3203|4
118
MSP430F5529 内核电压和时钟的关系 [复制链接]
/* --COPYRIGHT--,BSD_EX
* Copyright (c) 2012, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* *  Redistributions of source code must retain the above copyright
*    notice, this list of conditions and the following disclaimer.
* *  Redistributions in binary form must reproduce the above copyright
*    notice, this list of conditions and the following disclaimer in the
*    documentation and/or other materials provided with the distribution.
* *  Neither the name of Texas Instruments Incorporated nor the names of
*    its contributors may be used to endorse or promote products derived
*    from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
*                       MSP430 CODE EXAMPLE DISCLAIMER
* MSP430 code examples are self-contained low-level programs that typically
* demonstrate a single peripheral function or device feature in a highly
* concise manner. For this the code may rely on the device's power-on default
* register values and settings such as the clock configuration and care must
* be taken when combining code from several examples to avoid potential side
* effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
* for an API functional library-approach to peripheral configuration.
* --/COPYRIGHT--*/
//   MSP430F552x Demo - Software Toggle P1.1 with 12MHz DCO
//   Description: Toggle P1.1 by xor'ing P1.1 inside of a software loop.
//   ACLK is rought out on pin P1.0, SMCLK is brought out on P2.2, and MCLK
//   is brought out on pin P7.7.
//   ACLK = REFO = 32kHz, MCLK = SMCLK = 12MHz
//                 MSP430F552x
//          | |             P1.0|-->ACLK
//          --|RST          P7.7|-->MCLK
//            |             P2.2|-->SMCLK
//            |             P1.1|-->Port Pin
//   Bhargavi Nisarga
//   Texas Instruments Inc.
//   April 2009
//   Built with CCSv4 and IAR Embedded Workbench Version: 4.21
#include
int main(void)
  volatile unsigned int i;
  WDTCTL = WDTPW+WDTHOLD;                   // Stop WDT
  P1DIR |= BIT1;                            // P1.1 output
  P1DIR |= BIT0;                            // ACLK set out to pins
  P1SEL |= BIT0;
  P2DIR |= BIT2;                            // SMCLK set out to pins
  P2SEL |= BIT2;
  P7DIR |= BIT7;                            // MCLK set out to pins
  P7SEL |= BIT7;
  UCSCTL3 |= SELREF_2;                      // Set DCO FLL reference = REFO
  UCSCTL4 |= SELA_2;                        // Set ACLK = REFO
  __bis_SR_register(SCG0);                  // Disable the FLL control loop
  UCSCTL0 = 0x0000;                         // Set lowest possible DCOx, MODx
UCSCTL1 = DCORSEL_5;                      // Select DCO range 24MHz operation
  UCSCTL2 = FLLD_1 + 374;                   // Set DCO Multiplier for 12MHz
                                            // (N + 1) * FLLRef = Fdco
                                            // (374 + 1) * 32768 = 12MHz
                                            // Set FLL Div = fDCOCLK/2
  __bic_SR_register(SCG0);                  // Enable the FLL control loop
  // Worst-case settling time for the DCO when the DCO range bits have been
  // changed is n x 32 x 32 x f_MCLK / f_FLL_reference. See UCS chapter in 5xx
  // UG for optimization.
  // 32 x 32 x 12 MHz / 32,768 Hz = 375000 = MCLK cycles for DCO to settle
  __delay_cycles(375000);
  // Loop until XT1,XT2 & DCO fault flag is cleared
  do
    UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + DCOFFG);
                                            // Clear XT2,XT1,DCO fault flags
    SFRIFG1 &= ~OFIFG;                      // Clear fault flags
  }while (SFRIFG1&OFIFG);                   // Test oscillator fault flag
  while(1)
    P1OUT ^= BIT1;                          // Toggle P1.1
    __delay_cycles(600000);                 // Delay
上面官方程序  时钟是12M,
为何没有提升内核电压,不解
外部电压决定你的内核调压范围,MCU的频率会受内核电压影响,如上图所示,如果你想运行相应的频率就必须设置对应的内核电压范围,否则工作不起来或者不正常,这样设计为了降低功耗,内核电压越低,功耗也会越少,当你使用不同频率时可以设置对应的内核电压来降低mcu的功耗  详情 回复 发表于 2017-7-17 10:26
2774
这表的意思应该是 供电1.8V以上就能满足MCU运行到最高 8M,供电2.0V以上MCU就可以跑到最高12M。跑的频率本来就不会提升电压,MCU的电压是由你的供电电路决定的,印像中一般的MCU好像没有办法能过芯片自身去调节电压,你输入1.8V,一般的MCU没有能力把1.8V升到2.0V。供参考,如有不对的地方请指正,谢谢。参考一下这个图吧。
118
楼上我说的是内核电压与MCLK频率关系,5529MCLK频率除了和供电压有关,还和内核电压有关,还有就是5529内核电压是可调的,不是说不可调,下面也是官方例子5529MCLK=25M   内核电压就提升了,我不理解的是提升内核电压阀值和官方例子不同。*******************************************************************************
* --/COPYRIGHT--*/
//   MSP430F552x Demo - Software Toggle P1.1 with 25MHz DCO
//   ACLK = REFO = 32kHz, MCLK = SMCLK = 25MHz
//                MSP430F5529
//          | |             P1.0|-->ACLK
//            |             P2.2|-->SMCLK
//            |             P1.1|-->Port Pin toggle
//   Bhargavi Nisarga
//   April 2009
#include
void SetVcoreUp (unsigned int level);
int main(void)
  P1SEL |= BIT0;
  P2SEL |= BIT2;
  P7SEL |= BIT7;
  // Increase Vcore setting to level3 to support fsystem=25MHz
  // NOTE: Change core voltage one level at a time..
  SetVcoreUp (0x01);
  SetVcoreUp (0x02);
  SetVcoreUp (0x03);
  UCSCTL3 = SELREF_2;                       // Set DCO FLL reference = REFO
  UCSCTL1 = DCORSEL_7;                      // Select DCO range 50MHz operation
  UCSCTL2 = FLLD_0 + 762;                   // Set DCO Multiplier for 25MHz
                                            // (762 + 1) * 32768 = 25MHz
  // 32 x 32 x 25 MHz / 32,768 Hz ~ 780k MCLK cycles for DCO to settle
  __delay_cycles(782000);
  // Loop until XT1,XT2 & DCO stabilizes - In this case only DCO has to stabilize
  do
  while(1)
  // Open PMM registers for write
  PMMCTL0_H = PMMPW_H;
  // Set SVS/SVM high side new level
  SVSMHCTL = SVSHE + SVSHRVL0 * level + SVMHE + SVSMHRRL0 * level;
  // Set SVM low side to new level
  SVSMLCTL = SVSLE + SVMLE + SVSMLRRL0 * level;
  // Wait till SVM is settled
  while ((PMMIFG & SVSMLDLYIFG) == 0);
  // Clear already set flags
  PMMIFG &= ~(SVMLVLRIFG + SVMLIFG);
  // Set VCore to new level
  PMMCTL0_L = PMMCOREV0 * level;
  // Wait till new level reached
  if ((PMMIFG & SVMLIFG))
    while ((PMMIFG & SVMLVLRIFG) == 0);
  // Set SVS/SVM low side to new level
  SVSMLCTL = SVSLE + SVSLRVL0 * level + SVMLE + SVSMLRRL0 * level;
  // Lock PMM registers for write access
  PMMCTL0_H = 0x00;
1059
118
关键是官方例程和手册有差距
【TI有奖直播报名中】
直播时间:4月24日(周四)上午10:00
直播奖励:好礼等您拿!
