3326|2
请问工控用的M27C4002和X28HC64是属于哪个板块的? [复制链接]
我要重点研究这两个程序芯片
多谢!!
先上两个datasheet The M27C4002 is a 4 Mbit EPROM offered in the two ranges UV (ultra violet erase) and OTP (one time programmable). It is ideally suited for microprocessor systems requiring large programs and is organised as 262,144 words of 16 bits. [attach]16546[/attach] The X28HC64 is an 8K x 8 E2PROM, fabricated with Xicor’s proprietary, high performance, floating gate CMOS technology. Like all Xicor programmable nonvolatile memories the X28HC64 is a 5V only device. The X28HC64 features the JEDEC approved pinout for bytewide memories, compatible with industry standard RAMs. ——XICOR [attach]16548[/attach] The X28HC64 is an 8K x 8 EEPROM, fabricated with Intersil’s proprietary, high performance, floating gate CMOS technology. Like all Intersil programmable nonvolatile memories, the X28HC64 is a 5V only device. It features the JEDEC approved pinto for byte-wide memories, compatible with industry standard RAMs. ——intersil [attach]16547[/attach]  详情 回复 发表于 2009-4-17 16:41
Re: [求助] 请问工控用的M27C4002和X28HC64是属于哪个板块的?
谁有这两个芯片的介绍资料或者是程序资料
我看下
学习啊
交流啊
565
513
裸片初长成(中级)
先上两个datasheet
M27C4002-12F1.pdf (234.33 KB, 下载次数: 11)
——XICOR
datasheet.pdf (114.24 KB, 下载次数: 5)
——intersil
datasheet_intersil.pdf (309.7 KB, 下载次数: 4)
【TI有奖直播报名中】
直播时间:4月24日(周四)上午10:00
直播奖励:好礼等您拿!
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 13
