求问各位大佬,TI的例程程序中电流采样的问题,程序如下,如下红色部分,这个跟0x8000进行异或之后,产生了0x8000--0x7FF0之间的数,但是这么处理后,好像就直接转化成了IQ(-1)~IQ(1)之间的值是,那么如何进行电流解算的呢,程序中为什么没有写电流值是多少,就直接转化成了IQ(-1)~IQ(1)之间的值,我要反解算电流,应该怎么处理呢?
#include "DSP281x_Device.h"
#include "f281xileg.h"
#define CPU_CLOCK_SPEED 6.6667L // for a 150MHz CPU clock speed
#define ADC_usDELAY 5000L
#define DELAY_US(A) DSP28x_usDelay(((((long double) A * 1000.0L) / (long double)CPU_CLOCK_SPEED) - 9.0L) / 5.0L)
extern void DSP28x_usDelay(unsigned long Count);
void F281X_ileg2_drv_init(ILEG2MEAS *p)
DELAY_US(ADC_usDELAY);
AdcRegs.ADCTRL1.all = ADC_RESET_FLAG; // Reset the ADC Module
asm(" NOP ");
asm(" NOP ");
AdcRegs.ADCTRL3.bit.ADCBGRFDN = 0x3; // Power up bandgap/reference circuitry
DELAY_US(ADC_usDELAY); // Delay before powering up rest of ADC
AdcRegs.ADCTRL3.bit.ADCPWDN = 1; // Power up rest of ADC
AdcRegs.ADCTRL3.bit.ADCCLKPS = 6; // Set up ADCTRL3 register
AdcRegs.ADCTRL1.all = ADCTRL1_INIT_STATE_ILEG2; // Set up ADCTRL1 register
AdcRegs.ADCTRL2.all = ADCTRL2_INIT_STATE_ILEG2; // Set up ADCTRL2 register
AdcRegs.ADCMAXCONV.bit.MAX_CONV1 = 1; // Specify two conversions
AdcRegs.ADCCHSELSEQ1.all = p->ChSelect; // Configure channel selection
EvaRegs.GPTCONA.bit.T1TOADC = 1; // Set up EV Trigger with Timer1 UF
void F281X_ileg2_drv_read(ILEG2MEAS *p)
int16 DatQ15;
int32 Tmp;
// Wait until ADC conversion is completed
while (AdcRegs.ADCST.bit.SEQ1_BSY == 1)
DatQ15 = AdcRegs.ADCRESULT0^0x8000; // Convert raw result to Q15 (bipolar signal)
Tmp = (int32)p->ImeasAGain*(int32)DatQ15; // Tmp = gain*dat => Q28 = Q13*Q15
p->ImeasA = (int16)(Tmp>>13); // Convert Q28 to Q15
p->ImeasA += p->ImeasAOffset; // Add offset
p->ImeasA *= -1; // Positive direction, current flows to motor
DatQ15 = AdcRegs.ADCRESULT1^0x8000; // Convert raw result to Q15 (bipolar signal)
Tmp = (int32)p->ImeasBGain*(int32)DatQ15; // Tmp = gain*dat => Q28 = Q13*Q15
p->ImeasB = (int16)(Tmp>>13); // Convert Q28 to Q15
p->ImeasB += p->ImeasBOffset; // Add offset
p->ImeasB *= -1; // Positive direction, current flows to motor
p->ImeasC = -(p->ImeasA + p->ImeasB); // Compute phase-c current
AdcRegs.ADCTRL2.all |= 0x4040; // Reset the sequence
