4896|2
32
上个老外的开源虚拟示波器 [复制链接]
Simultaneous analog/digital capture
100 MHz sub-sampling bandwidth
50 Ms/s logic sample rate (max)
40 Ms/s analog sample rate (max)
20 MHz single-shot bandwidth
4 analog inputs (multiplexed)
2 inputs via BNC (buffered 1Meg)
2 inputs via DB25 POD
8 logic inputs via DB25 POD
Two 32K x 8 capture buffers
Sophisticated triggers (analog or digital)
10 MHz arbitrary waveform generator
Fully programmable using ASCII "scripts"
Simple virtual machine programming
Optional A/D convertor modules
Expansion POD for external devices
Low cost PIC 16F628 design
All logic in a single PLD
115 kb/s Serial Interface or
625 kb/s 10BaseT Ethernet Interface
1.25 Mb/s USB Interface
"Atomic" ASCII command set
Scalable design to >100MS/s @ 3.3V
Chipset suitable for embedded DSO
看看.......................  详情 回复 发表于 2010-2-22 14:43
32
2954
个人签名不断地学习,才会有创新!
淘宝小店:手机、qq点卡、游戏点卡自动充值 http://shop63727265.taobao.com/
有奖直播 | AI之眼——安森美图像传感器 报名中
直播主题:AI之眼——安森美图像传感器
报名观看直播、直播间提问、填写问卷均有机会获得精美礼品!
