6035|2
请教:用迅为4412开发板开机时卡在Android静止画面 [复制链接]
个未先进好我使用身边的4412版子
发现开机的时候会有机会卡在Android静止画面
使用RS232接机器log后比较正常与无法开机进入的log
发现缺少执行了以下内容
因此想请教各为这段缺少的内容是执行什么样的函式呢
[    8.464643] ADB open:
[    8.470987] [HIF-SDIO][I]WMT_open:major 190 minor 0 (pid 1243)
[    8.476148] [HIF-SDIO][I]WMT_open:1st call
[    8.479738] [HIF-SDIO][I]mtk_wcn_hif_sdio_tell_chipid:set combo chip id to 0x6620
[    8.500056] [mtk_wcn_stp_set_if_tx_type] set STP_IF_TX to UART.
[    8.504506] [HIF-SDIO][I]wmt_lib_set_hif:new hifType:0, fcCtrl:0, baud:115200, fm:2
[    8.512315] [WMT-DFT][I]wmt_conf_set_cfg_file:WMT config file is set to (/system/etc/firmware//WMT.cfg)
[    8.512595] [HIF-SDIO][I]opfunc_hif_conf:WMT-CORE: WMT HIF info added
[    8.528207] [STP] mtk_wcn_stp_set_wmt_last_close:[I] set wmt_last_close flag (0)
shell@smdk4x12:/ $ [    8.960145] s3c-fimc3: FIMC3 1 opened.
[    9.231863] s3cfb s3cfb.0: [fb1] dma: 0x693ac000, cpu: 0xf1dff000, size: 0x00bb8000
[    9.245695] s3c-fimc3: FIMC3 2 opened.
[    9.351285] s3c-fimc0: FIMC0 1 opened.
[    9.353651] s3c-fimc0: FIMC0 0 released.
[   15.535389] warning: `zygote' uses 32-bit capabilities (legacy support in use)
[   18.786735] healthd: battery l=0 v=0 t=0.0 h=1 st=1 chg=
[   18.798673] request_suspend_state: wakeup (3->0) at 18798651345 (2017-11-02 06:43:50.578534925 UTC)
[   19.433954] dm9620 1-3.2:1.0: eth0: link down
[   19.441180] link_reset() speed: 10 duplex: 0
[   19.445570] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   19.591335] acc_open
[   19.592065] acc_release
[   19.603835] [MTK-WIFI] WIFI_open: WIFI_open: major 194 minor 0 (pid 1)
[   19.608939] [MTK-WIFI] WIFI_write: WIFI_write 0
[   19.613429] [MTK-WIFI] WIFI_close: WIFI_close: major 194 minor 0 (pid 1)
[   19.917680] [MTK-WIFI] WIFI_open: WIFI_open: major 194 minor 0 (pid 1)
[   19.922880] [MTK-WIFI] WIFI_write: WIFI_write 1
[   19.930328] [HIF-SDIO][I]mtk_wcn_wmt_func_ctrl:OPID(3) type(3) start
[   19.935341] [STP] mtk_wcn_stp_psm_disable:[W] STP Not Ready, Dont do Sleep/Wakeup
[   19.942822] [WMT-DFT][I]mtk_wcn_cmb_hw_pwr_on:CMB-HW, hw_pwr_on start
[   19.949228] [WMT-DFT][I]wmt_plat_pmu_ctrl:WMT-PLATMU init (out 0)
[   19.955555] [WMT-DFT][I]wmt_plat_rst_ctrl:WMT-PLAT:RST init (out 0)
[   20.080397] [MTK-WIFI] WIFI_open: WIFI_open: major 194 minor 0 (pid 1573)
[   20.170080] [WMT-DFT][I]mtk_wcn_cmb_hw_pwr_on:CMB-HW, rtc clock exported
另一段:
[   20.295294] [WMT-DFT][I]mtk_wcn_cmb_hw_pwr_on:CMB-HW, BGF_EINT IRQ registered and disabled
[   20.295304] [WMT-DFT][I]wmt_conf_read_file:WMT config file:/system/etc/firmware//WMT.cfg
[   20.295309] [WMT-DFT][I]wmt_conf_read_file:WMT config no need WMT.cfg
[   20.295532] [HIF-SDIO][I]wmt_ctrl_ul_cmd:str(open_stp) result(0)
[   20.295538] Flush type = 4 Rx Queue
[   20.295700] [HIF-SDIO][I]wmt_ctrl_ul_cmd:str(baud_115200_0) result(0)
[   20.295708] [STP] mtk_wcn_stp_enable:[I] mtk_wcn_stp_enable: set the current enable = (0)
[   20.295716] [STP-PSM] [I]_stp_psm_reset: _stp_psm_reset
[   20.295721] [STP-PSM] [I]_stp_psm_reset: reset-wake_lock(0)
[   20.295728] [STP-PSM] [I]_stp_psm_reset: reset-wake_lock(0)
[   20.295736] [STP] mtk_wcn_stp_ready:[I] set ready (0)
[   20.295742] [STP] mtk_wcn_stp_set_mode:[I] STP_SUPPORT_PROTOCOL = 00000002
[   20.295748] [STP] mtk_wcn_stp_enable:[I] mtk_wcn_stp_enable: set the current enable = (1)
[   20.295754] [STP] mtk_wcn_stp_coredump_start_ctrl:[I] set f/w assert (0)
[   20.407513] [STP-PSM] [E]_stp_psm_notify_stp(1223):ERROR! state = 0, flag = 40
[   20.419722] [HIF-SDIO][I]wmt_core_hw_check:get hwcode (chip id) (0x6620)
[   20.430096] [WMT-DFT][I]mt6620_ver_check:MT6620: read hw_ver (hw version) (0x8a11)
[   20.441348] [WMT-DFT][I]mt6620_ver_check:MT6620: read fw_ver (rom version) (0x8a10)
[   20.447562] [WMT-DFT][I]mt6620_find_wmt_ic_info:found ic info(0x8a11) by full match! index:3
[   20.456004] [WMT-DFT][I]mt6620_ver_check:MT6620: wmt ic info: MT6620.E4 (0x8a11, WMTHWVER:3, patch_ext:_e3)
[   20.465731] [HIF-SDIO][I]wmt_core_hw_check:chip id(0x6620) ver_check ok
[   20.472316] [HIF-SDIO][I]wmt_core_stp_init:pctx->p_ic_ops->co_clock_ctrl(0x0), pWmtGenConf(0xbf046218)
[   20.481595] [WMT-DFT][I]mt6620_sw_init:no Flow Control (uartFcCtrl:0)
[   20.498274] [HIF-SDIO][I]wmt_ctrl_ul_cmd:str(baud_115200_0) result(0)
[   20.503305] [WMT-DFT][I]mt6620_sw_init:WMT-CORE: change baudrate(115200) ok
[   20.519612] [STP] mtk_wcn_stp_set_mode:[I] STP_SUPPORT_PROTOCOL = 00000001
[   20.525130] [STP] mtk_wcn_stp_enable:[I] mtk_wcn_stp_enable: set the current enable = (1)
[   20.533304] [STP] mtk_wcn_stp_coredump_start_ctrl:[I] set f/w assert (0)
[   20.540117] [WMT-DFT][I]mt6620_sw_init:enable host STP-UART-FULL mode
[   20.577076] [HIF-SDIO][I]WMT_unlocked_ioctl: get patch num from launcher = 4
[   20.604175] [HIF-SDIO][I]wmt_ctrl_ul_cmd:str(srh_patch) result(0)
[   20.608872] [WMT-DFT][I]mt6620_sw_init:patch total num = [4]
[   20.614516] [WMT-DFT][I]mt6620_patch_dwn:the 1 time valid patch found: (/system/etc/firmware//mt6620_patch_e3_0_hdr.bin)
[   20.625636] [WMT-DFT][I]mt6620_patch_dwn:===========================================
[   20.633062] [WMT-DFT][I]mt6620_patch_dwn:[Combo Patch] Built Time = 20131118144310
[   20.640707] [WMT-DFT][I]mt6620_patch_dwn:[Combo Patch] Hw Ver = 0x8a10
[   20.647226] [WMT-DFT][I]mt6620_patch_dwn:[Combo Patch] Sw Ver = 0x8a10
[   20.653724] [WMT-DFT][I]mt6620_patch_dwn:[Combo Patch] Ph Ver = 0x0001
[   20.660316] [WMT-DFT][I]mt6620_patch_dwn:[Combo Patch] Platform = 1308
[   20.666755] [WMT-DFT][I]mt6620_patch_dwn:[Combo Patch] Content Size = 0xbb0
[   20.673701] [WMT-DFT][I]mt6620_patch_dwn:[Combo Patch] Content CRC = 0xc83c
[   20.680619] [WMT-DFT][I]mt6620_patch_dwn:===========================================
[   20.693208] [WMT-DFT][I]mt6620_patch_dwn:4 bytes address command:0x00,0x3f,0x00,0x01
[   20.990054] [WMT-DFT][I]mt6620_patch_dwn:wmt_core: patch dwn:0 frag(3, 992) ok
[   20.999017] [WMT-DFT][I]mt6620_patch_dwn:the 2 time valid patch found: (/system/etc/firmware//mt6620_patch_e3_2_hdr.bin)
[   21.023082] [WMT-DFT][I]mt6620_patch_dwn:4 bytes address command:0x00,0x80,0x10,0x01
[   21.497643] [WMT-DFT][I]mt6620_patch_dwn:wmt_core: patch dwn:0 frag(5, 860) ok
[   21.506717] [WMT-DFT][I]mt6620_patch_dwn:the 3 time valid patch found: (/system/etc/firmware//mt6620_patch_e3_3_hdr.bin)
[   21.536945] [WMT-DFT][I]mt6620_patch_dwn:4 bytes address command:0x00,0x28,0x00,0x10
[   23.226050] [WMT-DFT][I]mt6620_patch_dwn:wmt_core: patch dwn:0 frag(18, 620) ok
[   23.235820] [WMT-DFT][I]mt6620_patch_dwn:the 4 time valid patch found: (/system/etc/firmware//mt6620_patch_e3_1_hdr.bin)
[   23.253408] [WMT-DFT][I]mt6620_patch_dwn:4 bytes address command:0x00,0x3f,0x00,0x01
[   23.556197] CPU1: shutdown
[   24.024176] CPU2: shutdown
[   25.470835] [WMT-DFT][I]mt6620_patch_dwn:wmt_core: patch dwn:0 frag(24, 56) ok
[   25.482066] [WMT-DFT][I]wmt_stp_init_coex:ctrl GET_WMT_CONF ok(0xbf046218)
[   25.513180] [WMT-DFT][I]mt6620_sw_init:init_coex ok
[   25.520935] [WMT-DFT][I]mt6620_sw_init:set fm mode (2) ok
[   25.524909] [STP] mtk_wcn_stp_psm_enable:[W] STP Not Ready, Dont do Sleep/Wakeup
[   25.532383] [STP] mtk_wcn_stp_ready:[I] set ready (1)
[   25.537448] [mt6620] +++ setup_mt6620_wlan_power_for_onoff : wlan power on
反正这些代码我是没看懂,哈哈,  详情 回复 发表于 2017-12-14 10:32
298
禁止发言
没接wifi模块,开启了wifi
个人签名更多开发板详情了解哦
1.https://arm-board.taobao.com
2.www.topeetboard.com
Q: 2551456065
27
反正这些代码我是没看懂,哈哈,
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
