3288|3
请教TCPMP源码中的一个问题:blit_i420_i420_mmx 等都是extern的,但没找到它们的原定义,有知道的么? [复制链接]
请教TCPMP源码中的一个问题:
  1. #define DECLARE_BLITMMX(name) \
  2. extern void STDCALL name##_mmx(blit_soft* This, uint8_t** DstPtr,uint8_t** SrcPtr,int DstPitch,int SrcPitch,int Width,int Height,uintptr_t Src2SrcLast); \
  3. extern void STDCALL name##_mmx2(blit_soft* This, uint8_t** DstPtr,uint8_t** SrcPtr,int DstPitch,int SrcPitch,int Width,int Height,uintptr_t Src2SrcLast); \
  4. extern void STDCALL name##_3dnow(blit_soft* This, uint8_t** DstPtr,uint8_t** SrcPtr,int DstPitch,int SrcPitch,int Width,int Height,uintptr_t Src2SrcLast);
  5. DECLARE_BLITMMX(blit_i420_i420)
  6. DECLARE_BLITMMX(blit_i420_yuy2)
  7. DECLARE_BLITMMX(blit_i420_rgb32)
  8. DECLARE_BLITMMX(blit_i420_rgb24)
  9. DECLARE_BLITMMX(blit_i420_bgr32)
  10. DECLARE_BLITMMX(blit_i420_bgr24)
  11. DECLARE_BLITMMX(blit_rgb32_rgb32)
  12. DECLARE_BLITMMX(blit_rgb24_rgb24)
  13. DECLARE_BLITMMX(blit_rgb16_rgb16)
  14. typedef struct blitmmx
  15. {
  16.     uint32_t In;
  17.     uint32_t Out;
  18.     blitsoftentry Func[3];
  19. } blitmmx;
  20. static const blitmmx BlitMMX[] =
  21. {
  22.     { FOURCC_I420, FOURCC_I420, { blit_i420_i420_mmx, blit_i420_i420_mmx2, blit_i420_i420_3dnow }},
  23.     { FOURCC_I420, FOURCC_YUY2, { blit_i420_yuy2_mmx, blit_i420_yuy2_mmx2, blit_i420_yuy2_3dnow }},
  24.     { FOURCC_I420, FOURCC_RGB32,{ blit_i420_rgb32_mmx,blit_i420_rgb32_mmx2,blit_i420_rgb32_3dnow }},
  25.     { FOURCC_I420, FOURCC_RGB24,{ blit_i420_rgb24_mmx,blit_i420_rgb24_mmx2,blit_i420_rgb24_3dnow }},
  26.     { FOURCC_I420, FOURCC_BGR32,{ blit_i420_bgr32_mmx,blit_i420_bgr32_mmx2,blit_i420_bgr32_3dnow }},
  27.     { FOURCC_I420, FOURCC_BGR24,{ blit_i420_bgr24_mmx,blit_i420_bgr24_mmx2,blit_i420_bgr24_3dnow }},
  28.     { FOURCC_RGB32,FOURCC_RGB32,{ blit_rgb32_rgb32_mmx,blit_rgb32_rgb32_mmx2,blit_rgb32_rgb32_3dnow }},
  29.     { FOURCC_RGB24,FOURCC_RGB24,{ blit_rgb24_rgb24_mmx,blit_rgb24_rgb24_mmx2,blit_rgb24_rgb24_3dnow }},
  30.     { FOURCC_RGB16,FOURCC_RGB16,{ blit_rgb16_rgb16_mmx,blit_rgb16_rgb16_mmx2,blit_rgb16_rgb16_3dnow }},
  31.     { FOURCC_RGB15,FOURCC_RGB15,{ blit_rgb16_rgb16_mmx,blit_rgb16_rgb16_mmx2,blit_rgb16_rgb16_3dnow }},
  32.     { FOURCC_BGR32,FOURCC_BGR32,{ blit_rgb32_rgb32_mmx,blit_rgb32_rgb32_mmx2,blit_rgb32_rgb32_3dnow }},
  33.     { FOURCC_BGR24,FOURCC_BGR24,{ blit_rgb24_rgb24_mmx,blit_rgb24_rgb24_mmx2,blit_rgb24_rgb24_3dnow }},
  34.     { FOURCC_BGR16,FOURCC_BGR16,{ blit_rgb16_rgb16_mmx,blit_rgb16_rgb16_mmx2,blit_rgb16_rgb16_3dnow }},
  35.     { FOURCC_BGR15,FOURCC_BGR15,{ blit_rgb16_rgb16_mmx,blit_rgb16_rgb16_mmx2,blit_rgb16_rgb16_3dnow }},
  36.     {0},
  37. };
复制代码
common\blit\blit_mmx.asm中的宏blit里定义了对应的函数,有mmx2,mmx,3dnow三套函数。  详情 回复 发表于 2010-4-8 14:43
你在CE上用么?CE上用的话管这个函数干什么?这明显是mmx指令的优化函数,CE上一定不支持的。
哦,那么 blit_i420_i420_mmx 等这些函数都在哪里定义的呀?没找到呀
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
第2场直播:融合热仿真与热测试提升产品可靠性
直播时间:04月17日 14:00 - 15:00
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 12
