7565|6
131
自己写的 mini2440 控制步进电机(IO口或者LED)的驱动程序+测试程序,欢迎大家批评 [复制链接]
测试程序如下
#include
#include
#include
#include
int main(int argc, char **argv)
{     int step1[]={0,0,0,1,0,0,1,0,0,1,0,0,1,0,0,0};
      int step2[]={};
int step3[]={};
int step4[]={};
int on,i;
int led_no;
int fd;
/*if (argc != 3 || sscanf(argv[1], "%d", &led_no) != 1 || sscanf(argv[2],"%d", &on) != 1 ||
     on < 0 || on > 1 || led_no < 0 || led_no > 3) {
  fprintf(stderr, "Usage: leds led_no 0|1\n");
  exit(1);
fd = open("/dev/stepmotor0", 0);
if (fd < 0) {
  fd = open("/dev/stepmotor", 0);
if (fd < 0) {
  perror("open device stepmotor");
  exit(1);
while(1)
for(i=0;i<4;i++)
ioctl(fd, step1[0+i], 0);
ioctl(fd, step1[4+i], 1);
ioctl(fd, step1[8+i], 2);
ioctl(fd, step1[12+i], 3);
usleep(500*1000);
close(fd);
return 0;
驱动程序如下:
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#define DEVICE_NAME "stepmotor"
static unsigned long led_table [] = {
S3C2410_GPF0,
S3C2410_GPF1,
S3C2410_GPF2,
S3C2410_GPF3,
static unsigned int led_cfg_table [] = {
S3C2410_GPF0_OUTP,
S3C2410_GPF1_OUTP,
S3C2410_GPF2_OUTP,
S3C2410_GPF3_OUTP,
static int sbc2440_leds_ioctl(
struct inode *inode,
struct file *file,
unsigned int cmd,
unsigned long arg)
switch(cmd) {
case 0:
case 1:
  if (arg > 4) {
   return -EINVAL;
  s3c2410_gpio_setpin(led_table[arg], !cmd);
  return 0;
default:
  return -EINVAL;
static struct file_operations dev_fops = {
.owner = THIS_MODULE,
.ioctl = sbc2440_leds_ioctl,
static struct miscdevice misc = {
.minor = MISC_DYNAMIC_MINOR,
.name = DEVICE_NAME,
.fops = &dev_fops,
static int __init dev_init(void)
int ret;
int i;
for (i = 0; i < 4; i++) {
  s3c2410_gpio_cfgpin(led_table, led_cfg_table);
  s3c2410_gpio_setpin(led_table, 0);
ret = misc_register(&misc);
printk (DEVICE_NAME"\tinitialized\n");
return ret;
static void __exit dev_exit(void)
misc_deregister(&misc);
module_init(dev_init);
module_exit(dev_exit);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("Andrew");
你可以先找个开发板一先实现简单的程序,了解一下! 你可以先不了解系统,先裸跑学习基本功能及特性!  详情 回复 发表于 2009-12-23 08:28
131
有兴趣的跟帖 我会把我所经历的问题说出来 给新手们参考!
130
听课。
个人签名就这样看着你慢慢离去.......
2131
至上芯片
我支持楼主,大家一起和你学习!
继续努力!
个人签名处处留心皆学问!
131
论坛的群 85824260
大家积极发言啊 前辈们也多多指教咱们新来的 哈哈
共同提高吧 呵呵
2112
裸片初长成(初级)
我以前没接触过arm
但是现在想自己学学
不知怎么上手啊
2131
至上芯片
回复 6楼 heningbo 的帖子
鏌ョ湅鏈笘鍏ㄩ儴璁ㄨ锛岃鐧诲綍鎴栬€�娉ㄥ唽
个人签名处处留心皆学问!
【TI有奖直播报名中】
直播时间:4月24日(周四)上午10:00
直播奖励:好礼等您拿!
