3461|5
关于MSP430FR5969 多通道AD采样 [复制链接]
单次采样试过了 没问题   可是改成多路以后中断都进不去了! 哪个大神帮着看看哪的毛病!谢谢了
程序有电多 我只拷贝了我更改的部分!
1.先是初始化 A12 A13 A14 A15
   ADC12_B_configureMemoryParam configureMemoryParam = {0};
    configureMemoryParam.memoryBufferControlIndex = ADC12_B_MEMORY_0;
    configureMemoryParam.inputSourceSelect = ADC12_B_INPUT_A12;
    configureMemoryParam.refVoltageSourceSelect =
        ADC12_B_VREFPOS_AVCC_VREFNEG_VSS;
    configureMemoryParam.endOfSequence = ADC12_B_NOTENDOFSEQUENCE;
    configureMemoryParam.windowComparatorSelect =
        ADC12_B_WINDOW_COMPARATOR_DISABLE;
    configureMemoryParam.differentialModeSelect =
        ADC12_B_DIFFERENTIAL_MODE_DISABLE;
    ADC12_B_configureMemory(ADC12_B_BASE, &configureMemoryParam);
        //ADC12_B_configureMemoryParam configureMemoryParam = {0};
        configureMemoryParam.memoryBufferControlIndex = ADC12_B_MEMORY_1;
        configureMemoryParam.inputSourceSelect = ADC12_B_INPUT_A13;
   configureMemoryParam.memoryBufferControlIndex = ADC12_B_MEMORY_2;
   configureMemoryParam.inputSourceSelect = ADC12_B_INPUT_A14;
  configureMemoryParam.memoryBufferControlIndex = ADC12_B_MEMORY_3;
  configureMemoryParam.inputSourceSelect = ADC12_B_INPUT_A15;
  configureMemoryParam.endOfSequence = ADC12_B_ENDOFSEQUENCE;
    ADC12_B_clearInterrupt(ADC12_B_BASE,
                           0,
                           ADC12_B_IFG3
    //Enable memory buffer 0 interrupt
    ADC12_B_enableInterrupt(ADC12_B_BASE,
                            ADC12_B_IE3,
                            0,
                            0);
2.定时器里转换
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=TIMERB0_VECTOR
__interrupt
#elif defined(__GNUC__)
__attribute__((interrupt(TIMERB0_VECTOR)))
#endif
void TIMERB0_ISR(void)
    //Enable/Start sampling and conversion
     * Base address of ADC12B Module
     * Start the conversion into memory buffer 0
     * Use the single-channel, single-conversion mode
    ADC12_B_startConversion(ADC12_B_BASE,
                            ADC12_B_MEMORY_0,
                                                        ADC12_B_SEQOFCHANNELS);
   // __bis_SR_register(LPM3_bits | GIE);   // Wait for conversion to complete
    // __bic_SR_register(GIE);
3.AD中断
#pragma vector=ADC12_VECTOR
__interrupt
__attribute__((interrupt(ADC12_VECTOR)))
#endif
void ADC12_ISR(void)
    switch(__even_in_range(ADC12IV,12))
    case  0: break;                         // Vector  0:  No interrupt
    case  2: break;                         // Vector  2:  ADC12BMEMx Overflow
    case  4: break;                         // Vector  4:  Conversion time overflow
    case  6: break;                         // Vector  6:  ADC12BHI
    case  8: break;                         // Vector  8:  ADC12BLO
    case 10: break;                         // Vector 10:  ADC12BIN
    case 12:
            // Vector 12:  ADC12BMEM0 Interrupt
            ADC12IFGR0 &= ~ADC12IFG0;             // Clear interrupt flag
            __bic_SR_register_on_exit(LPM3_bits); // Exit active CPU
        break;                              // Clear CPUOFF bit from 0(SR)
    case 14:
            ADC12IFGR0 &= ~ADC12IFG1;             // Clear interrupt flag
            break;                         // Vector 14:  ADC12BMEM1
    case 16:
            ADC12IFGR0 &= ~ADC12IFG2;             // Clear interrupt flag
            break;                         // Vector 16:  ADC12BMEM2
    case 18:
            qInput[samp_count] = ADC12_B_getResults(ADC12_B_BASE, ADC12_B_MEMORY_0);
                samp_count++;
                if(samp_count >=256)
                        samp_count =0;
                        mode = 1;
                        // Disable ADC12 and Timer_A0
                        ADC12_B_disable(ADC12_B_BASE);
                        Timer_B_stop(TIMER_B0_BASE);
                __bic_SR_register_on_exit(LPM0_bits); // Exit active CPU //退出LPM0
            break;                         // Vector 18:  ADC12BMEM3
    case 20: break;                         // Vector 20:  ADC12BMEM4
    case 22: break;                         // Vector 22:  ADC12BMEM5
    case 24: break;                         // Vector 24:  ADC12BMEM6
    case 26: break;                         // Vector 26:  ADC12BMEM7
    case 28: break;                         // Vector 28:  ADC12BMEM8
    case 30: break;                         // Vector 30:  ADC12BMEM9
    case 32: break;                         // Vector 32:  ADC12BMEM10
    case 34: break;                         // Vector 34:  ADC12BMEM11
    case 36: break;                         // Vector 36:  ADC12BMEM12
    case 38: break;                         // Vector 38:  ADC12BMEM13
    case 40: break;                         // Vector 40:  ADC12BMEM14
    case 42: break;                         // Vector 42:  ADC12BMEM15
    case 44: break;                         // Vector 44:  ADC12BMEM16
    case 46: break;                         // Vector 46:  ADC12BMEM17
    case 48: break;                         // Vector 48:  ADC12BMEM18
    case 50: break;                         // Vector 50:  ADC12BMEM19
    case 52: break;                         // Vector 52:  ADC12BMEM20
    case 54: break;                         // Vector 54:  ADC12BMEM21
    case 56: break;                         // Vector 56:  ADC12BMEM22
    case 58: break;                         // Vector 58:  ADC12BMEM23
    case 60: break;                         // Vector 60:  ADC12BMEM24
    case 62: break;                         // Vector 62:  ADC12BMEM25
    case 64: break;                         // Vector 64:  ADC12BMEM26
    case 66: break;                         // Vector 66:  ADC12BMEM27
    case 68: break;                         // Vector 68:  ADC12BMEM28
    case 70: break;                         // Vector 70:  ADC12BMEM29
    case 72: break;                         // Vector 72:  ADC12BMEM30
    case 74: break;                         // Vector 74:  ADC12BMEM31
    case 76: break;                         // Vector 76:  ADC12BRDY
    default: break;
大家帮看看哪有毛病 谢谢了
这个手册上还要有写,主要是寄存器的值的配置,这个还是自己看看吧,对自己也是一种提高,老实说,在论坛上贴程序的,很多是解决不了问题的,就像我一样,即使这个芯片我用过,我也不会再回去翻芯片手册一点点的对照程序检查  详情 回复 发表于 2016-5-14 17:19
自己顶顶
补充 :想改成 多通道 单次 采样
来人啦 求救了
977
