8161|21
87
终于点亮了我的LCD显示器,1024*768@60Hz,verilog语言,EP2C8,全部源码 [复制链接]
昨天几乎一晚没睡,参考了很多代码,现在只是点亮了,没进行美化,我是新手,大家别拍砖,呵呵。
module vga(
clock,
switch,
disp_RGB,
hsync,
vsync
input clock; //系统输入时钟
input [1:0]switch;
output  [2:0]disp_RGB; //VGA数据输出
//disp_RGB[0]:蓝
//disp_RGB[1]:红
//disp_RGB[2]:绿
output hsync; //VGA行同步信号
output vsync; //VGA场同步信号
reg [11:0] hcount; //VGA行扫描计数器
reg [11:0]  vcount; //VGA场扫描计数器
reg [2:0]   data;
reg [2:0] h_dat;
reg [2:0]   v_dat;
wire dat_act;
wire hsync;
wire  vsync;
//VGA行、场扫描时序参数表
parameter //1024*768@60Hz//65M
h_Front_porch = 12'd24,
h_Sync_pulse  = 12'd136,
h_Back_porch = 12'd160,
Whole_line    = 12'd1344,
v_Front_porch = 12'd3,
v_Sync_pulse = 12'd6,
v_Back_porch = 12'd29,
Whole_frame = 12'd806;
//************************VGA驱动部分*******************************
//行场扫描
//行扫描 hcount 从0开始计数到 Whole_line
//场扫描 vcount 从0开始计数到 Whole_frame
always @(posedge clock)
begin
// if (hcount == Whole_line) //行扫描计数到Whole line
if (hcount == 12'd1344) //行扫描计数到Whole line
begin
hcount <= 1'd0;
// if (vcount == Whole_frame) //场扫描计数到Whole frame
if (vcount == 12'd806) //场扫描计数到Whole frame
vcount <= 1'd0;
else
vcount <= vcount + 1'd1;
end
else
begin
hcount <= (hcount + 1'd1);
end
end
//同步信号输出
reg hsync_r,vsync_r;
begin
hsync_r <= (hcount > h_Sync_pulse);
vsync_r <= (vcount > v_Sync_pulse);
end
assign hsync = hsync_r;//产生行同步信号(低电平)
assign vsync = vsync_r;//产生场同步信号(低电平)
//数据输出
assign dat_act =    ((hcount >= (h_Sync_pulse + h_Back_porch)) && (hcount < (Whole_line - h_Front_porch)))
&& ((vcount >= (v_Sync_pulse + v_Back_porch)) && (vcount < (Whole_frame - v_Front_porch)));
assign disp_RGB = (dat_act) ?  data : 3'h00;
//************************显示数据处理部分*******************************
begin
case(switch[1:0])
2'd0: data <= h_dat;    //选择横彩条
2'd1: data <= v_dat;    //选择竖彩条
2'd2: data <= (v_dat ^ h_dat); //产生棋盘格
2'd3: data <= (v_dat ~^ h_dat); //产生棋盘格
endcase
end
always @(posedge clock) //产生竖彩条
begin
if(hcount < 223)
v_dat <= 3'h7;     //白
else if(hcount < 303)
v_dat <= 3'h6; //黄
else if(hcount < 383)
v_dat <= 3'h5; //青
else if(hcount < 463)
v_dat <= 3'h4;   //绿
else if(hcount < 543)
v_dat <= 3'h3; //紫
else if(hcount < 623)
v_dat <= 3'h2; //红
else if(hcount < 703)
v_dat <= 3'h1; //蓝
else
v_dat <= 3'h0; //黑
end
always @(posedge clock) //产生横彩条
begin
if(vcount < 94)
h_dat <= 3'h7;        //白
else if(vcount < 154)
h_dat <= 3'h6; //黄
else if(vcount < 214)
h_dat <= 3'h5; //青
else if(vcount < 274)
h_dat <= 3'h4;   //绿
else if(vcount < 334)
h_dat <= 3'h3; //紫
else if(vcount < 394)
h_dat <= 3'h2; //红
else if(vcount < 454)
h_dat <= 3'h1; //蓝
else
h_dat <= 3'h0; //黑
end
endmodule
此帖出自FPGA/CPLD论坛
TFT有些惧怕啊,一直没玩过  详情 回复 发表于 2013-5-17 19:51
32
学习学习
此帖出自FPGA/CPLD论坛
325
裸片初长成(初级)
很不错的帖子哈
此帖出自FPGA/CPLD论坛
个人签名科技应该让生活变得更简单!
515
确实不错,精神值得学习啊,对我们也有激励作用,不错,谢谢@@@
此帖出自FPGA/CPLD论坛
1860
支持,一定支持,我是专门来顶的
此帖出自FPGA/CPLD论坛
个人签名有目的的学习是最有效的学习!
5968
ding~~~~~
此帖出自FPGA/CPLD论坛
269
精神不错,鼓励一下。
此帖出自FPGA/CPLD论坛
学习
学习
此帖出自FPGA/CPLD论坛
7249
192
MARK  正好要学啊
此帖出自FPGA/CPLD论坛
65
看看
此帖出自FPGA/CPLD论坛
107
楼主强人呢,谦虚了吧?呵呵
此帖出自FPGA/CPLD论坛
6892
楼主很谦虚啊!
此帖出自FPGA/CPLD论坛
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
用电脑vga信号点的吧!
此帖出自FPGA/CPLD论坛
269
好东西,顶起
此帖出自FPGA/CPLD论坛
个人签名一个人,一本书,一杯茶,一帘梦。
6892
学习楼主精神!
此帖出自FPGA/CPLD论坛
欢迎光临网上店铺!
234
恭喜楼主啊!
此帖出自FPGA/CPLD论坛
个人签名努力就有不清不楚的收获。
67
最近刚开始弄FPGA,后续也要试试点亮LCD
此帖出自FPGA/CPLD论坛
很有参考价值啊~
此帖出自FPGA/CPLD论坛
384
顶一个
此帖出自FPGA/CPLD论坛
这个对我来说是乱码啊~~
此帖出自FPGA/CPLD论坛
