544|0
294
R16 android4.4 常见问题参考手册 [复制链接]
明远智睿R16 android4.4 常见问题参考手册
1  R16 android4.4 常见问题
1.1  在内核中添加spi驱动
$cd lichee/linux-3.4 $make ARCH=arm menuconfig $lunch astar_parrot-tina
$make kernel_menuconfig
Device Drivers ---> SPI support ---> <*> User mode SPI device driver support
修改
lichee/tools/pack/chips/sun8iw5p1/configs/evb-30/sys_config.fex
[spi_board0]
modalias      = "at25df641"
sflash_size   = 32
max_speed_hz  = 50000000
bus_num       = 0
chip_select   = 0
mode          = 0
修改成
[spi_board0]
modalias      = "spidev"
sflash_size   = 32
bus_num       = 0
chip_select   = 0
mode          = 0
1.2  以太网不能用
在内核增加驱动
Device Drivers --->
   Network device support --->
       USB Network Adapters --->
              <*> Multi-purpose USB Networking Frameworksuch as cable modems)
              <*> SMSC LAN95XX based USB 2.0 10/100 ethernet devices
1.3  默认勾选使用以太网
1)在frameworks\base\packages\SettingsProvider\res\values\default.xml
  true  改成true
  true 添加以下这两句
     true
      eth0
2)在frameworks\base\packages\SettingsProvider\src\com\android\providers\settings\DatabaseHelper.java 添加
       loadBooleanSetting(stmt, Settings.Global.ETHERNET_CONF, R.bool.def_ethernet_conf)
       loadStringSetting(stmt, Settings.Global.ETHERNET_IFNAME, R.string.def_ethernet_ifname)
个人签名明远智睿 您的一站式 嵌入式 方案提供商
立即报名 | 2025 瑞萨电子工业以太网技术日即将开启!
预报从速,好礼等您拿~
