此帖出自模拟电子论坛
lesson learn:
"Protecting Off-Amps" by John Ardizzoni
Strangely enough, most of the off-amp questions I receive do involve a voltage—but not the supply voltage. The voltage of interest is usually a voltage applied to either an input or output of the off-amp. To save power, users will selectively shut down certain parts of their systems. This often results in voltages being applied to un-powered parts of the system. Users are typically interested in knowing how the off-amp will react to this errant voltage, and what precautions they must take to ensure the safety of the off-amp.
Getting to the bottom of off-amp questions can be challenging, with many factors that must be taken into account. The amplifier type, peripheral circuitry, and input and output voltages are all important. The best way to protect an off-amp is to ensure that the power to any circuit that touches the off-amp is off as well. If that’s not possible, then make sure to limit the current entering the off-amp. Always check with the applications engineer if you need additional help.
芯片规格书中的原理框图应该是不会把完整的电路画出来,所以出现这种不可预知的结果也就成为一种可能,看来我们只能惹不起就躲得起了。
详情
发表于 2018-11-7 14:47
YesWatt艺瓦特电子科技有限公司 傻大粗电源转换器制造商 https://apu5ob0ydv0ysskfm03hs4dtqfr97j68.taobao.com/ |
此帖出自模拟电子论坛
点评 | ||
此帖出自模拟电子论坛
