【得捷电子Follow me第4期】基础任务二-TCP server和UDP server
TCP Server
将pico+W5500通过网线接到路由或者交换机上
通过CMD确定ipconfig的IP地址,将TCP和UDP与其配置在同一个网段下进行连接
这里主机地址是192.168.31.171
将pico+W5500配置为192.168.31.100,端口号2233
import board
import busio
import digitalio
import time
import array
from adafruit_wiznet5k.adafruit_wiznet5k import WIZNET5K
import adafruit_wiznet5k.adafruit_wiznet5k_socket as socket
import adafruit_sharpmemorydisplay
'''LED init'''
led = digitalio.DigitalInOut(board.GP25)
led.direction = digitalio.Direction.OUTPUT
'''Sharp Display init'''
# Initialize SPI bus and control pins
spi = busio.SPI(board.GP14, MOSI=board.GP15)
scs = digitalio.DigitalInOut(board.GP13) # inverted chip select
# pass in the display size, width and height, as well
# display = adafruit_sharpmemorydisplay.SharpMemoryDisplay(spi, scs, 96, 96)
display = adafruit_sharpmemorydisplay.SharpMemoryDisplay(spi, scs, 144, 168)
'''W5500 init start'''
##SPI0-W5500
SPI0_SCK = board.GP18
SPI0_TX = board.GP19
SPI0_RX = board.GP16
SPI0_CSn = board.GP17
##reset
W5x00_RSTn = board.GP20
print("Wiznet5k Simple TCP Server Test")
# Setup your network configuration below
# random MAC, later should change this value on your vendor ID
#MY_MAC = (0x00, 0x01, 0x02, 0x03, 0x04, 0x05)
IP_ADDRESS = (192, 168, 31, 100)
SUBNET_MASK = (255, 255, 0, 0)
GATEWAY_ADDRESS = (192, 168, 31, 1)
DNS_SERVER = (8, 8, 8, 8)
ethernetRst = digitalio.DigitalInOut(W5x00_RSTn)
ethernetRst.direction = digitalio.Direction.OUTPUT
# For Adafruit Ethernet FeatherWing
cs = digitalio.DigitalInOut(SPI0_CSn)
# For Particle Ethernet FeatherWing
# cs = digitalio.DigitalInOut(board.D5)
spi_bus = busio.SPI(SPI0_SCK, MOSI=SPI0_TX, MISO=SPI0_RX)
# Reset W5500 first
ethernetRst.value = False
time.sleep(1)
ethernetRst.value = True
# # Initialize ethernet interface without DHCP
eth = WIZNET5K(spi_bus, cs, is_dhcp=False)#, mac=MY_MAC, debug=True)
# # Set network configuration
eth.ifconfig = (IP_ADDRESS, SUBNET_MASK, GATEWAY_ADDRESS, DNS_SERVER)
# Initialize ethernet interface with DHCP
#eth = WIZNET5K(spi_bus, cs, is_dhcp=True, mac=MY_MAC, debug=True)
print("Chip Version:", eth.chip)
print("MAC Address:", [hex(i) for i in eth.mac_address])
print("My IP address is:", eth.pretty_ip(eth.ip_address))
'''W5500 init end'''
'''TCP socket init'''
# Initialize a socket for our server
socket.set_interface(eth)
server = socket.socket() # Allocate socket for the server
server_ip = None # IP address of server
server_port = 2233 # Port to listen on
server.bind((server_ip, server_port)) # Bind to IP and Port
server.listen() # Begin listening for incoming clients
#conn, addr = server.accept() # Wait for a connection from a client.
#print("socket connected")
'''display show'''
display.fill(1)
chip_version = "chip version:" + eth.chip
display.text(chip_version, 0, 0, 0)
ip_addr = "ip:" + eth.pretty_ip(eth.ip_address)
display.text(ip_addr, 0, 10, 0)
mac_addr = "mac:" + eth.pretty_mac(eth.mac_address)
display.text(mac_addr, 0, 20, 0)
display.show()
row = 30
while True:
# Maintain DHCP lease
#eth.maintain_dhcp_lease()
led.value = not led.value
time.sleep(1)
with server:
while True:
# data = conn.recv(20)
data,addr = server.recvfrom(20)
if data:
print(data)
display.fill_rect(0,row,144,10,1)
display.text(data.decode('utf-8'), 0, row, 0)
display.show()
row += 10
if row > 150:
row = 30
手机端TCP/IP连接测试
UDP server
import board
import busio
import digitalio
import time
import array
'''LED init'''
##SPI0-W5500
##reset
print("Wiznet5k Simple UDP Server Test")
# Reset W5500 first
time.sleep(1)
'''UDP socket init'''
server = socket.socket(socket.AF_INET, socket.SOCK_DGRAM) # Allocate socket for the server
server.bind((eth.pretty_ip(eth.ip_address), server_port)) # Bind to IP and Port
'''display show'''
display.fill(1)
display.show()
row = 30
while True:
time.sleep(1)
with server:
while True:
if data:
print(data)
display.show()
row += 10
if row > 150:
row = 30
server.send(data)
#conn.send(data) # Echo message back to client
手机端UDP连接测试
