用avrM16做连续频率采集,采集同时输出500HZ,占空比任意(我用50%)的pwm。我用T1捕获,端口接ICP1。PB3输出pwm。现在问题是,我同时开启T0,T1输出不是500HZ,而是随着输入频率改变,并且中间我加了ADC程序,输出频率也会改变。但是我只开T0,不加捕获,输出的一直是500HZ。 #include #include #include "delay.h" #define uint unsigned int #define uchar unsigned char #define PWM_0 PORTB&=~(1< #define PWM_1 PORTB|=(1< signed int wendu,flag,flag1,jd,count,flag4,flag3; volatile unsigned int CAPi=0,CAPj=0; volatile unsigned intCAP[10]={0,0,0,0,0,0,0,0,0,0};
//TIMER1 initialize - prescale:1 // WGM: 0) Normal, TOP=0xFFFF // desired value: 1mSec // actual value: 1.000mSec (0.0%) void timer0_init(void) {
TCCR0 = 0x00; //stop TCNT0 = 0x00; TCNT0 = 0x9c; OCR0 =0xF0; //改变此值可改变占空比 TCCR0 = 0x02; //设置为快速PWM模式,匹配时OC0置1,分频系数8 } void main(void) { uint dianya; DDRC=0xFF; jd=10; DDRB= 0Xff; PORTB=0XFF; DDRD&=~(1< PORTD|=1< TCCR1B=(1< TCCR1B|=0x03; TIMSK=1<
MCUCR = 0x00; GICR =0x00; timer0_init(); TIMSK = 0x21; //timer interrupt sources SEI(); //re-enable interrupts 等价与SREG=0x80
while(1) {
DDRA&=~BIT(0); ADMUX=0x40;//低4位是通道号 参考是AVCC ADCSRA=0x87; //使能ADC,单次转换,预分频为128 while(!(ADCSRA&(1< 等待转结束循环 dianya=ADCL;//先读 低位 这个必须遵守 度高位后被更新数据 dianya=ADCH*256+dianya; yanwu=dianya*0.09765625; if(yanwu>78) flag1=1; else flag1=0;
if((flag==1)&&(flag1==1)) {PORTC=0xff;} else {PORTC=0;} }
} #pragma interrupt_handler Timer1_icp_isr:6 void Timer1_icp_isr(void) //6 号中断 { unsigned char i;
if(CAPi==0) {CAPi=ICR1;CAP[0]=ICR1;}//TCCR0 = 0;} else { CAP[1]=ICR1; CAPj=ICR1-CAPi;
CAPj=1000000/8/CAPj; if(CAPj>3000) {flag=1;//TIMSK=0x21;timer0_init();SEI(); } else flag=0; TCCR1B&=0xFC;//11000000 TCCR1B|=0x03; TCNT1=0; CAPi=0; CAPj=0; } } #pragma interrupt_handlertimer0_ovf_isr:iv_TIM0_OVF //定时器0中断 void timer0_ovf_isr(void) {
TCNT0 = 0x9c; if(count比较 { PWM_1;//高电平转 } else PWM_0;//低电平停
count++; if(count>20)//周期 count=0;
