2519|2
613
STM32学习第九贴 关不掉的PWM脚 [复制链接]
今天试了一下STM32F103的PWM脚输出PWM.
代码如下:
TIM_TimeBaseStructInit(&TIM1_TimeBaseStructure);
  /* Time Base configuration */
  TIM1_TimeBaseStructure.TIM_Prescaler = 0x0;
  TIM1_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned1; //0x0020 中间对齐1模式
  TIM1_TimeBaseStructure.TIM_Period = 1999;    //
  TIM1_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV2; //0x0100
  // Initial condition is REP=0 to set the UPDATE only on the underflow
  TIM1_TimeBaseStructure.TIM_RepetitionCounter = 1; //1
  TIM_TimeBaseInit(TIM1, &TIM1_TimeBaseStructure); //
TIM_OCStructInit(&TIM1_OCInitStructure);
  /* Channel 1, 2,3 in PWM mode */
  TIM1_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM1_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM1_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM1_OCInitStructure.TIM_Pulse = 1000; //dummy value
  TIM1_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
//  TIM1_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  TIM1_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  TIM1_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
//  TIM1_OCInitStructure.TIM_OCNIdleState = LOW_SIDE_POLARITY;
  TIM1_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Set;//LOW_SIDE_POLARITY;
  TIM_OC1Init(TIM1, &TIM1_OCInitStructure);
// Resynch to have the Update evend during Undeflow
  TIM_GenerateEvent(TIM1, TIM_EventSource_Update);
  // Clear Update Flag
  TIM_ClearFlag(TIM1, TIM_FLAG_Update);
  TIM_ITConfig(TIM1, TIM_IT_Update, DISABLE);
  TIM_ITConfig(TIM1, TIM_IT_CC4,DISABLE);
现在输出有了,但是很奇怪,
这二项应该是输出使能对应到脚上,我改成Disable,完全不影响PWM输出!!!!!!
此帖出自stm32/stm8论坛
你怎么改的?  详情 回复 发表于 2019-3-27 18:21
点赞 关注(1)
个人签名我是一头搞电子的猪,猪是一种好色的动物,猪八戒就是代表.
4008
你怎么改的?
此帖出自stm32/stm8论坛
613
此贴请忽略,我已发现原因,涉及到后面程序,
此帖出自stm32/stm8论坛
