【得捷电子Follow me第4期】终极任务+总结
终极任务自己用circuit python没捣鼓出来,所以学习了其他大佬基于micropython的FTP服务器设计
import socket
import network
import uos
import gc
from time import localtime
from machine import Pin,SPI
import time
def w5x00_init():
#spi init
spi=SPI(0,2_000_000, mosi=Pin(19),miso=Pin(16),sck=Pin(18))
nic = network.WIZNET5K(spi,Pin(17),Pin(20)) #spi,cs,reset pin
nic.active(True)#network active
nic.ifconfig(('192.168.1.100','255.255.255.0','192.168.1.1','8.8.8.8'))#Set static network address information
while not nic.isconnected():
time.sleep(1)
print(nic.regs())#Print register information
#Print network address information
print("IP Address:",nic.ifconfig()[0])
print("Subnet Mask:",nic.ifconfig()[1])
print("Gateway:",nic.ifconfig()[2])
print("DNS:",nic.ifconfig()[3])
return nic
month_name = ["", "Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"]
def send_list_data(path, dataclient, full):
try: # whether path is a directory name
for fname in uos.listdir(path):
dataclient.sendall(make_description(path, fname, full))
except: # path may be a file name or pattern
pattern = path.split("/")[-1]
path = path[:-(len(pattern) + 1)]
if path == "": path = "/"
if fncmp(fname, pattern) == True:
def make_description(path, fname, full):
if full:
stat = uos.stat(get_absolute_path(path,fname))
file_permissions = "drwxr-xr-x" if (stat[0] & 0o170000 == 0o040000) else "-rw-r--r--"
file_size = stat[6]
tm = localtime(stat[7])
if tm[0] != localtime()[0]:
description = "{} 1 owner group {:>10} {} {:2} {:>5} {}\r\n".format(
file_permissions, file_size, month_name[tm[1]], tm[2], tm[0], fname)
else:
description = "{} 1 owner group {:>10} {} {:2} {:02}:{:02} {}\r\n".format(
file_permissions, file_size, month_name[tm[1]], tm[2], tm[3], tm[4], fname)
else:
description = fname + "\r\n"
return description
def send_file_data(path, dataclient):
with open(path, "r") as file:
chunk = file.read(512)
while len(chunk) > 0:
dataclient.sendall(chunk)
def save_file_data(path, dataclient, mode):
with open(path, mode) as file:
chunk = dataclient.read(512)
file.write(chunk)
def get_absolute_path(cwd, payload):
# Just a few special cases "..", "." and ""
# If payload start's with /, set cwd to /
# and consider the remainder a relative path
if payload.startswith('/'):
cwd = "/"
for token in payload.split("/"):
if token == '..':
if cwd != '/':
cwd = '/'.join(cwd.split('/')[:-1])
if cwd == '':
cwd = '/'
elif token != '.' and token != '':
if cwd == '/':
cwd += token
else:
cwd = cwd + '/' + token
return cwd
# compare fname against pattern. Pattern may contain
# wildcards ? and *.
def fncmp(fname, pattern):
pi = 0
si = 0
while pi < len(pattern) and si < len(fname):
if (fname[si] == pattern[pi]) or (pattern[pi] == '?'):
si += 1
pi += 1
else:
if pattern[pi] == '*': # recurse
if (pi + 1) == len(pattern):
return True
while si < len(fname):
if fncmp(fname[si:], pattern[pi+1:]) == True:
return True
else:
si += 1
return False
else:
return False
if pi == len(pattern.rstrip("*")) and si == len(fname):
return True
else:
return False
def ftpserver():
DATA_PORT = 13333
ftpsocket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
datasocket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
ftpsocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
datasocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
ftpsocket.bind(socket.getaddrinfo("0.0.0.0", 21)[0][4])
datasocket.bind(socket.getaddrinfo("0.0.0.0", DATA_PORT)[0][4])
ftpsocket.listen(1)
datasocket.listen(1)
datasocket.settimeout(10)
msg_250_OK = '250 OK\r\n'
msg_550_fail = '550 Failed\r\n'
try:
dataclient = None
fromname = None
while True:
cl, remote_addr = ftpsocket.accept()
cl.settimeout(300)
cwd = '/'
try:
# print("FTP connection from:", remote_addr)
cl.sendall("220 Hello, this is the ESP8266.\r\n")
while True:
gc.collect()
data = cl.readline().decode("utf-8").rstrip("\r\n")
if len(data) <= 0:
print("Client disappeared")
break
command = data.split(" ")[0].upper()
payload = data[len(command):].lstrip()
path = get_absolute_path(cwd, payload)
print("Command={}, Payload={}, Path={}".format(command, payload, path))
if command == "USER":
cl.sendall("230 Logged in.\r\n")
elif command == "SYST":
cl.sendall("215 UNIX Type: L8\r\n")
elif command == "NOOP":
cl.sendall("200 OK\r\n")
elif command == "FEAT":
cl.sendall("211 no-features\r\n")
elif command == "PWD":
cl.sendall('257 "{}"\r\n'.format(cwd))
elif command == "CWD":
try:
files = uos.listdir(path)
cwd = path
cl.sendall(msg_250_OK)
except:
cl.sendall(msg_550_fail)
elif command == "CDUP":
cwd = get_absolute_path(cwd, "..")
elif command == "TYPE":
# probably should switch between binary and not
cl.sendall('200 Transfer mode set\r\n')
elif command == "SIZE":
try:
size = uos.stat(path)[6]
cl.sendall('213 {}\r\n'.format(size))
except:
elif command == "QUIT":
cl.sendall('221 Bye.\r\n')
break
elif command == "PASV":
addr = nic.ifconfig()[0]
cl.sendall('227 Entering Passive Mode ({},{},{}).\r\n'.format(
addr.replace('.',','), DATA_PORT>>8, DATA_PORT%256))
dataclient, data_addr = datasocket.accept()
# print("FTP Data connection from:", data_addr)
elif command == "LIST" or command == "NLST":
if not payload.startswith("-"):
place = path
else:
place = cwd
try:
send_list_data(place, dataclient, command == "LIST" or payload == "-l")
cl.sendall("150 Here comes the directory listing.\r\n")
cl.sendall("226 Listed.\r\n")
except:
if dataclient is not None:
dataclient.close()
dataclient = None
elif command == "RETR":
try:
cl.sendall("150 Opening data connection.\r\n")
cl.sendall("226 Transfer complete.\r\n")
except:
dataclient.close()
dataclient = None
elif command == "STOR":
try:
cl.sendall("150 Ok to send data.\r\n")
save_file_data(path, dataclient, "w")
except:
dataclient.close()
dataclient = None
elif command == "APPE":
try:
save_file_data(path, dataclient, "a")
except:
dataclient.close()
dataclient = None
elif command == "DELE":
try:
uos.remove(path)
except:
elif command == "RMD":
try:
uos.rmdir(path)
except:
elif command == "MKD":
try:
uos.mkdir(path)
except:
elif command == "RNFR":
fromname = path
cl.sendall("350 Rename from\r\n")
elif command == "RNTO":
if fromname is not None:
try:
uos.rename(fromname, path)
except:
else:
fromname = None
else:
cl.sendall("502 Unsupported command.\r\n")
# print("Unsupported command {} with payload {}".format(command, payload))
except Exception as err:
print(err)
finally:
cl.close()
cl = None
finally:
datasocket.close()
ftpsocket.close()
dataclient.close()
nic = w5x00_init()
ftpserver()
基于socket,构建一个ftp文件服务器IP为:192.168.1.100
运行完成后,在文件夹下通过ftp://192.168.1.100访问该ftp文件服务器,
向其拖入文件,thonny中便可以看到上传的文件,存储在该server下
任务合集:
【得捷电子Follow me第4期】入门任务-开箱-开发环境搭建-BLINK - DigiKey得捷技术专区 - 电子工程世界-论坛 (eeworld.com.cn)
【得捷电子Follow me第4期】入门任务->基础任务一 - DigiKey得捷技术专区 - 电子工程世界-论坛 (eeworld.com.cn)
【得捷电子Follow me第4期】基础任务二-TCP server和UDP server - DigiKey得捷技术专区 - 电子工程世界-论坛 (eeworld.com.cn)
【得捷电子Follow me第4期】进阶任务-NTP同步时间 - DigiKey得捷技术专区 - 电子工程世界-论坛 (eeworld.com.cn)
【得捷电子Follow me第4期】终极任务+总结 - DigiKey得捷技术专区 - 电子工程世界-论坛 (eeworld.com.cn)
视频:
得捷Follow me第4期任务合集视频-EEWORLD大学堂
B站的:
总结:
对rp2040、python、网络都比较陌生,第一次使用rp2040,基于circuitpython或micropython进行编程,了解了相关库,自己学习了python环境下IO、TIM、ADC、SPI、IIC等各外设的使用,任务做的勉勉强强,不过学到了很多自己想要了解的东西,对网络TCP/IP、服务器、客户端有了新的认知,收获颇丰,拓宽了自己的知识面。
感谢EEworld与得捷FM4的这次活动,有了开发平台后,后续会随着自己的深入,持续学习,不断完善。
本次群里讨论的很激烈,一天不看就有成百上千条未读消息,各种大佬争相秀技,认识到了许多新事物,新的方向。
建议:
Follow me做的很不错,如果可以再多一些指导教程就更好了!
