子产品中常见到的三端稳压集成电路有正电压输出的78××系列和负电压输出的79×× ...
元件模特秀--图文并茂、简单易懂
无意间发现一篇很有创意的介绍元件的原理、外形、封装、功能的文章---元件模特秀。 原作者是“爱因迪生”。在这里我转帖过来, ...
决战2011全国大学生电子设计竞赛——寒假篇(下)
电设竞赛应该准备好哪些理论基础?——这点在这套电设竞赛备战攻略中之后会详细展开叙述 ...
关于AD转换设计的一些经验总结
看到一片关于AD转换设计中的基本问题整理博文,特地转载过来和大家共分享。 了解数据转换器错误及参数 1.如何选择高速模数 ...
有奖调查:ST MEMS 传感器论坛用户问卷调查,参与有惊喜
活动时间:即日起至6月22日 填问卷 >>点此填写问卷,几分钟,即可完成。为论坛以后的升级、内容建设提出您的建议 ...
基于RSL10的心率检测BLE设备
基于RSL10的心率检测BLE设备 作者:yilonglucky 一、作品简介 心率检测服务是蓝牙协议族中标准一套子协议。本项目基于R ...
国产汽车芯片迎来”窗口期“?开始被测评网友问这个芯片是不是车规级?
上个月复旦微的FM33LG0系列在论坛免费申请测评,有网友问:是不是车规级的 保险起见,我去问了复旦微家的人,得到回复: ...
【花雕动手做】有趣好玩的音乐可视化项目(11)---WS2812幻彩灯带
偶然心血来潮,想要做一个声音可视化的系列专题。这个专题的难度有点高,涉及面也比较广泛,相关的FFT和FHT等算法也相当复杂,不 ...
正负12V电路的输出端是两个电容并联吗
请教,正负12V电路的输出端是两个电容并联,输出电容里两个2X22uF电容是什么意思呢 814791
【2024 DigiKey创意大赛】1.树莓派5驱动ILI9488图像显示
1.前言 其实早就收到了RaspberryPi5的套件,8G版本,拿到手真是欣喜啊.自此开始了折腾之路。其实一直也在想从哪里入手呢,后面 ...
