对Follow me4项目的过往进行总结
因为是第一次应用树莓派的RP2040,很多地方比较生疏,所以选择了最为官方推荐的方案 W5500-EVB-Pico、 Adafruit Sharp Memory Display,跟在大家的后面,一起学习进步。
这次收获满满,认识了RP2040,了解了micro python和circuit python编程的方便,更是学到了许多TCP/IP相关的知识,收益颇丰!
汇总视频:
202402181614
一、入门任务:
1、开发环境搭建,这里选择了micro python和circuit python进行后续工作,刷写固件也很方便
fm4_mv-1
2、LED灯BLINK闪闪,驱动液晶显示器进行显示
【得捷电子Follow me第4期】入门任务-开箱-开发环境搭建-BLINK - DigiKey得捷技术专区 - 电子工程世界-论坛 (eeworld.com.cn)
import machine
import time
# 初始化LED引脚为输出模式
led = machine.Pin('LED', machine.Pin.OUT)
while True:
# 点亮LED
led.on()
time.sleep(1) # 等待1秒钟
# 熄灭LED
led.off()
3、驱动sharp的lcd屏幕,显示信息
【得捷电子Follow me第4期】入门任务->基础任务一 - DigiKey得捷技术专区 - 电子工程世界-论坛 (eeworld.com.cn)
import sys
import time
import board
import digitalio
import busio
import adafruit_sharpmemorydisplay
# 打印输入到stdout
print("start:xxx")
# 初始化LED引脚
led = digitalio.DigitalInOut(board.GP25)
led.direction = digitalio.Direction.OUTPUT
# Initialize SPI bus and control pins
spi = busio.SPI(board.GP14, MOSI=board.GP15)
scs = digitalio.DigitalInOut(board.GP13) # inverted chip select
# pass in the display size, width and height, as well
# display = adafruit_sharpmemorydisplay.SharpMemoryDisplay(spi, scs, 96, 96)
display = adafruit_sharpmemorydisplay.SharpMemoryDisplay(spi, scs, 144, 168)
print("Pixel test")
# Clear the display. Always call show after changing pixels to make the display
# update visible!
display.fill(1)
display.show()
# Set a pixel in the origin 0,0 position.
display.pixel(0, 0, 0)
# Set a pixel in the middle position.
display.pixel(display.width // 2, display.width // 2, 0)
# Set a pixel in the opposite corner position.
display.pixel(display.width - 1, display.height - 1, 0)
display.show()
time.sleep(2)
print("Lines test")
# we'll draw from corner to corner, lets define all the pair coordinates here
corners = (
(0, 0),
(0, display.height - 1),
(display.width - 1, 0),
(display.width - 1, display.height - 1),
display.fill(1)
for corner_from in corners:
for corner_to in corners:
display.line(corner_from[0], corner_from[1], corner_to[0], corner_to[1], 0)
display.show()
time.sleep(2)
print("Rectangle test")
display.fill(1)
w_delta = display.width / 10
h_delta = display.height / 10
for i in range(11):
display.rect(0, 0, int(w_delta * i), int(h_delta * i), 0)
display.show()
time.sleep(2)
print("Text test")
display.fill(1)
display.text(" hello world!", 0, 0, 0)
display.text(" This is the", 0, 8, 0)
display.text(" CircuitPython", 0, 16, 0)
display.text("adafruit library", 0, 24, 0)
display.text(" for the SHARP", 0, 32, 0)
display.text(" Memory Display :) ", 0, 40, 0)
display.show()
# 循环使能LED点亮
while True:
# 点亮LED
led.value = True
time.sleep(1)
led.value = False
time.sleep(1)
cb31256870ea5d56a1dedf6a911c69a4
二、基础任务一
完成主控板W5500初始化(静态IP配置),并能使用局域网电脑ping通,同时W5500可以ping通互联网站点;通过抓包软件(Wireshark、Sniffer等)抓取ping报文析。
import board
import busio
import digitalio
import time
from adafruit_wiznet5k.adafruit_wiznet5k import WIZNET5K
##SPI0
SPI0_SCK = board.GP18
SPI0_TX = board.GP19
SPI0_RX = board.GP16
SPI0_CSn = board.GP17
##reset
W5x00_RSTn = board.GP20
print("Wiznet5k Ping Test (no DHCP)")
# Setup your network configuration below
# random MAC, later should change this value on your vendor ID
MY_MAC = (0x00, 0x01, 0x02, 0x03, 0x04, 0x05)
IP_ADDRESS = (192, 168, 1, 100)
SUBNET_MASK = (255, 255, 255, 0)
GATEWAY_ADDRESS = (192, 168, 1, 1)
DNS_SERVER = (8, 8, 8, 8)
ethernetRst = digitalio.DigitalInOut(W5x00_RSTn)
ethernetRst.direction = digitalio.Direction.OUTPUT
# For Adafruit Ethernet FeatherWing
cs = digitalio.DigitalInOut(SPI0_CSn)
# For Particle Ethernet FeatherWing
# cs = digitalio.DigitalInOut(board.D5)
spi_bus = busio.SPI(SPI0_SCK, MOSI=SPI0_TX, MISO=SPI0_RX)
# Reset W5500 first
ethernetRst.value = False
time.sleep(1)
ethernetRst.value = True
# Initialize ethernet interface with DHCP
# eth = WIZNET5K(spi_bus, cs)
# Initialize ethernet interface without DHCP
eth = WIZNET5K(spi_bus, cs, is_dhcp=False, mac=MY_MAC)
# Set network configuration
eth.ifconfig = (IP_ADDRESS, SUBNET_MASK, GATEWAY_ADDRESS, DNS_SERVER)
print("Chip Version:", eth.chip)
print("MAC Address:", [hex(i) for i in eth.mac_address])
print("My IP address is:", eth.pretty_ip(eth.ip_address))
while True:
led.value = not led.value
time.sleep(1)
print("Done!")
设置静态IP:
同一路由下,本机的IP为192.168.1.33,然后在CMD中使用ping 192, 168, 1, 100完成静态IP的ping
fm4_mv2
三、基础任务二
主控板建立TCP/IP或UDP服务器,使用TCP/IP或UDP客户端进行连接与发送数据,主控板接收数据并显示,通过抓包软件抓取交互报文
【得捷电子Follow me第4期】基础任务二-TCP server和UDP server - DigiKey得捷技术专区 - 电子工程世界-论坛 (eeworld.com.cn)
3.1、TCP Server
将pico+W5500通过网线接到路由或者交换机上,这里主机地址是192.168.31.171
将pico+W5500配置为192.168.31.100,端口号2233
import board
import busio
import digitalio
import time
import array
import adafruit_wiznet5k.adafruit_wiznet5k_socket as socket
'''LED init'''
'''Sharp Display init'''
'''W5500 init start'''
##SPI0-W5500
##reset
print("Wiznet5k Simple TCP Server Test")
#MY_MAC = (0x00, 0x01, 0x02, 0x03, 0x04, 0x05)
IP_ADDRESS = (192, 168, 31, 100)
SUBNET_MASK = (255, 255, 0, 0)
GATEWAY_ADDRESS = (192, 168, 31, 1)
# Reset W5500 first
time.sleep(1)
# # Initialize ethernet interface without DHCP
eth = WIZNET5K(spi_bus, cs, is_dhcp=False)#, mac=MY_MAC, debug=True)
# # Set network configuration
#eth = WIZNET5K(spi_bus, cs, is_dhcp=True, mac=MY_MAC, debug=True)
'''W5500 init end'''
'''TCP socket init'''
# Initialize a socket for our server
socket.set_interface(eth)
server = socket.socket() # Allocate socket for the server
server_ip = None # IP address of server
server_port = 2233 # Port to listen on
server.bind((server_ip, server_port)) # Bind to IP and Port
server.listen() # Begin listening for incoming clients
#conn, addr = server.accept() # Wait for a connection from a client.
#print("socket connected")
'''display show'''
display.fill(1)
chip_version = "chip version:" + eth.chip
display.text(chip_version, 0, 0, 0)
ip_addr = "ip:" + eth.pretty_ip(eth.ip_address)
display.text(ip_addr, 0, 10, 0)
mac_addr = "mac:" + eth.pretty_mac(eth.mac_address)
display.text(mac_addr, 0, 20, 0)
display.show()
row = 30
while True:
# Maintain DHCP lease
#eth.maintain_dhcp_lease()
time.sleep(1)
with server:
while True:
# data = conn.recv(20)
data,addr = server.recvfrom(20)
if data:
print(data)
display.fill_rect(0,row,144,10,1)
display.text(data.decode('utf-8'), 0, row, 0)
display.show()
row += 10
if row > 150:
row = 30
fm4_mv3
LCD显示传输数据
ae7b4388745ec0c4bc29440cfa7e98d2
3.2、UDP Server
import board
import busio
import digitalio
import time
import array
'''LED init'''
##SPI0-W5500
##reset
print("Wiznet5k Simple UDP Server Test")
# Reset W5500 first
time.sleep(1)
'''UDP socket init'''
server = socket.socket(socket.AF_INET, socket.SOCK_DGRAM) # Allocate socket for the server
server.bind((eth.pretty_ip(eth.ip_address), server_port)) # Bind to IP and Port
'''display show'''
display.fill(1)
display.show()
row = 30
while True:
time.sleep(1)
with server:
while True:
if data:
print(data)
display.show()
row += 10
if row > 150:
row = 30
server.send(data)
#conn.send(data) # Echo message back to client
四、进阶任务
从NTP服务器(注意数据交互格式的解析)同步时间,获取时间送显示屏(串口)显示
【得捷电子Follow me第4期】进阶任务-NTP同步时间 - DigiKey得捷技术专区 - 电子工程世界-论坛 (eeworld.com.cn)
基于socket的示例,导入adafruit的ntp库,进行时间的获取与同步,import adafruit_ntp
import board
import busio
import digitalio
import time
import array
import struct
import adafruit_requests as requests
from adafruit_wiznet5k.adafruit_wiznet5k import *
from adafruit_wiznet5k.adafruit_wiznet5k_ntp import NTP
import adafruit_wiznet5k.adafruit_wiznet5k_dns as dns
import adafruit_ntp
days = ("Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday")
##SPI0
##reset
print("Wiznet5k NTP Client (DHCP)")
MY_MAC = (0x00, 0x01, 0x02, 0xFF, 0xFF, 0xFF)
IP_ADDRESS = (192, 168, 1, 24)
port = 5000
ntp_server_port= 123
# Reset W5500 first
time.sleep(1)
#eth = WIZNET5K(spi_bus, cs, is_dhcp=False, mac=MY_MAC, debug=False)
eth = WIZNET5K(spi_bus, cs, is_dhcp=True, mac=MY_MAC, debug=False)
ntp = adafruit_ntp.NTP(socket)
print(ntp.datetime)
通过串口打印出相关信息和+8后的时间:2024.2.16.23:59:44
fm4_mv5
终极任务二
终极任务是使用外部存储器,组建简易FTP文件服务器,并能正常上传下载文件。
【得捷电子Follow me第4期】终极任务+总结 - DigiKey得捷技术专区 - 电子工程世界-论坛 (eeworld.com.cn)
这里借鉴并学习了其他小伙伴做的基于micropython的FTP服务器
import socket
import network
import uos
import gc
from time import localtime
from machine import Pin,SPI
import time
def w5x00_init():
#spi init
spi=SPI(0,2_000_000, mosi=Pin(19),miso=Pin(16),sck=Pin(18))
nic = network.WIZNET5K(spi,Pin(17),Pin(20)) #spi,cs,reset pin
nic.active(True)#network active
nic.ifconfig(('192.168.1.100','255.255.255.0','192.168.1.1','8.8.8.8'))#Set static network address information
while not nic.isconnected():
time.sleep(1)
print(nic.regs())#Print register information
#Print network address information
print("IP Address:",nic.ifconfig()[0])
print("Subnet Mask:",nic.ifconfig()[1])
print("Gateway:",nic.ifconfig()[2])
print("DNS:",nic.ifconfig()[3])
return nic
month_name = ["", "Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"]
def send_list_data(path, dataclient, full):
try: # whether path is a directory name
for fname in uos.listdir(path):
dataclient.sendall(make_description(path, fname, full))
except: # path may be a file name or pattern
pattern = path.split("/")[-1]
path = path[:-(len(pattern) + 1)]
if path == "": path = "/"
if fncmp(fname, pattern) == True:
def make_description(path, fname, full):
if full:
stat = uos.stat(get_absolute_path(path,fname))
file_permissions = "drwxr-xr-x" if (stat[0] & 0o170000 == 0o040000) else "-rw-r--r--"
file_size = stat[6]
tm = localtime(stat[7])
if tm[0] != localtime()[0]:
description = "{} 1 owner group {:>10} {} {:2} {:>5} {}\r\n".format(
file_permissions, file_size, month_name[tm[1]], tm[2], tm[0], fname)
else:
description = "{} 1 owner group {:>10} {} {:2} {:02}:{:02} {}\r\n".format(
file_permissions, file_size, month_name[tm[1]], tm[2], tm[3], tm[4], fname)
else:
description = fname + "\r\n"
return description
def send_file_data(path, dataclient):
with open(path, "r") as file:
chunk = file.read(512)
while len(chunk) > 0:
dataclient.sendall(chunk)
def save_file_data(path, dataclient, mode):
with open(path, mode) as file:
chunk = dataclient.read(512)
file.write(chunk)
def get_absolute_path(cwd, payload):
# Just a few special cases "..", "." and ""
# If payload start's with /, set cwd to /
# and consider the remainder a relative path
if payload.startswith('/'):
cwd = "/"
for token in payload.split("/"):
if token == '..':
if cwd != '/':
cwd = '/'.join(cwd.split('/')[:-1])
if cwd == '':
cwd = '/'
elif token != '.' and token != '':
if cwd == '/':
cwd += token
else:
cwd = cwd + '/' + token
return cwd
# compare fname against pattern. Pattern may contain
# wildcards ? and *.
def fncmp(fname, pattern):
pi = 0
si = 0
while pi < len(pattern) and si < len(fname):
if (fname[si] == pattern[pi]) or (pattern[pi] == '?'):
si += 1
pi += 1
else:
if pattern[pi] == '*': # recurse
if (pi + 1) == len(pattern):
return True
while si < len(fname):
if fncmp(fname[si:], pattern[pi+1:]) == True:
return True
else:
si += 1
return False
else:
return False
if pi == len(pattern.rstrip("*")) and si == len(fname):
return True
else:
return False
def ftpserver():
DATA_PORT = 13333
ftpsocket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
datasocket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
ftpsocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
datasocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
ftpsocket.bind(socket.getaddrinfo("0.0.0.0", 21)[0][4])
datasocket.bind(socket.getaddrinfo("0.0.0.0", DATA_PORT)[0][4])
ftpsocket.listen(1)
datasocket.listen(1)
datasocket.settimeout(10)
msg_250_OK = '250 OK\r\n'
msg_550_fail = '550 Failed\r\n'
try:
dataclient = None
fromname = None
while True:
cl, remote_addr = ftpsocket.accept()
cl.settimeout(300)
cwd = '/'
try:
# print("FTP connection from:", remote_addr)
cl.sendall("220 Hello, this is the ESP8266.\r\n")
while True:
gc.collect()
data = cl.readline().decode("utf-8").rstrip("\r\n")
if len(data) <= 0:
print("Client disappeared")
break
command = data.split(" ")[0].upper()
payload = data[len(command):].lstrip()
path = get_absolute_path(cwd, payload)
print("Command={}, Payload={}, Path={}".format(command, payload, path))
if command == "USER":
cl.sendall("230 Logged in.\r\n")
elif command == "SYST":
cl.sendall("215 UNIX Type: L8\r\n")
elif command == "NOOP":
cl.sendall("200 OK\r\n")
elif command == "FEAT":
cl.sendall("211 no-features\r\n")
elif command == "PWD":
cl.sendall('257 "{}"\r\n'.format(cwd))
elif command == "CWD":
try:
files = uos.listdir(path)
cwd = path
cl.sendall(msg_250_OK)
except:
cl.sendall(msg_550_fail)
elif command == "CDUP":
cwd = get_absolute_path(cwd, "..")
elif command == "TYPE":
# probably should switch between binary and not
cl.sendall('200 Transfer mode set\r\n')
elif command == "SIZE":
try:
size = uos.stat(path)[6]
cl.sendall('213 {}\r\n'.format(size))
except:
elif command == "QUIT":
cl.sendall('221 Bye.\r\n')
break
elif command == "PASV":
addr = nic.ifconfig()[0]
cl.sendall('227 Entering Passive Mode ({},{},{}).\r\n'.format(
addr.replace('.',','), DATA_PORT>>8, DATA_PORT%256))
dataclient, data_addr = datasocket.accept()
# print("FTP Data connection from:", data_addr)
elif command == "LIST" or command == "NLST":
if not payload.startswith("-"):
place = path
else:
place = cwd
try:
send_list_data(place, dataclient, command == "LIST" or payload == "-l")
cl.sendall("150 Here comes the directory listing.\r\n")
cl.sendall("226 Listed.\r\n")
except:
if dataclient is not None:
dataclient.close()
dataclient = None
elif command == "RETR":
try:
cl.sendall("150 Opening data connection.\r\n")
cl.sendall("226 Transfer complete.\r\n")
except:
dataclient.close()
dataclient = None
elif command == "STOR":
try:
cl.sendall("150 Ok to send data.\r\n")
save_file_data(path, dataclient, "w")
except:
dataclient.close()
dataclient = None
elif command == "APPE":
try:
save_file_data(path, dataclient, "a")
except:
dataclient.close()
dataclient = None
elif command == "DELE":
try:
uos.remove(path)
except:
elif command == "RMD":
try:
uos.rmdir(path)
except:
elif command == "MKD":
try:
uos.mkdir(path)
except:
elif command == "RNFR":
fromname = path
cl.sendall("350 Rename from\r\n")
elif command == "RNTO":
if fromname is not None:
try:
uos.rename(fromname, path)
except:
else:
fromname = None
else:
cl.sendall("502 Unsupported command.\r\n")
# print("Unsupported command {} with payload {}".format(command, payload))
except Exception as err:
print(err)
finally:
cl.close()
cl = None
finally:
datasocket.close()
ftpsocket.close()
dataclient.close()
nic = w5x00_init()
ftpserver()
fm4_mv6
整个Follow me第四期下来,收获满满,自己作为小白,首先把pico裸机的外设端口学习了一遍,接着摸索着点亮了sharp的LCD屏幕,显示的那一瞬满是开心,也许电子这一行的快乐可能就是调通的那一刹那,后面在TCP/IP这块,配合着WiFi那块板子的调试进度,对client和servers有了更进一步的认知,在这块是真的学到了些许东西;最后的FTP服务器,自己没搞定,学习了论坛其他小伙伴的程序,后续随着自己的学习不断完善;
最后,谢谢得捷和EEworld的组织的这次活动,和给予的这次参与机会,组织的很棒。以后我会多加关注,积极参加论坛活动,多方面提升个人的知识,与大家一同进步,加油!
