The MicroPython Interactive Interpreter Mode (aka REPL)
This section covers some characteristics of the MicroPython Interactive Interpreter Mode. A commonly used term for this is REPL (read-eval-print-loop) which will be used to refer to this interactive prompt.
Auto-indent
When typing python statements which end in a colon (for example if, for, while) then the prompt will change to three dots (...) and the cursor will be indented by 4 spaces. When you press return, the next line will continue at the same level of indentation for regular statements or an additional level of indentation where appropriate. If you press the backspace key then it will undo one level of indentation.
If your cursor is all the way back at the beginning, pressing RETURN will then execute the code that you’ve entered. The following shows what you’d see after entering a for statement (the underscore shows where the cursor winds up):
>>> for i in range(3):
... _
If you then enter an if statement, an additional level of indentation will be provided:
>>> for i in range(30):
... if i > 3:
... _
Now enter break followed by RETURN and press BACKSPACE:
>>> for i in range(30):
... if i > 3:
... break
... _
Finally type print(i), press RETURN, press BACKSPACE and press RETURN again:
>>> for i in range(30):
... if i > 3:
... break
... print(i)
>>> Auto-indent won’t be applied if the previous two lines were all spaces. This means that you can finish entering a compound statment by pressing RETURN twice, and then a third press will finish and execute.
Auto-completion
While typing a command at the REPL, if the line typed so far corresponds to the beginning of the name of something, then pressing TAB will show possible things that could be entered. For example type m and press TAB and it should expand to machine. Enter a dot . and press TAB again. You should see something like:
>>> machine.
__name__ info unique_id reset
bootloader freq rng idle
sleep deepsleep disable_irq enable_irq
Pin
The word will be expanded as much as possible until multiple possibilities exist. For example, type machine.Pin.AF3 and press TAB and it will expand to machine.Pin.AF3_TIM. Pressing TAB a second time will show the possible expansions:
>>> machine.Pin.AF3_TIM
AF3_TIM10 AF3_TIM11 AF3_TIM8 AF3_TIM9
>>> machine.Pin.AF3_TIM
Interrupting a running program You can interupt a running program by pressing Ctrl-C. This will raise a KeyboardInterrupt which will bring you back to the REPL, providing your program doesn’t intercept the KeyboardInterrupt exception.
For example:
>>> for i in range(1000000):
... print(i)
6467
6468
Traceback (most recent call last):
File "", line 2, in
KeyboardInterrupt:
Paste Mode
If you want to paste some code into your terminal window, the auto-indent feature will mess things up. For example, if you had the following python code:
def foo():
print('This is a test to show paste mode')
print('Here is a second line')
foo()
and you try to paste this into the normal REPL, then you will see something like this:
>>> def foo():
... print('This is a test to show paste mode')
... print('Here is a second line')
... foo()
File "", line 3
IndentationError: unexpected indent If you press Ctrl-E, then you will enter paste mode, which essentially turns off the auto-indent feature, and changes the prompt from >>> to ===. For example:
>>> paste mode; Ctrl-C to cancel, Ctrl-D to finish
=== def foo():
=== print('This is a test to show paste mode')
=== print('Here is a second line')
=== foo()
Paste Mode allows blank lines to be pasted. The pasted text is compiled as if it were a file. Pressing Ctrl-D exits paste mode and initiates the compilation.
Soft Reset
A soft reset will reset the python interpreter, but tries not to reset the method by which you’re connected to the MicroPython board (USB-serial, or Wifi).
You can perform a soft reset from the REPL by pressing Ctrl-D, or from your python code by executing:
raise SystemExit
For example, if you reset your MicroPython board, and you execute a dir() command, you’d see something like this:
>>> dir()
['__name__', 'pyb']
Now create some variables and repeat the dir() command:
>>> i = 1
>>> j = 23
>>> x = 'abc'
>>> dir()
['j', 'x', '__name__', 'pyb', 'i']
Now if you enter Ctrl-D, and repeat the dir() command, you’ll see that your variables no longer exist:
PYB: sync filesystems
PYB: soft reboot
MicroPython v1.5-51-g6f70283-dirty on 2015-10-30; PYBv1.0 with STM32F405RG
Type "help()" for more information.
>>> dir()
['__name__', 'pyb']
The special variable _ (underscore)
When you use the REPL, you may perfom computations and see the results. MicroPython stores the results of the previous statment in the variable _ (underscore). So you can use the underscore to save the result in a variable. For example:
>>> 1 + 2 + 3 + 4 + 5
>>> x = _
>>> x
Raw Mode
Raw mode is not something that a person would normally use. It is intended for programmatic use. It essentially behaves like paste mode with echo turned off.
Raw mode is entered using Ctrl-A. You then send your python code, followed by a Ctrl-D. The Ctrl-D will be acknowledged by ‘OK’ and then the python code will be compiled and executed. Any output (or errors) will be sent back. Entering Ctrl-B will leave raw mode and return the the regular (aka friendly) REPL.
