4262|1
32
CORTEX_M4_0: Error: Connection with the target was unexpectedly lost. [复制链接]
CORTEX_M4_0: GEL Output:
Memory Map Initialization Complete
CORTEX_M4_0: Failed to remove the debug state from the target before disconnecting.  There may still be breakpoint op-codes embedded in program memory.  It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
CORTEX_M4_0: GEL: Target must be connected before calling the function
M4和电脑没有连接  详情 回复 发表于 2016-6-13 19:22
M4和电脑没有连接
