3750|4
105
LT9211:MIPI to Dual-Port LVDS/TTL Converter [复制链接]
需要芯片资料及技术支持联系陈S-18925229071 Q-3001603283
1. Description
The Lontium LT9211 is a high performance convertor which interconvertible between MIPI DSI/CSI-2/Dual-Port LVDS and TTL except for TTL to TTL. The LT9211 deserializes input MIPI/LVDS/TTL video data, decodes packets, and converts the formatted video data stream to MIPI/LVDS/TTL transmitter output between AP and mobile display panel or camera.
The LT9211 can be used as 2-Port MIPI/LVDS Repeater which support maximum 14dB input equalization and programmable pre-emphasis to improve performance.
The LT9211 can also be used as MIPI/LVDS Muxer andSplitter.
The LT9211 is fabricated in advanced CMOS process and implemented in 7.5x7.5mm QFN64 package. This package is RoHS compliant and specified to operate from -40°C to +85°C.
2. Features
• Dual-Port LVDS Transimitter
• MIPI Transmitter
• TTL Output
• Dual-Port LVDS Receiver
• TTL Intput
• Single-Port MIPI Receiver
• Miscellaneous
3. Applications
• Mobile systems
• Cellular handsets
• Digital still cameras
• Digital  video cameras
• Tablet PC, Notebook PC
• Car Display and Camera System
深圳市亿旸科技有限公司LT9211现货特供,提供技术支持! 联系方式:朱先生13714033198  18126125171 QQ:709365451 LT9211转换 (MIPI/TTL/2-Port LVDS o to MIPI/TTL/2-Port LVDS) ★LT9211转换功能强大: 支持 MIPI to LVDS、LVDS to MIPI、MIPI to TTL、TTL to MIPI; 支持 TTL to 2Port-LVDS、2Port LVDS to TTL; 支持 1 Port LVDS to 2Port-LVDS、2 Port LVDS to 1Port-LVDS; 支持 1 Port MIPI to 2Port MIPI、2 Port MIPI to 1Port MIPI。 (以上仅支持输入视频信号同源) ★LT9211 是一种高性能转换器,在 MIPI-DSI/CSI-2 双端口之间可以相互转换 LVDS 和 TTL,除了 24 位TTL 到 24 位 TTL 同步和反序列化,LT9211 反序列化输入 MIPI/LVDS/TTL 视频数据,解码数据包,以及将视频流转换为格式化的视频AP和mobile之间的MIPI/LVDS/TTL发射机输出显示面板或摄像头。LT9211可作为 2 端口 MIPI/LVDS 中继器使用支持最大输入 14dB 可编程预加重以提高性能。LT9211 还可以用作 MIPI/LVDS 复用和拆分器。  详情 回复 发表于 2021-1-19 16:36
105
优势出货LT9211
105
GM8775C: MIPI DSI 转双LVDS,有技术支持,性价格更高,已大批量出货,欢迎来了解
26
