2030|0
253
MY-R16-EK166 常见问题参考手册 [复制链接]
MY-R16-EK166 常见问题参考手册[size=0.87em]
关于R16增加spiLinux系统:
1)在内核中添加spi驱动
$cd tinaV2.1 $source build/envsetup.sh
$lunch astar_parrot-tina
$make kernel_menuconfig
Device Drivers --->
SPI support --->
<*> User mode SPI device driver support
2)修改
  tinaV2.1/target/allwinner/astar-parrot/configs/sys_config.fex  [spi_board0]  modalias      = "at25df641"  sflash_size   = 32  max_speed_hz  = 50000000bus_num       = 0  chip_select   = 0  mode          = 0
修改成
   [spi_board0]modalias      = "spidev"  sflash_size   = 32  max_speed_hz  = 50000000  bus_num       = 0  chip_select   = 0  mode          = 0  Android系统:
1)在内核中添加spi驱动
$cd lichee/linux-3.4
$make ARCH=arm menuconfig
Device Drivers --->
SPI support --->
2)修改
   lichee/tools/pack/chips/sun8iw5p1/configs/evb-30/sys_config.fex    [spi_board0]  modalias      = "at25df641"    sflash_size   = 32    max_speed_hz  = 50000000  bus_num       = 0    chip_select   = 0   mode          = 0
修改成
[spi_board0]  modalias      = "spidev"    sflash_size   = 32    max_speed_hz  = 50000000    bus_num       = 0   chip_select   = 0   mode          = 0
此帖出自ARM技术论坛
点赞 关注(1)
