566|0
181
【得捷电子Follow me第4期】进阶任务-NTP同步时间 [复制链接]
从NTP同步时间,这里使用的是adafruit_ntp.py
adafruit_ntp.py (3.53 KB, 下载次数: 1)
基于socket的示例,import adafruit_ntp
import board
import busio
import digitalio
import time
import array
import struct
import adafruit_requests as requests
from adafruit_wiznet5k.adafruit_wiznet5k import *
import adafruit_wiznet5k.adafruit_wiznet5k_socket as socket
from adafruit_wiznet5k.adafruit_wiznet5k_ntp import NTP
import adafruit_wiznet5k.adafruit_wiznet5k_dns as dns
import adafruit_ntp
days = ("Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday")
##SPI0
SPI0_SCK = board.GP18
SPI0_TX = board.GP19
SPI0_RX = board.GP16
SPI0_CSn = board.GP17
##reset
W5x00_RSTn = board.GP20
print("Wiznet5k NTP Client (DHCP)")
# Setup your network configuration below
# random MAC, later should change this value on your vendor ID
MY_MAC = (0x00, 0x01, 0x02, 0xFF, 0xFF, 0xFF)
IP_ADDRESS = (192, 168, 1, 24)
SUBNET_MASK = (255, 255, 255, 0)
GATEWAY_ADDRESS = (192, 168, 1, 1)
DNS_SERVER = (8, 8, 8, 8)
port = 5000
ntp_server_port= 123
led = digitalio.DigitalInOut(board.GP25)
led.direction = digitalio.Direction.OUTPUT
ethernetRst = digitalio.DigitalInOut(W5x00_RSTn)
ethernetRst.direction = digitalio.Direction.OUTPUT
# For Adafruit Ethernet FeatherWing
cs = digitalio.DigitalInOut(SPI0_CSn)
# cs = digitalio.DigitalInOut(board.D5)
spi_bus = busio.SPI(SPI0_SCK, MOSI=SPI0_TX, MISO=SPI0_RX)
# Reset W5500 first
ethernetRst.value = False
time.sleep(1)
ethernetRst.value = True
# Initialize ethernet interface without DHCP
#eth = WIZNET5K(spi_bus, cs, is_dhcp=False, mac=MY_MAC, debug=False)
# Initialize ethernet interface with DHCP
eth = WIZNET5K(spi_bus, cs, is_dhcp=True, mac=MY_MAC, debug=False)
print("Chip Version:", eth.chip)
print("MAC Address:", [hex(i) for i in eth.mac_address])
print("My IP address is:", eth.pretty_ip(eth.ip_address))
# Initialize a socket for our server
socket.set_interface(eth)
# Set network configuration
eth.ifconfig = (IP_ADDRESS, SUBNET_MASK, GATEWAY_ADDRESS, DNS_SERVER)
ntp = adafruit_ntp.NTP(socket)
print(ntp.datetime)
运行即可
通过串口打印出相关信息和+8后的时间:2024.2.16.23:59:44
Chip Version: w5500
MAC Address: ['0x0', '0x1', '0x2', '0xff', '0xff', '0xff']
My IP address is: 192.168.1.24
struct_time(tm_year=2024, tm_mon=2, tm_mday=16, tm_hour=15, tm_min=59, tm_sec=44, tm_wday=4, tm_yday=47, tm_isdst=-1)
