2244|0
裸片初长成(高级)
[转]最热MSP430相关的NFC整体参考设计 [复制链接]
转自:
http://www.deyisupport.com/question_answer/wireless_connectivity/f/45/t/75303.aspx
ConnectivityTIDM-NFC-I2C-MODULE : NFC I2C Reader Module Reference Design (查看详情 ) G2553Low Cost, Small Form Factor
ConnectivityTIDA-00230 : NFC Configuration & Logging Interface ( Dual Port FRAM: NFC-FRAM-Serial) (http://www.ti.com/lit/ug/tidu388/tidu388.pdf ) FR59698Mbps Throughput via FRAM over Serial, 800Kbps Throughput over NFC via FRAM
ConnectivityTIDM-RF-Sensornode : Development Platform for 6LowPAN (查看详情 )F5438A Multiple interface/COM ports ( upto 8),  Software with Contiki OS
ConnectivityTIDA-00217 : Dynamic Field-Powered NFC for Data Logging Access Control & Security Applications Reference Design (查看详情 )FR5969FRAM for fast data write, AES256 security, Ultra low Power
ConnectivityTIDM-DYNAMICNFCTAG : Dynamic Near Field Communication (NFC) Type 4B Tag (查看详情 ) FR5738FRAM, Small Form Factor
ConnectivityTIDM-BATTERYLESSNFCKEYBOARD : Battery-less Near Field Communication (NFC) Keyboard (查看详情 ) FR5739FRAM, Small Form Factor
ConnectivityTIDM-NFC-EZ430-MODULE : NFC EZ430 Reader Module Reference Design (查看详情 )
